TRD Pro Wheels on 2015 Prerunner?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2ndGenTacomaHI, Mar 18, 2020.
  1. Mar 18, 2020 at 9:55 PM
    2ndGenTacomaHI
    2ndGenTacomaHI [OP] Member
    2015 Tacoma Prerunner
    Hi Everyone,
    New to the forum. I have a 2015 Tacoma Prerunner Double cab. V6. Truck has not been modified. No lift or anything. Tire size is 265/65R17. I was looking to put the 4Runner TRD Pro Wheels on my truck. I was just wondering if these will fit as is? No rub? Do I need to level or need spacers? Thanks for any info you can provide
  2. Mar 19, 2020 at 5:25 AM
    Thegenerik1
    Thegenerik1 Well-Known Member
    Erik
    NorCal
    18 DCLB OR
    They will fit as is. If you go with a bigger tires you could get some rubbing.
    2ndGenTacomaHI[OP] likes this.
  3. Mar 19, 2020 at 8:25 AM
    TheDirtyMike
    TheDirtyMike Well-Known Member
    They will fit as is, no rub or any issues.
  4. Mar 19, 2020 at 10:01 AM
    rphillips
    rphillips Well-Known Member
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    Are those available in alum. (silver) color? If they are, they would really look great
  5. Mar 19, 2020 at 11:04 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    As long as the rims are 17 inch.
  6. Mar 19, 2020 at 12:56 PM
    Micbt25
    Micbt25 Well-Known Member
    TM
    2015 MGM TRD Sport Access Cab 4X4 V6
    Yup they fit on my 2015 TRD Sport 4x4 with 265/70R17 (Tire size up from yours). The bigger tires rub a bit on the flaps, but that had nothing to do with the rims. They look great.
    Mike714 likes this.
  7. Mar 19, 2020 at 1:23 PM
    Gregthespy
    Gregthespy Well-Known Member
    Greg
    Orlando
    2015 Blue Ribbon Metallic TRD Sport 4X4
    They fit great. They also are available in a gun metal gray. The offset is a little wider so they stick out about an inch further than the factory aluminum wheels do. In my opinion it gives the truck a more aggressive stance.
    I love mine!
    Micbt25 and Mike714 like this.
  8. Mar 19, 2020 at 4:43 PM
    Kolter45
    Kolter45 Well-Known Member
    Denver, CO
    2013 TRD Sport, 2015 Inferno 4Runner
    Toytec Boss Leer/Rhino Rack TRD Wheels/Falkens
    you should be okay. tell them to reuse your TPMS, value stems & lugs. you do have 6 lug correct?
  9. Mar 19, 2020 at 5:53 PM
    J'sBeasTRD
    J'sBeasTRD Well-Known Member
    Salinas California
    15TACOMATRDOR 4X4DCSB6SPD...
    Yes they will fit perfectly
  10. Mar 19, 2020 at 5:55 PM
    ALI3N_123
    ALI3N_123 ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Eric
    Austin, Texas
    2021 Silver TuRD Squirt DCSB 4x4 // 2008 Black Rusty Shitbox DCSB PreRunner
    They'll work with those wheels and tire size
  11. Mar 19, 2020 at 10:56 PM
    2ndGenTacomaHI
    Thanks for the confirmation!
  12. Mar 19, 2020 at 10:58 PM
    2ndGenTacomaHI
    Kolter - Thanks! yes I have 6lug
  13. Mar 19, 2020 at 11:00 PM
    2ndGenTacomaHI
    Thanks for the feedback everyone! Much appreciated.
    MICBT - if I go to that tire size do I need to lift my truck?
  14. Mar 20, 2020 at 4:44 AM
    Micbt25
    TM
    No lift needed, I removed all the mud flaps, the rubbing wasn’t too bad, but I like the appearance better without. Tires of the same size vary slightly. For example, the 265/70R17 BFG KO2s may run larger than say the Cooper Discoverer AT3.
    I may install Bilstein 5100s on the front and set it on the first raised setting (.85), just to raise it up a bit.
  15. Apr 3, 2020 at 2:34 PM
    Ditchhanger
    Ditchhanger Active Member
    Oahu, Hawaii
    2010 DCSB TRD Sport PreRunner
    TRD Wheels, 265/65/17 KO2
    I just had these installed on my 2010 with 265/65/17 K02's. I was going to put the 265/70/17's but they were going to rub, so I went with the smaller size tire. No other fitment issues at all.IMG_8673.jpg
    Mike714 and Micbt25 like this.
  16. Apr 3, 2020 at 4:32 PM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 Super White S/C DCLB TRD SPORT
    beautiful truck!
  17. Apr 4, 2020 at 11:03 AM
    Ditchhanger
    Oahu, Hawaii
    Thanks! Not bad for a used 10-year old truck
  18. Apr 6, 2020 at 4:10 PM
    Mike714
    Mike714 Well-Known Member
    Cypress, CA
    2013 DCSB Prerunner Super White
    Wow that's fantastic looking! The paint is superb!
  19. Apr 6, 2020 at 4:28 PM
    Ditchhanger
    Oahu, Hawaii
    It’s got a few small dings and chips, but pretty decent. I had a paint correction done when I bought the truck. It made a huge difference.
  20. Apr 27, 2020 at 3:16 PM
    kbourg1
    kbourg1 Active Member
    Redding, CA
    2013 DCSB TRD Sport 4x4
    I just purchased TRD Pro Wheels as well. Went into Les Schwab to have them installed with new tires today and Schwab called back and said it was a pain in the ass getting the new wheels on. They said they had to "hammer" them into place. Anyone else have this issue with fitment size? This is specific to the wheels themselves and not tires.
