TRD Valve Caps
Discussion in '3rd Gen. Tacomas (2016-2023)' started by RZRob, Feb 11, 2017.
  1. Feb 11, 2017 at 4:30 PM
    RZRob
    RZRob [OP] Well-Known Member
    Robert
    Anaheim Hills
    Jaggerbub likes this.
  2. Feb 11, 2017 at 4:38 PM
    DarthMinnow
    DarthMinnow Well-Known Member
    '16 Tacoma TRD Sport 4x4 AT
    I rather put lock tight on my valve stems. First review on Amazon reads:
    "These started rusting on the inside after a snow storm that left salt on the roads. I thought I would just put the old ones back on but found out that the rust ruined my tire pressure sensor and it cost me $84.88 to fix. Do not put these on your tires unless you live in the desert."
    06Tacooo and shakerhood like this.
  3. Feb 11, 2017 at 4:47 PM
    RZRob
    Robert
    Anaheim Hills
    Buzz kill. I'm not too worried, but I'll monitor.
    RZ Rob
    bobrown14 likes this.
  4. Feb 11, 2017 at 4:50 PM
    DarthMinnow
  5. Feb 12, 2017 at 9:18 AM
    bobrown14
    bobrown14 Well-Known Member
    Bob
    Philadelphia
    Gen 3
    bunch of stuff - Bro Pro style
    Let me know when you see any problems ... I've had em on my truck for over a year now.. live where its grey and salty roads.... so far they are painted CHROME.. so no problem.
    The only worry for me is kids in the summertime riding bikes and "upgrading" the bike ... gotta start somewhere I get it... been there.
  6. Feb 12, 2017 at 9:46 AM
    Jaggerbub
    Jaggerbub Well-Known Member
    Tom
    Diamond Bar 91765
    2017 DCLB OR 4X4
    Been hearing about tpms sensors going bad because of these caps. I've been eyeing those too. Lol Looks great on your wheels!
  7. Feb 12, 2017 at 11:47 AM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    I had a spare on my 206 Taco that the dealer put a steel cap on after checking the pressure.... 1 yr later, the TPMS showed a low tire.... it was that spare... the steel ate the aluminum valve stem...nothing salvageable.... DO not mix these metals...use plastic or aluminum..
  8. Feb 12, 2017 at 11:51 AM
    Broccoli
    Broccoli Well-Known Member
    Airdrie Alberta
    2016 trd sport blazing blue,
    Disimilar metals will always rust... nuff said.
  9. Feb 12, 2017 at 12:02 PM
    Jpuch
    Jpuch Active Member
    2017 Tacoma TRD OR
    None yet
    Just a heads up. I put some cool metal caps on my old truck. After a winter exposed to road salt and that liquid crap they spray on the roads, they became welded to my valve stems. I broke off two stems in my driveway trying to get them off. :annoyed: I wash my vehicles once a week at a minimum and it didn't seem to help.
  10. Feb 12, 2017 at 12:42 PM
    JS760
    JS760 Well-Known Member
    San Diego
    2017 DC Sport
    Can't believe you pair 8.99 plus tax for that
    RZRob[OP] likes this.
  11. Feb 12, 2017 at 2:04 PM
    GPsevinSixx
    GPsevinSixx Well-Known Member
    Ros Angerus
    2015twoAX2.4techPAWS
    6112/5160AALfnCNTSTRyokG015
    I believe it's galvanic corrosion. OP, just put a little petroleum based lube on the threads, not thread locker. It will be fine if you check your pressures regularly. Keep it away from the valve core is all.
    Light coating of anti seize works also. I put this between the brake rotors/ drums and the rim contact surface. No issues.
    over60 likes this.
  12. Feb 13, 2017 at 10:22 AM
    RZRob
    Robert
    Anaheim Hills
    Actually I recalled paying $5 three months ago when I ordered them. Bottom line is they were the cheapest thing I ever bought for my truck. I was trying to be funny with the post (the fact I'd even mention them), but now you guys got me paranoid. I think I'll take them back off. How about the King shocks? Do those need to go too?
    RZ Rob
  13. Feb 17, 2017 at 11:14 AM
    facefirst
    facefirst Well-Known Member
    Geoff
    Cleveland, OH
    2017 MGM TRD Off Road DCSB
    I bought some too a month ago. Checked on them today. Yep, already rusting at the set screw. Valve stem threads look fine, luckily. Took them off immediately and put the plastic ones back on. They look neat but they're 100% pieces of shit. I'd rather have "boring" valve caps than ones that rust themselves to the valve stems. Went ahead and set up a return on Amazon.
  14. Feb 17, 2017 at 11:31 AM
    RZRob
    Robert
    Anaheim Hills
    Okay, looks like I made a bad investment. Fong Ho did me wrong.
    RZ Rob
    TXtacoTRDOR likes this.
  15. Dec 15, 2018 at 2:06 AM
    pepecorote
    pepecorote Member
    Jose
    2016Tacoma
    Even though this is an old thread Amazon has these in carbon fiber which shouldn’t cause corrosion problems
  16. Dec 15, 2018 at 2:38 AM
    06Tacooo
    06Tacooo Earth Czar
    Mark
    39° 14' N / 83° 13' W
    06 Off Road Access Cab Indigo Ink Pearl
    Michelin Defender LTX M/S2, ABS kill switch, Tech Deck, Mirror riser, Ride-Rites, BF Garmin GPS
    A set screw tightened down against the threaded TPMS valve stem is not a good idea.
    Plus it's a PIA every time you adjust tire pressure. For me, that's every few weeks, since the temperature changes, and I haul heavy chit from time to time.
