Truck Bed Outlet - OK to Use for Camper Shore Power?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jrf_1845, Nov 1, 2018.
  1. Nov 1, 2018 at 4:56 PM
    Jrf_1845
    Jrf_1845 [OP] New Member
    2008 Tacoma Crew Cab Long Bed
    I just bought a camper, and instead of altering the Tacoma's existing wiring/alternator/battery, I am considering a simple extension cord attached from the bed outlet to the camper's shore power (30A) connection in order to charge the camper batteries.
    Thoughts? Pros/Cons? Thanks! - Jason
  2. Nov 1, 2018 at 5:01 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    Ha, no. It's only a 3.5 amp outlet @ 400watts.
    FrostbitTaco likes this.
  3. Nov 1, 2018 at 5:20 PM
    L J
    L J Well-Known Member
    Illinois
    07 4X4 SR5 TRD Sport DCLB
    ...and you can only get that when in park.
  4. Nov 1, 2018 at 5:26 PM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    '15 DCSB TRD Sport 4wd super white (sold) '13 access cab SR5 4wd
    piddly stuff
    A small generator or solar, depending on what your desires are, is about your only options I would think
  5. Nov 1, 2018 at 6:04 PM
    j8food
    j8food Well-Known Member
    Jay
    2009 Tacoma TRD Off Road
    Wouldn't that be converting 12v from the truck to 110v at the outlet then back to 12v for the camper batteries? Seems like a lot of wasted electricity.
  6. Nov 1, 2018 at 6:06 PM
    computeruser6
    computeruser6 Nuclear Janitor
    Dirk
    Escondido
    2008 Regular Cab Tundra
    King 2.5 coilovers Nitto Exo Grapplers
  7. Nov 1, 2018 at 6:22 PM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    If you are just wanting to charge the camper batteries all you should have to do is hook up the trailer wires to the truck. Your 7 pin connector shuld have a hot wire that charges the batteries while you're driving. If you're stationary for a bit just back the truck up and hook up. The truck will have to be running of course but then it would to run the bed outlet also. This isn't the optimal solution but at least doable compared to using the bed outlet. A generator or Solar is still the best solution.
    stickyTaco likes this.
