Truck Bed Bolt keeps spinning help!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jonnytacoo, Feb 15, 2023.
  1. Feb 15, 2023 at 5:36 PM
    jonnytacoo
    jonnytacoo [OP] Well-Known Member
    Jonny
    So Cal
    2018 TRD Off-Road 4x4
    OEM
    I installed a baseplate into my truck bed and two of the bolts I think I stripped them out with the impact. The fact they keep spinning makes me think the nuts (which are welded to the frame) might be stripped.
    I ordered some new bolts from Toyota and I’m going to install them and see if they will re tap (since they are self tapping bolts)
    If anyone has any ideas on how to fix this issue please let me know.
    I know you can drill and tap but I have no idea how to do this and also I think I would need an extension to even fit down in there to tap it.
    thanks for your help
  2. Feb 15, 2023 at 8:36 PM
    Ffej
    Ffej Well-Known Member
    Evergreen, Colorado
    '22 TRD OR DCSB
    Bed mat
    Did you use the impact wrench to tighten the bed bolts, and then they started spinning after one too many ugga duggas?
    Kolohe07, Chew and jonnytacoo[OP] like this.
  3. Feb 15, 2023 at 8:41 PM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Can't you crawl under the truck and see what's happening? The frame isn't boxed in the rear.
    Are you able to remove the bolts? If they spin and spin, you probably broke the nut free from the frame.
    LeakyAC, SR-71A, mitt22 and 2 others like this.
  4. Feb 15, 2023 at 8:51 PM
    jonnytacoo
    Jonny
    So Cal
    OEM
    I’m able to remove the bolts.
    The nuts aren’t broke free from the frame. They are welded to the frame.
  5. Feb 15, 2023 at 8:52 PM
    jonnytacoo
    Jonny
    So Cal
    OEM
    exactly
  6. Feb 15, 2023 at 9:43 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
  7. Feb 16, 2023 at 5:11 AM
    Greg-tacoma
    Greg-tacoma Well-Known Member
    Greg
    2016 Black 4cyl 4wd
    Bed cover, soon bug deflector, halo interior lights and backup
    Sounds like a retap or you may need to go up one size and tap. Get away from the impact wrenches on things. I have had grease monkeys tighten tires so tight I couldn’t break them free. On a cold dark night you need to change a tire your screwed. I usually take a tee and hand tighten so I have at least a chance.
    jonnytacoo[OP] likes this.
  8. Feb 16, 2023 at 5:14 AM
    ToyoTaco25
    ToyoTaco25 Well-Known Member
    North Carolina
    09 Super-White DCSB 6-Speed
    ProComp 4" D-Bag, I mean Drop Bracket Lift, AMP Research Powersteps, 285/70-R17’s, Magnaflow, AFE CAI, Dipped Badges
    If the nuts are stripped you should be able to see corresponding damage on the bolts?
  9. Feb 16, 2023 at 5:34 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    The bolts are longer than necessary. You can crawl under the truck and add a nut from the bottom. It may be a two person job.
  10. Feb 16, 2023 at 5:58 AM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers and a skewp
    Beat me to it.
    This! Quick and easy
    davidstacoma and jonnytacoo[OP] like this.
  11. Feb 16, 2023 at 6:17 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
  12. Feb 16, 2023 at 9:54 AM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    Whenever I get a vehicle back from a shop and know the wheels/tires have been "serviced" I loosen lug nuts then torque to spec. Always check tire pressure with a gauge.
  13. Feb 24, 2023 at 9:15 AM
    jonnytacoo
    Jonny
    So Cal
    OEM
    Thank you guys for the advice. I bought longer bolts from Mc mastercarr and used some new bolts underneath. Had to drill out a couple of them but it worked! Everything is torqued down to spec and I also installed 1/8 neoprene washers between all six bed mounts so no more rubbing metal to plastic which is a problem with the tacomas.
    Hillman 4328 5/8 ID x 2-1/4 OD x 1/8 in. Large Neoprene Washer (6-Pack) https://www.amazon.com/dp/B00IAVHTQ4
    RDT415 and davidstacoma like this.
  14. May 30, 2024 at 6:34 PM
    The_Crunchy_Taco
    The_Crunchy_Taco New Member
    2020 Tacoma trd or
    I’ve got the same problem one to many duggas. Adding the extra nut to the already long bolt is freakin genius!! Saved me a lot of headache much appreciated!
