Truck bed foam
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 3rdgntaco, Apr 15, 2020.
  1. Apr 15, 2020 at 5:40 PM
    3rdgntaco
    3rdgntaco [OP] Member
    jake
    2019 4x4 tacoma with century bed cover
    Tuff country rear leaf springs, rough country 2 inch level, century bed cover with thule cross members
    Hey guys, wondering the cheapest route for adding padding to truck bed sleeping platform. Wanting to keep it under 4 inches thick
  2. Apr 15, 2020 at 6:34 PM
    TacoMamba35
    TacoMamba35 Well-Known Member
    PNW
    2021 Tacoma TRD OR DCSB 3.5
    Probably a memory foam mattress topper...
  3. Apr 15, 2020 at 6:44 PM
    TacoTime850
    TacoTime850 Always Maybe Sometimes Never
    Everywhere and Nowhere
    2019 DCSB 4x4
    2.5” lift, Fox 2.5 ext tvl adjustable w/ DSC, SPC adjustable UCAs, Icon RXT leaf pack, Superbump stops, 17x9 Fuel Podium Bronze wheels, 285/70/17 Cooper STT Pro
    Air up camping bed is prob gonna be best. Anything foam that thin and you might as well be sleeping directly on the truck bed.
  4. Apr 15, 2020 at 6:49 PM
    emmett
    emmett Well-Known Member
    Emmett
    06 Red TRD offroad 6spd
    with memory foam youll end up right on the wood. it's not meant to be slept on without a mattress under it, and it gets hard in the cold. egg crate foam could be good, but I've found putting a soft (but supportive) carpet over the wood first helps a lot. I do use a mattress topper, but it's bad for cold and is a lot better with 2 layers of carpet under it.
    layers of those foam squares (look like puzzle pieces) under a thin mattress would be good too. that extra layer helps your pressure points.
  5. Apr 15, 2020 at 6:53 PM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    I had 2.5" memory foam. Worked great when I had my platform. Very comfortable.
  6. Apr 15, 2020 at 7:00 PM
    Reddy
    Reddy Well-Known Member
    Scott
    Ohio
    '11 TRD OR AC
    OME 885's/Dakars/265's/belly skid
    If you want to go the cheapest route, go to JoAnn Fabrics or somewhere like that and look at their bulk foam.
  7. Apr 15, 2020 at 7:04 PM
    Sig45
    Mark
    Maine
    I did that and it was significantly more expensive than what I would have guessed. And not wide enough to cover as a single piece
  8. Apr 15, 2020 at 7:05 PM
    Reddy
    Scott
    Ohio
    '11 TRD OR AC
    Doesn't mean it's not the cheapest way!
    emmett likes this.
  9. Apr 15, 2020 at 7:06 PM
    Sig45
    Mark
    Maine
    Was cheaper for me to buy the memory foam topper and trim to fit.
  10. Apr 15, 2020 at 7:09 PM
    emmett
    Emmett
    hows it do in the cold? mine will be stiff, and then soften from my body heat so i sink in, but then cant move because the rest is still like a rock
  11. Apr 15, 2020 at 7:10 PM
    Sig45
    Mark
    Maine
    I really didn't notice any difference. And I slept back there a couple times when it was below freezing.
    emmett[QUOTED] likes this.
  12. Apr 15, 2020 at 7:11 PM
    emmett
    Emmett
    well op, looks like its hit or miss depending on the memory foam type
    Sig45[QUOTED] likes this.
  13. Apr 15, 2020 at 7:13 PM
    Sig45
    Mark
    Maine
    I'll try and find link to it. Amazon purchase years ago.
  14. Apr 15, 2020 at 7:15 PM
    Sig45
    Mark
    Maine
  15. Apr 16, 2020 at 4:55 AM
    3rdgntaco
    jake
    Its worth noteing that i have a 6 month old german Shepard that would be back there too, trying to steer away from air mattress for the sake of them big ole claws
