TRD Supercharger and Rev Hang
Discussion in 'Performance and Tuning' started by dawgrules, Aug 31, 2012.
  1. Aug 31, 2012 at 3:35 PM
    dawgrules
    dawgrules [OP] Active Member
    Hey I was wondering if anyone with a TRD S/C could tell me what effect (if any) it has had on the Rev Hang issue. I know it is caused, at least mostly by the DBW throttle but I'm curious if the ECM re-flash had any effect.
    I'm seriously considering the S/C but with this PITA rev-hang annoyance I could be, lets say much more enthusiastic.
    TIA
    Jeff A
  2. Aug 31, 2012 at 3:58 PM
    Mikehole
    Mikehole Well-Known Member
    SF Bay Area
    '12 4x4 Short Bed TRD Off Road
    TRD Supercharger, Toytec 3" Ultimate Lift w/ 285/75/16s and planning on OBA for sometime in the future. Also thinking about the HWMS and a Warn 8000 for it.
    I don't know what the rev hang issue is, but I have the s/c for my '12 and it made my opinion of the truck go from "meh" to "F%&k yes!"
    A quick search of the forum for rev hang makes me think that its a manual issue, and I'm an automatic, so I guess I have no input, other than the s/c is awesome. It kind of serves as a audible reminder that I'm pressing too hard on the gas when I'm trying to be economical because the bypass valve opens up and the S/c whirrs when I give it too much gas.
  3. Aug 31, 2012 at 5:39 PM
    grant99
    grant99 Well-Known Member
    London, ON
    05 4DR TRD Sport 6SPD
    I have the rev hang with my truck, its kinda weird/annoying. If I coast to a stop down my road in neutral to my driveway (about 150') it will hold rev till I get below about 5kph, I was wondering if it had anything to do with creating enough vac for the brakes? Honestly never searched it (I remember reading something about it so didn't alarm me) so don't shoot me if I'm way off ;-)
  4. Aug 31, 2012 at 9:00 PM
    Beers
    Beers Well-Known Member
    Colorado
    12 TRD OR
    I have noticed the revs seem to stay up when I push the clutch in on my S/C '12. It really hasn't bothered me though.
  5. Aug 31, 2012 at 9:23 PM
    Darth_Yota
    Darth_Yota I intend to live forever, or die trying.
    Cam-moron
    Somewhere USA
    Dented, broken-down ‘08 hoopty
    Ain’t good’nuff for insta
    My truck rev hangs around 1500 above 10mph, and I have no s/c. From what I understand it was put into the throttle body control in order to lessen the blow by gas emissions. If the throttle is closed immediately pressure in the crankcase increases causing more oil vaporization than usual. Definitely more prevalent in a supercharged engine though. Anyway by keeping the throttle slightly open even when the pedal is completely released pressure can escape from the engine.
    I would look into an oil catch can if you get rid of the rev hang completely.
  6. Sep 1, 2012 at 6:46 AM
    dawgrules
    Thanks but it was not my intent to discuss rev-hang, but rather any effect the s/c install has had upon it. They all do it and weather you recognize it or how much it annoys you is another issue which is subjective
    Thx
  7. Sep 1, 2012 at 10:38 AM
    triumphx
    triumphx Well-Known Member
    Austin, TX
    X-runner/cummins
    It's the drive by wire that our trucks have, it sucks but is what it is
  8. Sep 1, 2012 at 11:16 AM
    novanut21
    novanut21 Well-Known Member
    Brent
    North Central,WV
    2009 TRD SPORT
    AFE CAI, Magnaflow cat-back, TRD S/C, TRD Quickshifter, URD Fuel Pump Kit, Wet Okoles Front&Rear, WeatherTech Mats, Sockmonkey Decals, Satoshi grille, JBA "shorty" headers, URD Y-Pipe, TTC Oil Catch Can, Lotek Dual Apillar gauge pod w/ Autometer Phantom II AFR & Vac/Boost, URD Pulley, HID Retrofit.
    The re-flash didnt change the rev-hang on mine. S/C'd w/6spd.
  9. Sep 1, 2012 at 1:34 PM
    dawgrules
    BAM !
    Exactly what I was looking for!
    Thanks much-
    we'll have to wait for the Sprint Booster's release. I emailed them yesterday
    as to time frame.... awaiting response
    Jeff A
  10. Dec 15, 2018 at 9:53 PM
    rreddogg
    rreddogg Member
    2013 Tacoma TRD 6 speed
    sway bar. add-a-leaf
    I drove a 2013 6 speed manual for several months prior to installing a Magneson s/c with a Bully Dog ECU flash. Prior to the s/c install I'd read other folks commenting on the throttle hang issue and from my experience it had been noticeable but not particularly bothersome.
    BUT NOW.... since the Bully Dog reflash to accommodate the s/c the throttle hang is RIDICULOUS ! It is so incredibly bad that I am concerned it might actually shorten the life span of my clutch since I often don't find enough patience to wait for the revs to calm down before finishing every up shift.
    Sadly, I have taken this issue to Bully Dog and so far they have offered no solution.
    BassAckwards likes this.
  11. Dec 17, 2018 at 8:22 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Try taking your foot off the gas for a second or two before pushing in the clutch, may help with the hang.
    rreddogg[QUOTED] likes this.
  12. Dec 17, 2018 at 8:56 AM
    rreddogg
    rreddogg Member
    Thanks, I will try that but I have to say it sounds like a lot of work & a herky-jerky ride if not done precisely.
    Obviously my preferred method would be that Bully Dog (for $499.99) should get this right.
  13. Dec 17, 2018 at 8:58 AM
    BassAckwards
    No worries. Like everything related to this 6spd, just takes some getting used to. I do believe that could fix your issues though, you'll find the sweet spot as far as how early you need to let off the gas before clutch gets pushed in.
