TRDpro Suspension Noise
Discussion in '3rd Gen. Tacomas (2016-2023)' started by brettt07, Nov 10, 2021.
  1. Nov 10, 2021 at 5:39 AM
    brettt07
    brettt07 [OP] New Member
    2021 Lunar Rock TRD Pro
    OVTune; LED interior lights; LEDGlow puddle lights, footwell lights, and additional truck bed lights; BakFlip cover; lunar rock steering wheel chrome out; Lunar rock colored Tacoma glove box lettering; automatic truck bed lock; TRD red push button start; truck bed mat; tufskinz door sill protectors
    I have a 2021 TRD Pro. I’ve noticed noise that sounds like something is loose and squeaks, especially at low speeds, with the radio off, and when going over small bumps. It’s driving me nuts. Initially, I thought it was coming from the rear, but I think it’s from the front. Any ideas on whether it is normal or not. I appreciate any help. Thanks!
  2. Nov 10, 2021 at 5:53 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Can't diagnose something like this over the Internet. 2021 is still under warranty? Take it to a dealer. Ask for a ridealong with the technician so you can tell him when the noise occurs.
    DWD484 and JoeCOVA like this.
  3. Nov 10, 2021 at 7:07 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Front body mount, spare tire swinging around, leaf springs rubbing, could be a ton of things.
    But really as 3joh22a said, we are not going to be able to diagnose this very easy.
  4. Nov 10, 2021 at 7:09 AM
    Grindstone
    Grindstone Requires Adult Supervision
    Tacoma leaf springs are notoriously squeaky. I get a small squeak out of my stock Pro rear springs occasionally. Same with my old '13 Sport.
  5. Nov 10, 2021 at 7:51 AM
    brettt07
    I understand it’s tough to diagnose over the internet. Just thought there may be a known common issue. Thanks everyone for helping. I appreciate it
  6. Nov 10, 2021 at 7:55 AM
    Mikro
    Mikro Well-Known Member
    2020 MGM TRD Pro
    Check your spare tire. I had a squeak going over any size bumps. I thought it was leaf springs until I kicked the spare and it made the same noise. All I had to do was drop the spare a bit and tighten it back up and the noise went away.
    skeletron and xerogs1 like this.
  7. Nov 10, 2021 at 7:56 AM
    brian2sun
    brian2sun Well-Known Member
    California
    ‘21 TRD OR DCSB ‘17 4Runner Limited ‘97 4Runner SR5
    Coilovers notoriously get squeaky over time, whether they’re Fox, King, Elka, Toytec, etc... My guess is that’s what you’re hearing.
  8. Nov 11, 2021 at 1:42 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    My Son and I chased a squeaky leaf spring, drove it over bumps, rocked the truck up and down and never could get a noise unless you were driving it. Then turning into the driveway we heard it. After 30 minutes of checking it all out, we found the factory tonneau cover bolt was way loose. Tightened it up and solve the issue. Just saying it was a simple fix, thankfully it was minor. It sure as heck sounded like suspension.
  9. Nov 11, 2021 at 2:03 AM
    LarryDangerfield
    LarryDangerfield One Larry a day keeps the money away ™ Moderator
    Tyler
    Northern Wisconsin
    Black 2020 Nightshade Edition 4Runner
    Oh there will be some mods all right
    There has been a fair amount of people who have had the TRD pro skid plate be the cause of their front end sounds. I believe the remedy was rubber spacers/washers once as well as just making sure all the bolts were tight.
    https://www.tacomaworld.com/threads...y-2020-sport-fixed-was-trd-skid-plate.675562/
    ktbell444 likes this.
  10. Nov 11, 2021 at 6:16 AM
    jcphillips
    jcphillips Active Member
    Had a similar problem on mine ('21 picked up in January); I believe that the dealer replaced the motor mounts. I'll have to go back and read what they fixed. It ended up coming back...but not as bad. I also did quite a bit of off-roading up in the high country (Colorado) and flexed the suspension a bit - this seemed to help.
    And for comparison, the '18 Off-Road that I had never had this issue.
  11. Nov 11, 2021 at 6:22 AM
    xerogs1
    xerogs1 Well-Known Member
    New Mexico
    2019 TRD OR DCSB AT Silver Sky Metallic
    Bartact Seat Covers, Cali Raised LED molle bed system, radio knobs and Subaru Tweeters, OCD interior parts, OEM Exhaust tip, dash cam, hood protector, various theft deterrent items. Still a WIP
    Yeah I had the same thing. When I installed the spare tire lock I didn't tighten my spare enough and it squeaked over bumps and really sounded like leaf springs. Once it was really tight and I stowed the chain so it didn't rattle all those noises went away.
  12. Nov 11, 2021 at 6:30 AM
    Xtremsiege2
    Xtremsiege2 Well-Known Member
    Norwalk CT
    21' LR Pro. Lots of fast bikes
    No noises here 21 pro. But only 3400 miles. Bring to dealer or wait for the scheduled service as mentioned..
    Having grown up with no warranties and breaking down every so often, same mindset as you. Now when paying for something, worthwhile to use otherwise buy used(just not now in this market, buy new lol)
  13. Nov 11, 2021 at 6:34 AM
    BurtMacklin
    BurtMacklin Well-Known Member
    Andy
    21 Pro - AT
    Is it a soft creaking/thumping noise, that only can only heard when going over small bumps at 3-10mph? Or is it more of a higher pitched squeak?
  14. Nov 11, 2021 at 8:07 AM
    CSVT
    CSVT Well-Known Member
    Ohio
    2021 TRD Pro
    I dont have any noises on my 21' Pro. Its under warranty, see if you can track down the noise and have the dealer take a look. I fully expect squeaks and creaks over time, but not this early in the game.
