Trouble balancing new BFG TA/KOs
Discussion in 'Wheels & Tires' started by crazybayman, Apr 26, 2010.
  1. Apr 26, 2010 at 6:20 PM
    crazybayman
    crazybayman [OP] Oh 'eah
    Newfoundland
    09 4x4 4.0L V6 Access Cab Standard
    AutoStart, Sirius Satellite Radio, 16x8 Moto Metal 955s, 265/75/16 Duratracs, Fog Lights, Skid plate
    Just bought a brand new set of 265/75/R16s from Costco, and brought them to be installed at Andy's, my usual walk-in tire/oil change garage (there was a 2-week wait at Costco).
    The guys at Andy's were not able to balance one of them, and therefore thought that the rim was bent. As well, they had to add an unusually high amount of weight to balance the others. I brought it to Toyota and got them to check it, and they informed me that the rim was fine. However they did confirm that they too could not balance the wheel, and noted that the amount of weight used to balance the others was excessive. They said that it must be the tires.
    My question: has anyone seen this situation before, where there were issues balancing a set of brand new tires? Is it possible that the tires are defective and not balanced properly? (especially where they're BFGs)
    Any input would be appreciated.
  2. Apr 26, 2010 at 7:03 PM
    bb609
    bb609 O.F.
    NH
    '09 TRD Sport Access Cab
    FOX 2 1/2" CO's STOCK UCA's - They used to be Icons! Icons suck!!! TSB Rear w/Bilstein 5100's - Air Lift System - Leer 550 Bedcover - Ventshades - Yota Bed Mat - Sheepskins!!! - Weathertechs
    Possible a tire is out of round? Read the below:
    http://www.gadgetonline.com/Vibration.htm
    A Hunter machine will either balance the tire or let you know if the tire is out of round. Surprised the Toyota dealer doesn't have one...or did they? If so, they should know enough to use the adapter too but I've read otherwise on here. Good luck!
  3. Apr 28, 2010 at 6:58 PM
    rahoovie
    rahoovie Member
    David
    AL
    03 tacoma prerunner
    I had the same trouble with brand new AT2s same size. Wonder why :confused:
  4. Apr 29, 2010 at 4:13 AM
    crazybayman
    Newfoundland
    Thanks. There are a few dealers with this machine in my area, I'll check it out. Only thing is, its the Volkswagon, Honda, Nissan, and Chevrolet dealerships that have them! A Canadian Tire in the area has one, maybe I'll go there.
    I brought them back to Costco, and they tried balancing them there. No dice. So they tried balancing another brand new BFG TA/KO on that rim, still couldn't get it to balance. They too, noted that there was an unusually high amount of weight used to balance others. Luckily, because I couldn't balance them, Costco refunded me the cost of the tires, even though I have been driving on them for almost a week.
    So they (Costco) tried balancing my old all seasons (the ones that came stock) and had no trouble, as very little weight was required to balance. So in the interim, I'm using those. Which is great, but now I'm spoiled to look of the aggressive, bigger tire!
    The manager there figured that even though the rim was within spec (Toyota's same words), there was a slight bend in the rim, and that perhaps a heavier tire like the BFG TA/KO 10 ply was just amplifying the imbalance.
    So now I might just wait to get alloy wheels. Although, perhaps the Haweka suggested by bb609 would help. Either way, I"ll probably just get Toyota to look into it. I do have to put her in soon to get a slave cylinder for the clutch, anyways. Maybe I"ll get them to try installing new tires.
    Man, what a racket!
  5. Apr 29, 2010 at 11:44 AM
    gtmiller1001
    gtmiller1001 Well-Known Member
    Greg
    Houston, TX
    06 Double Cab TRD Sport V6
    BHLM, Painted Stock 17" sport rims black, 3" Toytec coil overs with 5100's, AAL, black bull bar, TRD filter, parrot bluetooth, anytime foglights, debadged, removed mud flaps, added bed lights, grillcraft, Wet Okole's, Weather Tech's.....and traded in for a Tundra
    i had the same problem with a Duratrac 285/70/17.
    Tire had lateral runout and could not be balanced. Sears confirmed this and replaced the tire, no charge.
