Truck bed plastic or metal??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Nc12vpower, Sep 6, 2015.
  1. Sep 6, 2015 at 7:43 PM
    Nc12vpower
    Nc12vpower [OP] Member
    Gray 2011 tacoma TRD Sport
    5% tint on all the windows and 35% on the front windshield
    Is the inside of the bed of a 2011 tacoma all metal or like a plastic insert? Looking information so I'll know what kind of weight I can haul back there.
  2. Sep 6, 2015 at 7:44 PM
    fireman903
    fireman903 Well-Known Member
    new jersey
    06 taco
    3 inch lift 33 in tires undercover emergency responder light 30 rigid led light bar bed lights engine compartment lights
    the whole bed is fiberglass
  3. Sep 6, 2015 at 7:44 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Composite
    JDawg562 and KB Voodoo like this.
  4. Sep 6, 2015 at 7:46 PM
    Nc12vpower
    If I drill holes in the bottom of the bed to hold something down and from moving side to side would the bolts end up pulling threw sinceit's fiberglass
  5. Sep 6, 2015 at 7:48 PM
    OZ-T
    Peter North
    British Columbia
    Put D rings on the existing bed bolts , there's a thread
  6. Sep 6, 2015 at 7:50 PM
    Nc12vpower
    What's the thread?
  7. Sep 6, 2015 at 7:57 PM
    OZ-T
    Peter North
    British Columbia
    tinker_troy likes this.
  8. Sep 6, 2015 at 7:58 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    DrFunker likes this.
  9. Sep 6, 2015 at 7:59 PM
    OZ-T
    Peter North
    British Columbia
    That ones even better ^
  10. Sep 7, 2015 at 11:45 AM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    I know these are D-rings, but these are put out by Toyota with the backing plate for use on the Tacoma composite bed. PT278-35054
    If you use any bolt, be sure to use some type of backing plate to distribute the load.
  11. Sep 7, 2015 at 12:46 PM
    OZ-T
    Peter North
    British Columbia
    Looks like I missed some fun by some of the posts quoted here that are now deleted
    Blackout14 likes this.
  12. Sep 7, 2015 at 1:29 PM
    OZ-T
    Peter North
    British Columbia
    but seriously , D rings on the bed bolts is the strongest solution
    DoorDing likes this.
  13. Sep 7, 2015 at 1:29 PM
    DrFunker
    DrFunker Well-Known Member
  14. Sep 7, 2015 at 1:51 PM
    ODNAREM
    Ron
    Huntington Beach,CA.
    2012 TRD Sport Prerunner
    Composite and D rings is what you need.
  15. Feb 29, 2016 at 12:45 PM
    tacitos
    tacitos Tah-Key-Toes
    16 TRDORDCLBJBL
    Is this solution still holding up? I need to add another anchor in the center of my bed. I need it to tie down (2) sportbikes. The way I would tie them down is using both D-rings up front and using this center d-ring to tie down both bikes in the middle.
    My concern is the composite bed...
    Thanks,
  16. Feb 29, 2016 at 12:51 PM
    Clearwater Bill
    Billy
    Largo Florida
    There is no center bed bolt is there? Didn't these replace bed bolts, meaning they are frame mounted, with no load on the composite.
  17. Feb 29, 2016 at 12:51 PM
    tacitos
    16 TRDORDCLBJBL
    Thank you,
    Sorry for your loss
  18. Feb 29, 2016 at 12:54 PM
    tacitos
    16 TRDORDCLBJBL
    I added the d-Rings to the bed bolts that secure to the frame. That setup is good for (1) motorcycle secured to the centerline of the bed.
    Yesterday I had to haul (2) motorcycles and I had no other choice but to strap them to the front rail cleats. It was a short trip, but I want to avoid using the cleats again for the motorcycles.
  19. Feb 29, 2016 at 12:59 PM
    Clearwater Bill
    Billy
    Largo Florida
    Gotcha. Dimensions of plates?
  20. Feb 29, 2016 at 1:05 PM
    tacitos
    16 TRDORDCLBJBL
    Thats about right, I have (2) of those plates left over from my d-ring mod. I only really need (1) now, but I also need a d-ring for it.
