TRQ Wheel bearing assemblies - Anyone use them?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by texsw, Oct 4, 2018.
  1. Feb 27, 2023 at 1:29 PM
    JohnH213
    JohnH213 New Member
    I just installed two TRQ hub assemblies - one failed within a few weeks and the other is fine. Went to the auto recyclers and bought a used hub that works fine and it was about half the price. I had to clean it up a bit, but it bums me out that one of them was basically DOA.
  2. Feb 27, 2023 at 4:49 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
  3. Mar 3, 2023 at 12:01 PM
    BigCountry762x39
    BigCountry762x39 Well-Known Member
    TL
    PNW, Oregon!
    2009 Tacoma, with the cool white paint peel
    Arb Deluxe bull bar Front Bumper Ironman4x4 12k winch synth line AFE Intake OME 2.75in Dakar Leaf springs (R) Fox 2.0 bypass shocks (R) Bilstein 6112 (F) 33's on KMC wheels off road lighting comfort mods Redrock HD roof rack Retevis rt95 Radio Slotted Rotors and HD pads
    well I've a set of these sitting in the shop for my Tacoma, do they come with the Oil seal, and the Bearing O ring in the box? was thinking things I'd need replace if since ill already be half way there, doing brakes this weekend and figured might as well do bearings too, cut open one box and looked decent but wanted to make sure i had all the parts prior to working.
  4. Mar 3, 2023 at 12:24 PM
    TheJackal
    TheJackal Talented Wiseguy...
    WITSEC
    05 Speedway Blue Tacoma DCSB TRD Sport
  5. Mar 3, 2023 at 12:31 PM
    glk21c
    glk21c Well-Known Member
    MD
    2007 Silver Tacoma TRD Sport 4x4
  6. Mar 3, 2023 at 1:22 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I have never seen a set that did not come with the o-ring.
    The Beck/Arnely ones come with the knuckle seal.
    As do some of the others, but not all provide that seal.
    FWIW, I’d recommend the OEM dust seal.
    The aftermarket ones usually don’t fit good.
    Mine were loose. I took a hammer and “made them fit”. Also used to small amount of RTV to “glue them in place”, just to make me feel better.
  7. Mar 3, 2023 at 1:26 PM
    BigCountry762x39
    TL
    PNW, Oregon!
    found an install video from them and I don't see them install the O ring and seal guess I'll just open the box up tomorrow and talk a look around.
    TnShooter[QUOTED] likes this.
  8. Mar 3, 2023 at 1:30 PM
    TnShooter
    Deogee
    STOCK
    Sometimes they are already on the hub.
    Sometimes they are in a separate bag.
    I had a small panic attack when I opened one set of mine.
    There was not an O-ring in a bag like the other one.
    Thankfully, I seen it on hub before I went to buy one.
  9. Mar 3, 2023 at 1:34 PM
    BigCountry762x39
    TL
    PNW, Oregon!
    i mean worse case i check the o ring and it looks ok clean it up and re install. but the oil seal against the axle ill be heading over to toyota
  10. Mar 3, 2023 at 1:34 PM
    tak1313
    tak1313 Well-Known Member
    2013 Base 2WD
    I'm not saying good or bad, one way or the other, but on the Prius the 1a bearing replaced a Timken that only lasted about 10 months, and my wife (who drives the Prius) drives like a girl.
  11. Mar 3, 2023 at 1:49 PM
    BigCountry762x39
    TL
    PNW, Oregon!
    I'm not disregarding anything that anyone is saying here but I've a recpt for the purchase, and the bearings are super-fast to replace for me, likely going to take me longer to get the truck set on jackstands in my shop than anything else. I'm willing to swap them and if they get loud, I will warranty them out and get new ones.
    TnShooter likes this.
  12. Mar 3, 2023 at 1:58 PM
    TnShooter
    Deogee
    STOCK
    Yeah. Very true.
    Not much to it.
    17mm wrench
    21mm socket
    35mm socket
    And I forget the size for the caliper.
    But like you said, it takes about as long to get the truck on and off of stands as it does to change the hubs.
    I actually bought a torque adapter to “torque” the hub bolts right. But the first time I just got them “tight enough”
  13. Mar 3, 2023 at 2:04 PM
    BigCountry762x39
    TL
    PNW, Oregon!
    tell me about this torque adapter? i usually just stuff a screwdriver into a clean vent and add like 2 lb to the torque wrench. but I've also seen guys only jack up one side and "lock" it into 4wd and then just truck the torque wrench!
  14. Mar 3, 2023 at 3:14 PM
    TnShooter
    Deogee
    STOCK
    I am talking about 4 hub bolts that screw into the spindle. It looks like this but is a 17mm
    As for the axle nut
  15. Mar 3, 2023 at 3:21 PM
    #35
    BigCountry762x39
    TL
    PNW, Oregon!
    ah okay, ive long handle box wreches. ill use to break the bolts loose, and then a good old open-ended wrench, maybe if im feeling fancy grab the crows foot
    Taco 422 and TnShooter[QUOTED] like this.
  16. Mar 3, 2023 at 3:22 PM
    #36
    TnShooter
    Deogee
    STOCK
    Until I joined TW, I never torqued anything. :eek:
    I usually torqued stuffed somewhere between not tight enough, and way too tight.
  17. Mar 3, 2023 at 3:56 PM
    #37
    BigCountry762x39
    TL
    PNW, Oregon!
    I don't want to give away secrets but i worked for Honda and Subaru, unless an engine is involved, I'm a master of the impact gun. send it home fast and hard. use to keep one of my impacts on an air line that use to on the first setting set to about 80lbs was awesome for all sorts of wheels and tires.
  18. Mar 3, 2023 at 4:04 PM
    #38
    TnShooter
    Deogee
    STOCK
    If it sounds tight, it must be tight. :notsure:
