TRD Pro payload capacity for a slide-in camper?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by txrninvestor, Feb 11, 2022.
  1. Feb 11, 2022 at 1:52 PM
    txrninvestor
    txrninvestor [OP] New Member
    Texas
    2018 Tacoma TRD Pro
    Hello everybody!
    I have a 2018 Tacoma TRD Pro and I'm looking into getting a slide-in camper. I want a slide-in as opposed to a trailer primarily for better maneuverability in urban areas and ease of parking. Two of the options I'm really interested in are the Kimbo Camper 6 Series and the Scout YOHO. I'm not too savvy on terms like "payload capacity," "GVWR," "tongue weight," etc. and how flexible the definitions are. Looking for some assistance with understanding these terms and guidance with a possible need to modify the truck.
    Scout YOHO
    From Googling info, it looks like the payload of TRD Pro is 1155 lbs. According to the manufacturers' sites, the Kimbo weighs 900-1050 lbs and the Scout weighs 958 lbs. From my research, these are "dry weights." Should the truck be okay without mods since the weights technically fall within the payload capacity? Is payload something I can increase on a TRD Pro? If I need mods, what do I get? Will the "GVWR" come in to play once the camper is actually on the truck? I'm really not a math guy and there are so many numbers I did not expect, making this complicated for me...
    I appreciate you Tacoma gurus out there!
  2. Feb 11, 2022 at 2:07 PM
    Shellshock
    Iowa
    If you put one of those in on the stock leafs, it’s gonna be on the bump stops
    @YF_Ryan has a scout in his truck
  3. Feb 11, 2022 at 2:14 PM
    kfatt
    kfatt Active Member
    GVWR is determined by the manufacturer and cannot be changed. The Tacoma's is very low. It doesn't include fuel, or passengers. A family of 4 can easily kiss the GVWR with normal camping gear and 0 mods.
    You can modify the truck to better handle the weight - common upgrades would be suspension via springs and/or airbags, big brake kit, and a tune. None of that will increase the GVWR, but it will make the vehicle safer & more pleasurable to operate when overloaded. This is what many people do - most heavily modified tacomas are over GVWR, in many cases quite far over it.
    If you're not willing to go over GVWR you're stuck with a tent-style, *maybe* a pop-up like Project M or Ovrlnd, or moving up to a bigger truck.
    Montana_Actual likes this.
  4. Feb 11, 2022 at 2:17 PM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    Payload capacity = the weight of EVERYTHING that you put into your Taco, i.e. the camper, you, your passenger(s), your equipment and everything you put into your camper. If your camper's dry weight is 1,000 lbs and your Taco's rated payload capacity in 1,050 lbs, then you best go on a diet.
    Now, that said, there are things you can do to increase the payload capacity of your Taco. BUT keep in mind that those are typically only suspension enhancements. Your Taco is designed around what its total weight could be - things like the frame, the brakes, etc.
    Can you exceed the capacity? Sure. Many of us do on occasion (or frequently). But when we do we're exceeding what the total truck is designed and rated for.
    I understand the desire to avoid a trailer, but quite honestly it may serve your needs better and allow you to carry more in the Taco and avoid that extreme diet.
    Sprig likes this.
  5. Feb 11, 2022 at 2:27 PM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    Junkhead and Shellshock[QUOTED] like this.
  6. Feb 11, 2022 at 2:31 PM
    YF_Ryan
    Kent, WA
    And here's me loaded to the hilt! :thumbsup:
    Survived a 2000 mile roadtrip easily. But drank gas like none other. A little over 7mpg average.
    grogie and Junkhead like this.
  7. Feb 11, 2022 at 2:58 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    When you put people, equipment and fuel in the truck plus the slide in camper you are going to grossly exceed the GVWR. Not only is that illegal but it’s dangerous too. If you are set on a slide in camper then you need to get a full size truck.
    Stopping that truck when it’s grossly over weight becomes a real problem. With all the weight and the higher center of gravity with the camper vehicle control also becomes a real problem when you have to stop suddenly or swerve for something. Finally when you have an accident and you are grossly overweight, your liability increases and you will get the shit sued out of you. So you need a different truck or look into a moderate weight travel trailer.
  8. Feb 11, 2022 at 3:10 PM
    kfatt
    kfatt Active Member
    I'm not a stickler for weight generally but the stopping distance on this has got to be as eyepopping as the MPG. Not something I would plan to do if I had the budget OP is talking about(80k minimum?). There's no shortage of capable trucks in the US. Why by one that doesn't fit your needs and then try to force it?
