TRD Pro wheels on 2010 Taco?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cvillej, May 30, 2021.
  1. May 30, 2021 at 8:41 AM
    cvillej
    cvillej [OP] Member
    Jon
    I have a 2010 SL SR5. The stock wheel is: P245/75R16 Tires.
    I would like to put these on: https://www.amazon.com/Genuine-Toyota-4Runner-TRD-PTR20-35110-BK/dp/B07PDNSTDK/ref=sr_1_5
    I am planning on lifting it a couple issues. I am more concerned about fit. I know the lug pattern is compatible. I have read that on some model tacos they fit too tight and they get a brake shudder. I't looks like people have been able to fix it by grinding a slight chamfer on the hub: https://www.tacomaworld.com/threads/problems-with-2021-4runner-trd-pro-wheels-install.715447/page-3
    Anyone try putting these wheels on the same Tacoma I have?
  2. May 30, 2021 at 5:59 PM
    TacoTuesday1
    FL
    I would not.
    Why?
    -overplayed. Everyone has them
    -they're ugly. Boring stock mild design
    -too expensive for no noticeable upgrade
    -does not have bead grip ridges like the new Method wheels that cost the same and look better
    98_3RZ_NIC likes this.
  3. May 30, 2021 at 10:39 PM
    pahaf
    pahaf Well-Known Member
    paul
    NorCal
    2015 Tacoma TRD Off Road
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
    I have a 2015 trd off road. They fit just fine and I have 265-70-17 tires. Have no issues at all with them.
    there is a slight “performance” upgrade when you get these. lol. They are about 24lbs where other rims run heavier and that is worse for mpg, power.
    I had the 4runner trail rims before and those were about 30lbs
    jeminyned, BraddahRO and Kilo Charlie like this.
  4. May 31, 2021 at 5:42 AM
    cvillej
    cvillej [OP] Member
    Jon
    Thanks for the feedback. I'll check out the method wheels.
    Your truck looks sweet. What kind of lift do you have in it?
  5. May 31, 2021 at 5:49 AM
    cvillej
    cvillej [OP] Member
    Jon
    Also - what did you do with your antenna?
  6. May 31, 2021 at 5:56 AM
    ALI3N_123
    ALI3N_123 ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Eric
    Austin, Texas
    2021 Silver TuRD Squirt DCSB 4x4 // 2008 Black Rusty Shitbox DCSB PreRunner
    https://www.tacomaworld.com/threads...-ish-thread-taken-over-by-a-gx460-now.603951/
  7. May 31, 2021 at 6:18 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Best looking wheel....period
    FastEddy59 likes this.
  8. May 31, 2021 at 7:42 AM
    pahaf
    paul
    NorCal
    I have bilstien 6112 set in 4/6 notch. And in the rear I have bilstien 5116 with ome el11r leaf springs. So about 2.5” lift.
    the antenna is just a replacement from eBay. It’s a “shorty” antenna. Was like $10 on eBay,
    cvillej[QUOTED][OP] likes this.
  9. May 31, 2021 at 8:18 AM
    kevinRR
    kevinRR Well-Known Member
    Milwaukee, WI
    2022 Toyota 4Runner
    G-shock! likes this.
  10. May 31, 2021 at 9:05 AM
    cvillej
    cvillej [OP] Member
    Jon
    Wow! That is a good price.
  11. May 31, 2021 at 9:11 AM
    pahaf
    paul
    NorCal
    i payed about $600-$700 shipped brand new from a dealer as well.
  12. May 31, 2021 at 9:40 AM
    G-shock!
    G-shock! Well-Known Member
    OC TACOMAN
    Orange County
    2GTRD4L
    Fox 2.0 frt/resi rr PolyPerf. UCAs
    It looks like most dealers are honoring $168 price per wheel for Memorial Day. Smokin deal.
  13. May 31, 2021 at 5:56 PM
    N minus 1
    N minus 1 Ruff Road Designs
    San Diego, CA
    2014 TRD Off Road
    I'd definitely recommend them. I just got a set of 5 of the gun metal gloss grey for my 2nd gen at $1100 OTD from my local dealer.
    should be no problem on your truck, track width will be a little wider (~1")
    There are alot of knock offs so buying from a dealer that price matches is always a good idea.
  14. Jun 1, 2021 at 5:26 AM
    cvillej
    cvillej [OP] Member
    Jon
    Thanks for all the feedback. I am going to pull the trigger on them. Need to save up a little cash money for tires now.
  15. Jun 1, 2021 at 5:28 AM
    cvillej
    cvillej [OP] Member
    Jon
    Anyone know if bam wholesale is generally a reputable site or should I still stick with a dealer?
    They have a great price: $166.65
  16. Jun 2, 2021 at 7:09 AM
    N minus 1
    San Diego, CA
    2014 TRD Off Road
    Iv herd alot of good feedback about BAM but also some people receiving damaged wheels.
    Don't forget BAM charges shipping as well so that might bump the price a little closer to a dealer who price matches.
  17. Jun 2, 2021 at 9:46 AM
    pahaf
    paul
    NorCal
    Got my rims from them. No issues
  18. Jun 2, 2021 at 1:36 PM
    cvillej
    cvillej [OP] Member
    Jon
    Sweet! Just ordered mine from them. I am stoked.
  19. Jun 2, 2021 at 4:02 PM
    kbourg1
    kbourg1 Active Member
    Redding, CA
    2013 DCSB TRD Sport 4x4
    I purchased mine from Bam with no issues and they shipped fast.
  20. Jun 3, 2021 at 8:10 AM
    cvillej
    cvillej [OP] Member
    Jon
    Your truck looks great! Is it lifted? What size wheels/tires? Trying to figure out what will fit on mine (2010 non TRD). I am going to lift it but need to figure how much and which lift to choose.
