TRD supercharger gains?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by heliman79, Feb 21, 2015.
  1. Feb 21, 2015 at 5:40 PM
    heliman79
    heliman79 [OP] Well-Known Member
    Tim
    loxley al (baldwin county)
    05 sr5 prerunner v6
    im halfass throwing the idea around of putting the trd s/c on my truck, a person i know has one, used ofcourse with around 20k on it. he sold his truck and decided to go back factory for some reason:confused: anyways the engine seems healthy, no blow by or bad rings that i know about, doesnt use hardly any oil, 123k on the odo. am i right in the general estimate that they usually produce around 35- 45 hp, im assuming low boost( around 6 to 8 psi)..does it use the factory fuel injectors, pump, afm etc?
  2. Feb 21, 2015 at 7:30 PM
    Brjw
    Brjw Well-Known Member
    Brian
    Forest Grove, Oregon
    No you're wrong on the numbers. They are all over the internet. The supercharger and fit kit includes different injectors, spark plugs, ECU tuning. The factory fuel pump is used but a bigger fuel pump is advised by many.
    If you're thinking of buying a used supercharger you damn well better do your research and make sure you're getting all of the correct accessories that are normally included.
  3. Feb 21, 2015 at 7:45 PM
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    The supercharger increases the Tacoma's power output to 304 hp (227 kW) from the original 236 hp (176 kW), and the torque output to 334 lb·ft (453 N·m).
    The problem with used kits is that they do not usually come with most of the odds and ends you need to install the S/C properly so it doesn't do any damage to your engine. Most guys say it's very difficult to locate the TRD injectors and some other odds and ends in the fit kit. If you do buy the S/C used, make sure the fit kit has EVERY part mentioned in the instructions. You'll also need to get Toyota to flash your ECU with the TRD tune once the S/C is installed, so count on that cost as well. Your buddy might even have a TRD tuned ECU available so you don't have to flash yours because there is no way to take the ECU back to stock so he would of had to get a new ECU when he took his truck back to stock.
    Oh, and don't worry about fuel pumps and all that. If you want to check that everything is fine get an AFR gauge and then worry about addons later when you start trying to get more boost. That's my opinion anyways.
  4. Feb 21, 2015 at 11:00 PM
    heliman79
    Tim
    05 sr5 prerunner v6
    thanks guys
  5. Feb 21, 2015 at 11:55 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    First thing I'd ask is "Do you need the SC?"
    Other wise, all I can see is it being money NOT well spent.
    Especially if it's used.
  6. Mar 8, 2015 at 8:36 PM
    Remster
    Remster Well-Known Member
    Remi
    Ottawa
    Tacoma TRD
    AFE Air intake, AFE exaust cat-back), Toytec Ultimate Lift, Light racing Uca`s, Spidertrax spacers
    was just wondering if anyone had the sc and bullydog set up with full exaust? what Hp are you getting from a set up like this? Also if anyone know how much hp can a stock motor take?
  7. Mar 8, 2015 at 8:45 PM
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    I'd never put a bully dog on a Tacoma! Or anything else for that matter. There's a reason no one talks about them positively after owning one for a few months. They ruin trucks.
    With the amount of money you'll have under the hood in a supercharger you'd have to be pretty dense to use a cheap $200 tuner instead of a true custom tune on something designed for your setup from the get go. Sorry if that sounds harsh but bullydog is bad news.
  8. Mar 9, 2015 at 4:24 AM
    Remster
    Remi
    Ottawa
    Tacoma TRD
    Kk thx for replying i was just curious about it since i had hurd a few guys talking about it. I didnt know it was a shitty tuner. But i am planning on puttjng the SC in it with headers and y-pipe...already have a cat back from Afe. Should i put a tunner also or the one that comes in the kit is good enaugh?
  9. Mar 9, 2015 at 6:44 AM
    Large
    Large Red
    I found a used one on CL that was missing pieces and parts, paid $1,500 for it and another $400ish for the fit kit. I think I paid another $250 for the missing parts and did the install, I was about $2k in and had a working supercharger and paid $100 for the ecu reflash. I would find a parts diagram to make sure you get all the parts you need.
  10. Mar 9, 2015 at 8:23 AM
    Jefes Taco
    Jefes Taco Well-Known Member
    Denver, CO
    14' DCLB TRD Sport supercharged
    Forget the Bullydog. Get the URD under drive pulley.
  11. Mar 10, 2015 at 8:47 AM
    Remster
    Remi
    Ottawa
    Tacoma TRD
    Thx for helping out guys now i have a bettrr idea where this might go. Just need money now lol
