TRD pro SEMA wheels on SR5
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Kdog63, Dec 19, 2022.
  1. Dec 19, 2022 at 9:53 AM
    Kdog63
    Kdog63 [OP] New Member
    2018 Tacoma SR5
    Hello all,
    I know everyone is probably sick of the tires and wheels questions but here goes anyway as I couldn’t find definitive answer on here. I want to know if the 17” TRD pro SEMA wheel will fit my 2018 Tacoma sr5, it is 2 wheel drive. I want to put this wheel on with a 265/70/17 falken wildpeak at3. Truck has no lift, will stay stock suspension for now. Thanks !!! Pictures would be great too…. If you have this setup or similar I would love to see what has been successful.
  2. Dec 19, 2022 at 10:03 AM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    It will fit no problem. You may rub the mudflaps a bit, but it's usually minor.
    Kdog63[OP] likes this.
  3. Dec 19, 2022 at 10:29 AM
    NomadicCypress
    NomadicCypress Well-Known Member
    2023 Solar Octane TRD Pro M/T
    It’ll work, they’ll look great. You’ll be fine.
    Remove the OEM mud guards and get rokblokz and you won’t have any rubbing
    LeakyAC and Kdog63[OP] like this.
  4. Dec 19, 2022 at 12:55 PM
    Buggin112
    Buggin112 Well-Known Member
    Portland, Oregon
    2022 Tacoma TRD Off-Road
    I have the same wheel and same size tire in the K02. Stock height and stock mud flaps. Only get a slight rub turning into a driveway at a higher speed (coming off a main road into a parking lot. No rub pulling into my driveway).
    GrandMasterChooch likes this.
  5. Dec 19, 2022 at 1:16 PM
    Integerdy
    Integerdy Aspiring "SR5 Pro"
    Eric
    So-Lame, Oregon
    21 SR5 Silver Sky DCSB
    My 2021 SR5 with trd lift kit, sema 17 pro wheels and 275/70/17 Falken wp at3w. No rub at all. Even have the oem mud flaps
    You should be able to fit 265 no problem
    TT005 and Kdog63[OP] like this.
  6. Dec 19, 2022 at 1:20 PM
    Buggin112
    Portland, Oregon
  7. Jun 28, 2023 at 6:19 PM
    CaribeTaco
    CaribeTaco Member
    William
    2022 Silver Tacoma OR
    TRD SEMA Wheels Falken Wildpeaks 265/70r17 DV8 Midbumper
    Sorry to dig up an old post, are you running aftermarket UCAs?
  8. Jun 29, 2023 at 11:39 AM
    Integerdy
    Eric
    So-Lame, Oregon
    No. Stock. 285s would have definitely rubbed in sema wheels.
  9. Jun 30, 2023 at 4:44 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    I have 5100s on the top perch, one inch rear block, very slight rake with OEM 4Runner SEMA Pro wheels with 285/70s and no rub on the OEM mud guards. I had the off road shop in our parts that I have used for 20 plus years do the lift and re did the alignment when I went up to 285s. I did oval out the bottom hole on the front guards and got them moved gack about 1/2 inch prior to the alignment. No where even close to rubbing and yea I flexed it at the mall!
