Trick to remove leaf spring bushings...
Discussion in '1st Gen. Tacomas (1995-2004)' started by Stutely, May 16, 2017.
  1. May 16, 2017 at 10:56 AM
    Stutely
    Stutely [OP] Well-Known Member
    Jonathan
    Central IL
    99 Xtra/3.4/5 speed/SR5/TRD/4x4 Burgundy "Ron"
    I discovered this attempting to drill out my old rubber leaf spring bushings on my 99 Tacoma. I've got new ones waiting for me to weld the brackets back on, so I didn't care about damaging the old ones.
    ready6delta, Beee1985 and tan4x4 like this.
  2. May 16, 2017 at 12:59 PM
    col. sandurz
    col. sandurz Well-Known Member
    same thing happened to me when I did mine. I still ended up having to burn them out, much to the horror of everyone else in the shop at the time.
    ThunderOne and Stutely[OP] like this.
  3. May 16, 2017 at 3:05 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    By far the only way the ever worked is the Oxy-Fuel torch for me.
    Still waiting for some super slick way to have them pop right out
  4. May 16, 2017 at 3:21 PM
    Stutely
    Jonathan
    Central IL
    I thought about torching it, but the smell from cutting the bolts (which were fused to the bushings) was bad enough I decided to try and drill them out, and in the process the drill bit kept slipping in between the spring and the bushing. I was prepared for a huge battle with the damned thing, but then they just started coming out. I've had enough battles repairing this truck's frame so it was great to have it go easy. Figured I'd film the second one and pass it on...
  5. May 16, 2017 at 3:27 PM
    Cable
    Cable Well-Known Member
    California
    2017 TRD Off Road 4x4 Quicksand
    Doesn't that score the crap out of the inside of the bushing channel?
  6. May 16, 2017 at 3:57 PM
    Stutely
    Jonathan
    Central IL
    I didn't notice any scoring. If there are some scuffs I can smoothe them out with a file.
  7. May 17, 2017 at 3:04 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Thats awesome. Thanx for sharing. :D
  8. May 17, 2017 at 3:31 PM
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    From my experience if this trick worked for you you were incredibly lucky.
  9. May 18, 2017 at 2:43 PM
    Stutely
    Jonathan
    Central IL
    Worked for both sides, so 2 for 2. I'm not doing the rear bushings just yet, so we'll see.
