Trouble code P0420
Discussion in '1st Gen. Tacomas (1995-2004)' started by el contrador, Oct 25, 2010.
  1. Oct 25, 2010 at 1:54 PM
    el contrador
    el contrador [OP] Member
    André
    Montreal, Quebec, Canada
    03, Tacoma double cab 4wd
    Original a to z
    Hi, I'm new on Tacoma World,
    I own a 2003 Tacoma, Double cab, 3.4L, 4wd and an my check engine light cam on last weekend :( but the truc runs perfectly... :confused:
    the code is P0420
    "Repair information" P0420 - Catalyst System Efficiency Below Threshold (Bank 1)
    Since the Cat and o2 sensors are very expensive I wouldn't want to change the part for nothing.
    Did any body had this code and if so, what did you do to fix it!!??
    thank you
  2. Oct 25, 2010 at 2:41 PM
    stucksucksnayota
    stucksucksnayota Well-Known Member
    Barry
    Fort Smith, Arkansas
    14 Taco 4x4 TRD Sport DCSB
    OEM roof rack, Shorty antenna (eBay), soft tonneau cover, K&N drop in air filter, bed mat, interior LED lights, 5100's, MT tires to come soon!!!
    I have the same code and I'm in the same boat your in. I have heard that it is a O2 sensor and a fuel/air mixture sensor. I have heard that you can buy a generic O2 sensor and just wire it in but sense it is also supposed to be a fuel/air mixture sensor I don't know if you can.
  3. Oct 25, 2010 at 3:50 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    the cat and the o2 sensors would definitly be where to start, if you decide to replace ur o2 sensors you should do both at the same time. the prices at rockauto.com arent to pricey and you get a TW member discount IIRC. get a OEM replacement (denso,bosch). or if ya want you could buy a URD simulator it is meant to turn off the CEL when you get a P0420 code, although its more meant for people who run no cat or a high flow cat.
  4. Nov 27, 2010 at 8:04 AM
    el contrador
    André
    Original a to z
    Hi!!
    I've been reading A LOT on this P0420 problem and found out a few good thing you might like to know!!!
    I lot of people have the same problem that we do, some changed everything related to emission system. Cats, o2 sensors, MAF, MAP, Temperature Sensor and still had the light coming on!!
    On thing that not a lot a people think of checking is the Ethanol rating in the gasoline they use!! Toyota tacoma are set to use Gas with less then 10% ethanol... So what i did is I empty my tank and filled it back with ethanol Free Gasoline, unplug the battery to erase the codes and Guess what, no more light...
    The problem with ethanol is that it doesn't burn like regular gas at all and our O2 sensors do not reconised the exhaust gas so your check engine light turn on!!!
    I was using Gasoline that had 12% Ethanol and didn't know it!!
    Try that and let me know what happens
    Thanks
  5. Nov 27, 2010 at 8:38 AM
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    I had this code and it turned out to be a leak in the exhaust system, I just had to tighten the joint between the cat and the back of the exhaust. That's the first I've heard of ethanol causing the code, unfortunately many people don't have the luxury of choosing non-ethanol gas.
  6. Mar 1, 2011 at 5:19 PM
    stucksucksnayota
    Barry
    I think the gas idea may be along the right track. I used to buy my gas from a station that always had the cheapest gas which I'm guessing is probably because they use more ethanol in the gas.
    My light would come on and I'd get it turned off then it would come on and I'd turn it off. So I seafoamed it and started running gas from a different station with "supposable" better quality gas and my light hasn't come on since. Knock on wood.
  7. Mar 1, 2011 at 8:30 PM
    davestaco
    davestaco TW's number one gear whore
    David
    Schofield Barracks
    00' tacoma xtra cab trd v6 4x4
    I have the same problem and i think i know the fix. Our 1st gens. i bellieve have 2 cats. one at the headers and one down the pipe a little bit. The code is a o2 code but you will never know which cat and o2 is causing it. I was told that you can cut both cats out and put one longer one in its place, then wire up one new o2 censor. any thoughts?
  8. Mar 1, 2011 at 9:12 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    It's almost always the sensors. Do em both at the same time and get denso oem styles. Bosch will not work correctly, I found that out the hard way and still have one laying around somewhere. I've never replaced the front o2 sensor but the rear one is really easy *if* the old sensor isn't rusted into the bung.
    tacomakid96 and 1997tacomav6 like this.
  9. Mar 1, 2011 at 9:22 PM
    dustinclm
    dustinclm Well-Known Member
    Thibodaux, La
    2012 Super White DC 4x4 V6
    Bilstein 5100 set at .85" WeatherTech Floor Mats
    i have the same code, but i also dont have my second cat and my URD simulator should be here by friday so that should fix it. it could also be a leak, for the longest time now i have heard a "puffing" noise on curbs, walls or any obstruction when i pass but can not for the life of me find it. i have checked, check, re checked, brought it to a muffler shop and still cant find the leak...its driving me nuts, it seems i only hear it when im hitting the gas so maybe thats why i cant find it when i look when its idling....