  6. Apr 29, 2010 at 12:21 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Have them spin & balance the tire. THen - have them rotate that same wheel/tire 180 degrees on the machine and spin them again. This will further 'fine tune' the first balance.
  7. Apr 29, 2010 at 12:26 PM
    NewMexiTaco
    NewMexiTaco Abron Cabron
    Abraham
    Santa Fe, NM
    2007 4x4 DC LB TRD Sport
    Weathertech mats; Wet Okole seat covers; Kobalt Lowpro truck box,(sitting in the shed) Snugtop Hi-liner camper shell; AFE Pro Dry air filter, Tailgate Hoseclamp mod; 5100s all around, Light Racing UCAs, OME 885 coils, OME Dakar Leafs, CB Drop, Driveline spacer. Epoxy Satoshi; Redline Hood Struts. 4x Mil Spec. bed D rings; Brute Force Fab custom DCLB Hybrid Sliders, ARB w/ Warn M8000 wench, Diff Breather mod, Alpine Deck w/ ipod cable. Iphone ziptie to rearview mirror 4wd-cam mod!
    Pita !!!! :[
  8. Apr 29, 2010 at 12:31 PM
    jusmac
    jusmac Well-Known Member
    tacoma's need to be "hubcentric" balanced, other wise you will always have a vibration. which mean they have to get them completely hub centric on the machine before they balance them. aftermarket wheels usually come with the hub centric mounting tool, but stock rims will be alot harder to get right.
  9. Apr 29, 2010 at 2:55 PM
    lakewoodbilly
    lakewoodbilly Well-Known Member
    Bill
    Lakewood, CO
    White 08 DC V6 SR5 4WD TRD Sport
    Factory DRL's, Underhood Flood LED's, Underbody Multi-color LEDS, Red Line Tuning Elite Hood Struts, Anytime Fog Lights, PIAA 4100 Intense White, Luminics JDM Yellow H10 Fog Lights, OBX Sport Pedals, Sill Protectors, Bed Net, Front Bed Tie Downs, iPod and Aux Factory HU Interface, Sirius Sportster 5, Satellite Antenna through third brake light
    I'm just about ready to buy new tires for '08 sport.
    I had BFG's on my last two trucks (both pre tacoma Toy 4x4's '86 and '91) and I always had a hard time getting them and keeping them balanced. Given their added weight and dimensions, I believe that is mostly why along with my cheep rims. I still loved the tires and just considered the out-of balance situation a minor nuisance as I still would get 55-60K out of each set.
    Now that they are 200+ each for my new size for the sport 17" wheels, I'm wondering if I can do that.
    So I am considering just buying 3 new dueler H/T's to match the spare that is new and drive on those for another 40K before I need to decide again.
    PS I was formarly apexbill - I'm back on Tacoma World as lakewoodbilly after a fairly long absence from moving and divorce and other stressful life events.
  10. May 14, 2010 at 9:00 AM
    crazybayman
    Newfoundland
    So to revive this thread....
    I've got moto metal 16x8's ordered, as well as Duratrac 265/76/16's. According to the website, the moto metals are not hubcentric. Will I have an issue with vibrations or anything else on my Tacoma because the rims are not hubcentric?
  11. May 14, 2010 at 9:45 AM
    bb609
    bb609 O.F.
    NH
    No. Most (all?) aftermarkets are lug centric.
  12. May 14, 2010 at 10:36 AM
    crazybayman
    Newfoundland
    Thanks, that gives me peace of mind. So as long as the wheel balances (whether its hub centric or lug centric), there should be no problem?
  13. May 15, 2010 at 6:24 PM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    Wow...guess I was lucky then. Just got new LT265-75/16 Dakota A/T's and they balanced perfect
  14. Jan 5, 2011 at 8:01 PM
    scott572011
    scott572011 Well-Known Member
    SCOTT
    SO-CAL.
    THE RELENTLESS PRUIST....
