Tried to start engine with it already started.
Discussion in '4 Cylinder' started by 01tacoprerunner, Mar 5, 2010.
  1. Mar 5, 2010 at 7:02 PM
    01tacoprerunner
    01tacoprerunner [OP] 01 4WD Prerunner
    Brian
    Raleigh, NC
    01 4WD Prerunner
    Ok so tonight i was sitting in a parking lot waiting on my friend cause he got pulled over and i had turned my headlights off and so i see him go by. I had forgot my truck was already started and i turned the key and the truck went off. So i started it back up and everything seemed good.
    Does anyone know if i could have messed anything up?? Im just checking cause i dont want to mess up my truck.
  2. Mar 5, 2010 at 7:04 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    my sister did it in my dads surbaban like 10 years ago, its been fine ever since, it just made a bad noise when she did it.
  3. Mar 5, 2010 at 7:06 PM
    SoutheastTaco
    SoutheastTaco Resident Jackass
    steven
    columbia sc
    09 trd sport dc 4x4
    rear spring tsb, 255/75/17 bfg muds
    its the starter gear against the flywheel. don't make a habit of that. you should be fine.
  4. Mar 5, 2010 at 7:15 PM
    01tacoprerunner
    Brian
    Raleigh, NC
    01 4WD Prerunner
    Ok thanks guys. When i did it i was really surprised that it went off. Like it cut the motor off. I have done it on a mower before and it makes the most aweful noise.
  5. Mar 5, 2010 at 7:16 PM
    vicstacoma
    vicstacoma Guest
    yeah many people do this specially in cars that don't make that much noise. Yeah your flywheel was spinning since your truck was on and once u turned your key to the on position the starter gear teeth rubbed against the spinning teeth of the flywheel. You'll be fine, the only thing that will cause some damage is if you would hold it for a long time then you'd damage ur starter or flywheel.
  6. Mar 5, 2010 at 7:33 PM
    travelingman
    travelingman What would Scooby do?
    Brian
    Ohio
    07lb4x4DC
    ticking eng.mo,ventvisors,locking tailgate,wheelmasters ss spare tire inflation line,weathertech mats
    Why the Ford hatin' dude? I've put 181000 on my F250 without a problem. I haven't had a Toyota long enough to prove shit.
  7. Mar 5, 2010 at 7:36 PM
    01tacoprerunner
    Brian
    Raleigh, NC
    01 4WD Prerunner
    Toyotas last forever. My brothers 96 has 320,000 on it. Not any big problems with it either.
    Fords are Shit. My dad has a F350 and it has broken down 3 times in the past year. And its not like little shit, its been $2000-$3000 fixes each time.
    Edit: It only had 116,000 miles on it.
  8. Mar 6, 2010 at 9:58 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    It's fine, don't worry. Potential damages that can be caused by "the human factor" are usually considered during the engineering process and safeguards are integrated into the systems of most modern cars (e.g. throwing the AT into park at speed will not lock the axle; tire-pressure monitoring systems, etc). Just try not to do it again.
  9. Mar 6, 2010 at 10:01 AM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    You should be fine. People accidentally do it all the time. Worst case scenario, you could have chipped a tooth on the flywheel or starter. In an extreme situation you could be replacing either or the two, or both, but this is very unlikely.
  10. Mar 6, 2010 at 10:04 AM
    schiz94
    schiz94 Thread Jacker
    Caleb
    Bellingham,WA
    08 Tacoma Reg Cab
    Morimoto Projector Retrofit, alpine cda-105,Wheelskins leather wheel cover, wet okoles,5% tint on back and 24% on front two windows,Debadged tailgate,custom sockmonkey centercap decals, xr rims pced gloss black.
    it makes a grinding noise, dont do it alot or you could break something
  11. Mar 6, 2010 at 8:01 PM
    sweater914
    sweater914 Well-Known Member
    North Dakota
    '09 I4 5spd Access Cab Timberland Mica SR5
    I once had a neighbor who happened to be blond do this at least once a month to a Volvo wagon. Makes a nasty noise when the starter gear tries to engage the ring gear on the flywheel, somehow that Volvo just put up with the abuse. C cups tend to compensate for a lot of other short comings.:D
  12. Mar 7, 2010 at 4:55 PM
    Raven65
    Raven65 Well-Known Member
    Camden, SC
    '09 Magnetic Gray Reg Cab 5-Lug
    Curt hitch, D-rings, bed mat
    The OP said nothing about hearing any grinding noise (which is what usually happens when you do this) - but said (twice) that his truck "went off". I take that to mean that the engine stopped running and then he had to restart it.
    Does the computer on these trucks shut the engine down if you try to start it when it's already running to protect the starter & flywheel teeth? Just a guess... I'm not testing that theory on MY truck. LOL
  13. Apr 5, 2010 at 10:47 PM
    Drewboto
    Drewboto Well-Known Member
    Drew
    Missouri
    Base model ಠ_à²
    (Former Tacoma owner) 17" Mustang wheels, Eclipse AVN 5435, Deck plate mod, vertical Maglite mount, K&N high-flow air filter, Delta gullwing box, amp, sub, 30 percent tint, floor lighting, tilt activated glove box lighting, lighting behind seat, engine bay lighting, SR5 grill surround, power windows, outside temp display
    I've seen somebody grind a starter about about 6 seconds without the car having any issues. You should be fine
  14. Apr 5, 2010 at 10:51 PM
    I Liquid I
    I Liquid I Well-Known Member
    Puerto Rico
    06 BSP DCLB, 17 Inferno TRD Offroad DCSB, 06 SW ACLB
    Too many mods to list
    ... and that's what grinds my gears!
    But no, you should be fine, ive done it once or twice cause I was used to my Liberty which was so much louder.
  15. Jan 11, 2011 at 4:03 AM
    timmo
    timmo Well-Known Member
    Tim
    OKC
    2010 doble cab 4wd sr5-silver
    my '10 engine manual says there is a feature that's supposed to disengage the starter if the engine is running but i tried to crank it deliberately and it engaged...ground those gears...and the engine cut out. maybe that's how this crank hold function works?
  16. Jan 13, 2011 at 9:26 PM
    norcal4banger
    norcal4banger 11-98 MUD
    Jack
    Far Northern California
    2005 4 Cylinder 2WD 5 Lug RC Tacoma
    Word. 97 F250 with 200k. Runs beautifully
  17. Jan 13, 2011 at 9:29 PM
    yamaha73
    yamaha73 Well-Known Member
    Royce
    Madera ranchos
    1997 4runner, 1980 Toyota pickup
    4Runner- wagoneer Dana 44 front lunchbox locker. Rear stock axle spooled. Beadlocks and 36s 3link rear, leaf front, dual transfer cases 1980 pickup- exo cage. Locked front and rear on 40s dual transfer cases. Custom paint job
    yea i did it last night on accident also, my engine just shut off and i restarted it and no problem, wen i did it in my old chevy it made a horrible noise, and same in an old ford i had
  18. Jan 13, 2011 at 9:33 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    x2:D
  19. Jan 13, 2011 at 9:41 PM
    Sigi
    Sigi Well-Known Member
    Sigi
    Sfv ca
    06 tacoma 4x4 trd offroad
    your truck will be fine.. I have done it plenty of times on many of my cars and none of them ever broke down or nothing bad ever happened..
  20. Jan 13, 2011 at 9:46 PM
    tanzak88
    tanzak88 Well-Known Member
    Here's an easy way to prevent that from happening again.
    Dual Flowmaster.
