TRD Pro parking brake cable spacer
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Pro-Taco, Apr 12, 2019.
  1. Apr 12, 2019 at 4:58 PM
    Pro-Taco
    Pro-Taco [OP] Well-Known Member
    Lou
    Commiefornia
    2019 OR DCSB 4X4 Prem/Tech Cement
    All TRD Pro parts
    So apparently that little spacer is a TRD Pro exclusive part and needs a special approval for Toyota to release it. I'll get it eventually trough my dealer friend prolly by the next week, but I wanted to install my shocks tomorrow and was wondering if I can substitute it with something else or skip it all together? What size bolt comes with the spacer? How big is the spacer? Maybe I can use bunch of washers instead? I borrowed this picture from BadCow to show you guys what I am talking about. Any help/advise is appreciated.
    WorldWar546 likes this.
  2. Apr 12, 2019 at 5:02 PM
    13txtaco
    13txtaco Well-Known Member
    Katy Texas
    2013 Tacoma 4x4
    I have this shock installed on my second gen no spacer at all and I have no issues with the parking cable
  3. Apr 12, 2019 at 5:09 PM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    I ordered one from a dealer a little over a year ago (Toyota of Kirkland) without any Pro Vin or hassle. I think each dealer is different.
    When I replaced my shocks with ADS, I had to ditch the cable holders all together (because of the Icon AAL). Haven't had any issues yet.
  4. Apr 12, 2019 at 5:12 PM
    Pro-Taco
    Lou
    Commiefornia
    All TRD Pro parts
    Thanks gents. This is what I see. Not sure how it can interfere with the Pro shocks?
    kbecerra and Red_Taco_Sauce like this.
  5. Apr 12, 2019 at 5:26 PM
    Pro-Taco
    Lou
    Commiefornia
    All TRD Pro parts
    Yep, wrong side. Here is the correct side.
  6. Apr 12, 2019 at 5:28 PM
    Pro-Taco
    Lou
    Commiefornia
    All TRD Pro parts
    And while in there I also noticed this. Should I be worried? Dealer time?
    whatstcp likes this.
  7. Apr 12, 2019 at 5:32 PM
    BingoBangoPickoMango
    BingoBangoPickoMango no no yeah
    Hawaii Nei
    2018 4X4 TRD Sport DCSB
    Another Bilstein Buildy Boi
    I got some aftermarket zip ties on mine
    Pro-Taco[OP] and whatstcp like this.
  8. Apr 12, 2019 at 5:48 PM
    Pro-Taco
    Lou
    Commiefornia
    All TRD Pro parts
    I was thinking about using stack of washers for a time being, and yes the install manual mentions new bolt but doesn't mention the size. I guess I'll remove the original and take it to the store. Thanks.
    whatstcp[QUOTED] likes this.
  9. Apr 12, 2019 at 6:04 PM
    wolfman00
    wolfman00 Well-Known Member
    matt
    Gambrills/Crofton MD
    '16 dclb
    sortof stock. 6112/5160, pro wheels and a tune.
    you just need a 1"x1" square block with a 3/8'' hole in it. that will work temporary just fine. you just need something to space the ebrake cable guide from rubbing on the shock. even a steel spacer from the home depot/lowes hardware asile will work just fine until you can get the real one.
    whatstcp and Pro-Taco[OP] like this.
  10. Apr 12, 2019 at 6:07 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I just keep thinking of my janky ass brake line spacer reading through this thread.
  11. Apr 12, 2019 at 6:09 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Like @whatstcp said, a 1” metal sleeve from ace and longer bolt will do the trick. Can even wrap it in heat shrink so it looks cleaner. I used washers at first and it was a pita
    TacoTorakku likes this.
  12. Apr 12, 2019 at 6:14 PM
    hawaii_dave
    hawaii_dave Well-Known Member
    2017 trd pro
    If the head of the bolt uses a 10mm wrench/socket then it's a 6x1.0mm bolt. 12mm wrench/socket then it's a 8x1.25mm bolt. if it's a 14mm wrench/socket that fits it's a 10x1.25mm bolt. 17mm wrench/socket it's a 12x1.25mm bolt. and if it's 19mm wrench/socket it's a 14x1.25mm bolt these sizes also go for the nuts . Toyota uses fine threads on all bolts and nuts . these are factory size aftermarket bolt and nuts you never know but most of the time they are off by 1 or 2 mm on the wrench size.
    This just a guide. the larger sizes 17 & 19 mm could be different . I have also seen bolts on Toyota's the will have 12mm head bot have 10x1.25mm threads . very rarely .
    SR-71A and Pro-Taco[QUOTED][OP] like this.
  13. Apr 13, 2019 at 12:24 AM
    Pro-Taco
    Lou
    Commiefornia
    All TRD Pro parts
    Thanks for ideas guys. Will update this thread tomorrow after my shopping spree :)
  14. Apr 13, 2019 at 4:10 AM
    BadCow
    BadCow Well-Known Member
    David
    2019 Tundra TRD PRO Super White
    Dude, you can go without the spacer, not a big deal really, unless doing some major off roading. It just gets your PBK cable away from the external bypass on the passenger side rear shock. Any type of spacer would work. I bought it from my dealer, he had one in stock, and it was only $9.
  15. Apr 13, 2019 at 4:20 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Just to clear up the nomenclature, that’s the external reservoir.
    Bypasses are those little tubes on the outside.
    BadCow[QUOTED] likes this.
  16. Apr 13, 2019 at 4:25 AM
    BadCow
    David
    Roger that, I stand corrected, but you know what I meant.
    EatSleepTacos[QUOTED] likes this.
  17. Apr 13, 2019 at 4:29 AM
    projectmoonlite
    projectmoonlite Taco noob
    Texas
    2012 Truck
    I used one of the rubber spacers off the old shock unit and zip tied it on there .
    I ordered the part online. No Pro vin needed.
    BadCow likes this.
  18. Apr 13, 2019 at 4:33 AM
    BadCow
    David
    Anyone can purchase that part. Or you can make your own spacer. Or you could run without it. The dealerships can be fickle about selling the entire TRD PRO suspension without the right VIN. It's total BS.
  19. Apr 13, 2019 at 1:07 PM
    Pro-Taco
    Lou
    Commiefornia
    All TRD Pro parts
    Seems like most of the dealers in my area requiring a VIn for that part. They can place an order but Toyota won't release it without a Pro VIN.
  20. Apr 13, 2019 at 1:08 PM
    Pro-Taco
    Lou
    Commiefornia
    All TRD Pro parts
    How wide is that spacer? 1", 2"?
