Trigger/Raxiom 2100 Wireless Accessory Controller 4-Switch Relay System, 1 Pack
Discussion in 'Buy / Sell / Trade - Other' started by 88JayPizzle, Jul 10, 2022.
  1. Jul 10, 2022 at 9:16 PM
    88JayPizzle
    88JayPizzle [OP] Well-Known Member
    150 . with free shipping
    These are 250 brand new (see link below)
    https://www.amazon.com/Trigger-2100-Wireless-Accessory-
    https://www.youtube.com/watch?v=2hA08tCimUk
    100% functional. Took it off my jeep before selling it.
    Look's like mine is the 1gen (Raxiom) branded 4 way switch. But it connects as trigger on the Blue tooth app on the phone. Please E-mail me for any questions. This switch retails for over 200+ brand new.
    It also comes with the over head mounting bracket
    (TRIGGER 4 PLUS Jeep JK Overhead Remote Mount)
    Description
    TRIGGER 4 PLUS Wireless Accessory Controller
    The Trigger 4 Plus Wireless Accessory Controller substantially saves installation time of your electronic accessories! Eliminate the need to run wires under the dash or through the firewall of your vehicle when wiring accessories. Includes an RF remote control for wirelessly activating installed accessories from inside or outside the vehicle. In addition, fused circuits with LED indicators notify you of active circuits or blown fuses.
    The included battery-powered RF remote utilizes a universal mounting system that will accommodate round surfaces as well as flat surfaces. There is an ambient back-light (illuminating the space around the switches momentarily) and it can be re-programmed for security or use with additional remotes; Several Trigger 4 Plus Wireless Accessory Controllers can be used together to control up to 24 accessories. When mounted to a UTV roll bar, the buttons on the remote are more easily accessible than dash switches. There is no straining against seat belts to reach the dash, just a quick reach up to flip a switch on the remote.
    We get asked this a lot, so…Please do not swap higher capacity fuses into lower capacity circuits. Each circuit is engineered to handle only the stated load, and doing so will damage the Trigger and void its warranty.
    Extend Control With The Trigger ACS Plus app for iOS and Android Devices!
    The Bluetooth App will control on/off and dimming functions as well as flashing when used with LED or conventional lighting. Of course, it’s quick and easy to set up and allows for extended control and user customization. Set switch functionality to either standard rocker or momentary, edit individual accessory names, and monitor vehicle battery voltage when using our VOLT Bluetooth Battery Monitor.
    Use the app to “Trigger” lights from outside the vehicle whenever you might need to activate an accessory on demand.
    Save time, simplify your installs, and get out on the trail: Pull The TRIGGER!
    A few additional features:
    • Accepts 12-24 Volt input
    • Two 10 amp fused circuits w/12-24 Volt output
    • Two 30 amp fused circuits w/12-24 Volt output
    • Includes 4 wire harnesses with waterproof connectors: two 10 gauge and two 12 gauge
    • Wireless Battery Operated RF remote switch module with ambient backlight
    • You can control it from your mobile device with our free TRIGGER ACS PLUS App for iOS/Android!