  10. Mar 2, 2011 at 12:50 PM
    Skillet
    Skillet Well-Known Member
    Caleb
    Palmdale,Ca
    99 tacoma prerunner 3.4 auto trans trd,
    Trd edition,black powdercoated wheels,king Coils front, king double bypass rear, k&n cai, jba headers,borla exhuast,optima batt,xenon hid,crystal headlights,rewired entire car to four guage wiring on big stuff alt starter etc.,alpine screen,focal honeycomb components,JL four channel amp,dynamated entire inside of truck and hoodliner,limo tint all rear windows,LEDs everywhere possible dome light, tails,fronts,04 tailights,
    Only factory o2 sensors for me found out the hard way,(don't buy from vato zone ever!) denso should be what you want for sensors.
  11. Mar 2, 2011 at 9:18 PM
    davestaco
    David
    Schofield Barracks
    run some seafoam through the brake booster. i bet you find it then:D
    cruxofthebisquit likes this.
  12. Mar 3, 2011 at 10:35 AM
    dustinclm
    Thibodaux, La
    i did that but i didnt think of looking for the leak and i did it myself, ill get a buddy to help me and norrow down next time i get some time to mess with it
  13. Mar 4, 2011 at 6:47 AM
    el contrador
    André
    Original a to z
    Finally the problem was only an exhaust leak. The flange gasket between the second Cat and the extension, right before the second O2 sensor was finish. I replaced it, erase the codes and voila!! done... the check engine light is off since 2 month now...
    The reason the check engine light goes on with P0420 code is because when you are driving at a constant speed, the flow in exhaust creates a vacuum and pull fresh air from exterior by the hole and falls the o2 sensors reading...
    Verify leaks by blocking muffler and check for very small leaks, specially near o2 sensors!!
    ztwatson and MattMan01 like this.
  14. May 31, 2016 at 11:50 AM
    thumper72
    thumper72 Well-Known Member
    Jon
    Ogden Utah
    2000 toyota tacoma prerunner v6 auto
    5100's, ome dakar leafs and ome coils, problem solver tie rods, eazycompany ditch light brackets and auxbeam osram 4" led pods, 2014 4runner wheels, 265/70/17 goodyear authority tires, soon to have 50" led bar on roof
    Well went to AutoZone and found out I have a code (po420) he said I have possible bad gas or a hole in my cat! Recommended fuel injector cleaner and a octane booster? I m thinking gas as I just filled up 50 miles ago from almost empty....
  15. May 31, 2016 at 12:11 PM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    if you have 130,000 mile or more and it's the OEM sensor, it's likely the sensor itself that crapped out
    they do wear out
  16. May 31, 2016 at 12:30 PM
    thumper72
    Jon
    Ogden Utah
    I'll look into it lol I have 230k lol how would you tell.if OEM or not clipped wires?
  17. Mar 22, 2017 at 6:24 AM
    truckyouup
    truckyouup New Member
    2004 Tacoma TRD
    Hello 1st Gen lovers,
    Wanted to pass on what work for me in fixing my P0420 CEL.
    2004 TRD with 165k on the clock.
    Truck runs great and was getting slightly better fuel mileage with the CEL on.
    Replaced upstream sensor, no change.
    Replaced downstream sensor, no change.
    Took it to the garage, they changed the mass air sensor in the intake. Worked for a week.
    Took it back to the garage they couldn't find anything and suggested new CATs.
    Made a shield for the downstream sensor, trying to imitate the spacer other people use to fool the sensor. no change
    Let the truck sit over night. Had a friend plugged the exhaust outlet with his hand, started the truck and found 2 leaks. Since the truck was cold the leaks were easy to find since they dripped water (condensation). One leak was between the upstream and downstream sensor. Used some exhaust putty to plug leaks. Problem solved!
    Thank you davestaco for the suggestion of looking for leaks, wish i would've tried that first..
    UPDATE,
    After a couple of months the Damn P0420 code came back. Found another pin hole in the exhaust between the 2 cats. patched it and code still came back. Truck was hesitating at full throttle, and through a misfire code. Check the spark plugs, all the electrodes were down to little points (ashamed I let them get that bad). Replaced spark plugs and the p0420 hasn't returned. And it runs great. Fingers crossed...
    prerunnerSD likes this.
  18. Jan 29, 2020 at 7:04 PM
    03taco
    03taco Well-Known Member
    Alex
    2004 Taco
    Never Ending Project
    It's the upstream correct
  19. Aug 26, 2020 at 2:08 PM
    uaflyer
    uaflyer Active Member
    Ken
    2006 Tacoma Base 2.7L 4Cyl
    front mud flaps, seat cover
    It's the upstream. It's the more expensive O2 sensor and they are connector key specific.
    I remember by looking at the connector notches. 1-2-3.
    The downstream has a different combination and is dirt cheap.
  20. Aug 26, 2020 at 2:14 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    @uaflyer
    Welcome aboard new member
    You might want to check the posts date stamp. :confused: 8 month old post.:D
    And the upstream is an Air/Fuel sensor for that year Taco.