  9. Feb 11, 2022 at 3:11 PM
    YF_Ryan
    Kent, WA
    You are mostly right, but depending on manufacturer people do or do not deduct from the payload. Some manufacturers assume a driver in the vehicle of some weight (i've seen both 150 and 170, for example), but I have also seen a manufacturer use 150 lbs per available seat (which I was seriously surprised about, cause that added up to 900lbs for the crew cab with bench seats). This should be spelled out in any vehicles owners manual. In the case of Toyota, they do state that ALL people need deducted from cargo capacity (snip below from 2021 Tacoma Manual). As for fuel, I have yet to see any manufacturer that does not include a full tank of fuel when calculating their Payload/GVWR/etc. As for liability/etc, yup, I'm with you. Personally I have made a decision, and everyone needs to do that for themselves. I am not suggesting anyone blow past their GVWR, at least not without giving it serious thought. But if the OP wants a truck camper, as long as he does the research and still wants to do it, more power to him.
    grogie likes this.
  10. Feb 11, 2022 at 3:14 PM
    anthemAnathema
    anthemAnathema Well-Known Member
    2013 4.0 6MT Access Cab TRD Offroad
    Elka 2.5 w/ DSC RCI Skids AP Expedition Leafs Leer 180
    Those Scout's are cool campers but they look goofy AF with how high above the bed rails they sit on Tacomas... actually they look that way on every truck I've seen 'em on.
    Seems like a lot of waster space.
    I'll also add that putting a truck camper in a Tacoma is in the same category of "but why" as white water stand up paddle boarding, mountain unicycling, and snowshoe running.
  11. Feb 11, 2022 at 3:15 PM
    YF_Ryan
    Kent, WA
    The pickup was paid for years before the mods. Bought it new in 2011, didn't start modding it til about 5 years ago. Stopping, even panic stops haven't been an issue. Trailer brakes even became disconnected once and I was still able to stop the load (since replaced trailer connector to avoid that happening again). I contemplated a sway bar, but deemed it unnecessary after our 2000 mile roadtrip (my sister's Raptor pulling an 18ft enclosed trailer had more issue with wind than us).
    I will definitely be buying a completely different style truck once the Tacoma wears out. Ram 5500 with Flatbed is our actual next plan. but this will do in the meantime.
    grogie likes this.
  12. Feb 11, 2022 at 3:16 PM
    YF_Ryan
    Kent, WA
    The high sides are based on full sized trucks and the height of their bedsides. They needed to make it fit as many vehicles as possible.
  13. Feb 11, 2022 at 3:17 PM
    YF_Ryan
    Kent, WA
    As for that budget, our camper was about 23K i believe, after taxes. And like the OP, I already had the truck.
  14. Feb 13, 2022 at 2:30 PM
    Voltron4x4
    Voltron4x4 Well-Known Member
    Denver, Colorado
    2014 Black Trail Limo
    This and that...
    Short answer, it works with only needing airbags with stock suspension. I own a Kimbo and met another with a Yoho. Long answer:
    I love my setup and have taken it off road where a trailer would not work. MPG’s are about what a Tundra gets when stock. We have a thread with a lot if info on the Kimbo here and I believe there is a tread on the Yoho too.
    https://www.tacomaworld.com/threads/kimbo-camper-bs-and-mods.651104/
    4E7D10CA-F242-482A-B800-C01D9B3E62EF.jpg IMG_9427.jpg AFF152B8-4935-4A36-992E-5A52A76642BC.jpg 85AFADBE-16EA-4DF2-A85B-28C0C7CC4398.jpg F4C72C17-FA6F-4F82-B5F0-24F3A2941957.jpg
    grogie, Jesse H and jwctaco like this.
  15. Feb 13, 2022 at 2:38 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Check your driver's door jamb for a sticker that looks like this. Your payload is likely around 950lbs which puts you over the GVWR with just the empty camper and no driver, passengers, food, gear, etc. You can do it with appropriate heavy duty suspension mods as demonstrated by many people on this forum but it isn't technically legal. Whether you plan to only put the camper on the back when you use it or carry it all the time will dictate how you will want to approach the upgrading process.
  16. Feb 13, 2022 at 2:39 PM
    Jesse H
    Jesse H Well-Known Member
    Jesse
    Texas
    '22 TRD Pro 6MT
    I love Dalmore!
  17. Feb 13, 2022 at 2:40 PM
    Voltron4x4
    Denver, Colorado
    This and that...
    The Cigar Malt is a favorite.
    Jesse H[QUOTED] likes this.
