Truck Bed Inverter Outlet to power up portable air pump?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DESportTRD, Dec 12, 2017.
  1. Dec 12, 2017 at 10:05 AM
    DESportTRD
    DESportTRD [OP] Well-Known Member
    2017 Blazing Blue Pearl DCSB Sport 4x4, MT
    Has anyone used their truck bed inverter outlet to power up a portable air pump? I live near the beach and do a far amount of surf fishing on the sand. After I come off the beach, I need to air up my tires from 20 lbs to 30 lbs. I don't always trust the the State Park Air Stations.
  2. Dec 12, 2017 at 10:07 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    It will work, but so will the ones in the cab. It has to be a small compressor and it will take a while.
  3. Dec 12, 2017 at 10:58 AM
    dynamicweight
    dynamicweight Well-Known Member
    It'll probably work on something small. I tried hooking up my porter cable 6 gallon pancake compressor just for fun and it can't even turn it over. I have a small automotive compressor that works off the cigarette lighter. To go from 20 to 30 psi in the big Tacoma tires is practically measured on a calendar though. More of an emergency thing. One day I going to splurge and buy the on-board ARB compressor. Looks soooo nice and get's good reviews. It can be mounted under hood or in the bed.
  4. Dec 12, 2017 at 11:05 AM
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    Hm I was going to try using my pancake compressor too, but I guess I'll just have to buy a viair compressor.
  5. Dec 12, 2017 at 11:23 AM
    Prairie Hawk
    Prairie Hawk Unknown Member
    North border of Weird
    2016 Silver DCLB OR
    SOS Concepts Sliders Softopper OVTune 87 iphone charger WeatherTech Floor Liners F/R De-badged Rear Differential Breather Mod
    It will power my 100 psi pancake compressor.
    shakerhood likes this.
  6. Dec 12, 2017 at 11:37 AM
    DavidM310
    DavidM310 Well-Known Member
    Temple, Texas
    2017 Tacoma/2015 4Runner/2015 IS250
    I got this at HF with a 20% coupon.
    Hooks to your battery, runs 30amps at 12volts = 360watts.
    Beats having to pay with coins somewhere and does a pretty good job. Does the job for a few bucks.
  7. Dec 12, 2017 at 11:46 AM
    DavidM310
    Temple, Texas
    Also the stock inverter is capped at 400w from a 12v DC to I think 110v/120v AC.
    The max amps you could run on that inverter is 3.33amps at 120V AC. 400watts / 120v = 3.33 amps.
    Every eletrical component needs to state the electrical draw. Look it over and that will tell you what you can run.
  8. Dec 12, 2017 at 12:28 PM
    mrCanoehead
    mrCanoehead Well-Known Member
    Ottawa
    2018 DCSB Sport manual 3.5 l
    The issue is more in the inrush current, which is high on a compressor and could potentially trip the breaker. But Prairie Hawk seems to be saying that it doesn't trip.
    Prairie Hawk likes this.
  9. Dec 12, 2017 at 12:46 PM
    DavidM310
    Temple, Texas
    Yeah I agree with you, peak start up draw will be alot higher than continuous draw. What size fuse is hooked up to the inverter? Could be other components tied in to it and Toyota raised the amps on the fuse. Would also like to see the gauge of the wiring, it might be running hot.
    This 100psi air compressor from Porter Cable draws a continuous 10amps at 120v AC. That is 1,200 watts, 3xs the recommended rating on the stock inverter.
    https://m.lowes.com/pd/PORTER-CABLE...MI_Iem5qqF2AIV1bbACh1o6AEGEAQYASABEgJAevD_BwE
  10. Dec 12, 2017 at 12:50 PM
    DavidM310
    Temple, Texas
  11. Dec 12, 2017 at 12:56 PM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
  12. Dec 12, 2017 at 1:03 PM
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    I have a 1/3 HP 3gal Harbor Freight pancake compressor. Label says it draws 2.6 amps. I've run it on an old nasty square wave 500w inverter with no issues. Those cheap little 12v air compressors suck for car tires. They get hot and take forever, i had one that said not to run it for more than X minutes without cool down. There's a reason ARB ones are big bucks.
  13. Dec 12, 2017 at 1:30 PM
    DavidM310
    Temple, Texas
    You should be able to run that in your bed’s inverter as you are 2.6/3.3 amps and 312/400 watts.
  14. Dec 12, 2017 at 2:49 PM
    ihatemytruck
    ihatemytruck Smartass
    Dave
    Southern California
    '17 Tacoma 4x4 off road DCLB
    I've tried a pancake compressor on mine. Did it with the truck motor running
  15. Dec 12, 2017 at 2:56 PM
    Metallikatz3
    Metallikatz3 Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
    I have one of these that runs just fine off the bed outlet. 97080.html
  16. Dec 12, 2017 at 4:49 PM
    Barcared
    Barcared Well-Known Member
    Philadelphia, PA
    2016 Barcelona Red TRDOR RIP. 2020 MGM TRD OR.
    https://www.amazon.com/Viair-00088-88P-Portable-Compressor/dp/B005ASY23I
    get this while the sale lasts.
    It hooks on the battery with the truck running and you don't have to ask what if's. I paid $70?80? I forget but definitely not the price that's on there now for $47! The cables that attach to the battery and the air hose are more than long enough to reach all 4 corners, with length to spare.
    It's small and it sits in the storage space in the back seat of my DCSB. It's worth it. It's brought me up from 15psi to 30 in about 15-20 minutes. I like it for state forest roads. Those roads are rutted and anything less than 15psi makes my teeth and liver chatter. I've used it a few times on the beach when there's a line at the air station.