    BF GOODRICH T/A ko, BILSTEIN HDs, AMERICAN RACING RAZOR`S 16X7.5, READYLIFT SST HYBRID LIFT SYSTEMS, ALTEC LANSING AUDIO,DREGS OF THE EARTH SYSTEMS,WOLF EYES,SUREFIRE ILLUMINATION TOOLS,HK-PROTECTION!!. POP LOCK, SHORTY ANTENNA, TACO TENT #3,. NITECORE ILLUMINATION, FENIX FLASHLITES. STILL PROTECTOR`S, FACTORY BED MAT, CUSTOM BED WEB, INTRO-TECH INTRO-GUARD CUSTOM TRUCK COVER, CENTER CONSOLE LOCK MOD, TECH-SHADE M1068, WEATHER-TECH CLEAR-COVER`S, OEM MINI TIE-DOWNS, TRUCK BEDZ AIR MATTRESS EXPEDITION SERIES, McGARD TOUGH NUTS WHEEL LOCK`S, DISABLE SEAT/BELT CHIME MOD, GARMIN GPS, KERSHAW BLADE`S, SKELETOOL, WEATHER-TECH FLOORLINER DIGITAL-FIT GRAY # 461781, NITE(IZE) KNOT-BONE ADJUSTABLE BUNGEE SYSTEM, WET OKole SEAT COVERS, UNDER DASH FLYZEYE BW LED LIGHT W/CUSTOM BLUE HALOS. NITECORE IFE1 INFILUX ILLUMINATION SYSTEM. JETBEAM BC-10 HANDHELD, HK VP-70Z 9mm PROTECTION!. JETBEAM PC-10 550 LUMEN ILLUMINATION SYSTEM. SUREFIRE E2D-LED-DEFENDER ULTRA 500 LUMENS KICK ASS ILLUMINATION...VIPER ALARM SYSTEM`S,ROCKFORD FOSGATE POWER COMPONENT SYSTEM`S.KENWOOD AUDIO/VIDEO,HUSHMAT SOUND DEADENING INSULATION,3M AUTOMOTIVE FILMS.
    AFTER NUMEROUS ATTEMPTS !! HAD TO KEEP TURNING THE WHEEL AND TIRE GUESS THEY BOTH HAVE GOOD AND BAD AREAS! NOW RIDE IS THE KIND!!.;)
  15. Jan 5, 2011 at 8:11 PM
    Archangel
    Archangel Special Assistant to the Regional Manager
    Charlotte, NC
    '04 T4R SR5 4x4
    You know there's lowerecase letters on the keyboard too, right? Just Kidding. Sounts like the tires are out of round. On a side note, wheels are coned on the balancer most of the time. The Kaweka spacer only works if the aftermarket wheel is perfectly centered on the spacer. You're better off still coning the wheel on the outside of the wheel to center it better. Hope this information helps.
  16. Jan 5, 2011 at 11:32 PM
    scott572011
    SCOTT
    SO-CAL.
    after rotating the tire on the rim 180 it balanced just fine no vibratition at any speed:rolleyes:
  17. Jan 14, 2011 at 11:24 PM
    mexitaco
    mexitaco New Member
    sam
    Chula Vista, California
    08 prerunner off road pakage
    Pro Comp level kit
    just wondering How much did you pay for your BFG's at Costco?
  18. Jan 15, 2011 at 9:34 AM
    Blkturbo!
    Blkturbo! Well-Known Member
    Sean
    Henderson, NV
    08 Tacoma; 05 Seadoo RXP; 94 Turbo Supra
    Icon Coilovers, Downsouth UCAs, rear Icon "2.5" shocks and Toytec single AAL. Still gotta do exhaust, dark headlights and re-gear the rear diff.
    I'll be buying new wheels and tires soon. Im planning on the 17in XD Hoss and either the KM2s or these BFG ATs.
    I wish I knew what your post meant :D
    Kaweka spacer? coning the wheel???
    What all do I need to know about this when i have a shop mount and balance?
    Also, how do you guys know that the tire shop monkeys are gonna even do any of this extra effort mentioned here in this thread?
  19. Jan 15, 2011 at 10:34 AM
    bb609
    bb609 O.F.
    NH
    Some good reading for you...
    http://www.gsp9700.com/
  20. Jan 16, 2011 at 6:55 AM
    crazybayman
    Newfoundland
    I think it was $900 or $1000, in that ball park. That's in Canada though, and you'll probably find them quite a bit cheaper in the US.
