TRD Pro Grille Retrofit 98-2000 tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by Godzilla619, Jul 10, 2020.
  1. Jul 10, 2020 at 5:19 PM
    Godzilla619
    Godzilla619 [OP] Well-Known Member
    David
    San Diego
    2000 Black Taco prerunner v6
    Mid travel
    I was inspired to make this after I saw some pictures on the unique mod section in 1st gens. I bought a TRD grille on OfferUp and went to work!
    I used a Dremel to cut the inside of the TRD grill out of the frame. And then I did the same for my 2000 grille. 5587FC49-3947-4BFF-9764-8032E0E278DD.jpg5A990099-9B18-4B13-9B16-04CCA3D3D0E2.jpg 69967DCF-CF10-4CF1-8C40-B82A9FE569EE.jpg
    Lots of measuring and going back and forth.
    F7803052-E8B6-4139-960F-EFB257F5467A.jpg E6F2B161-5DA1-48F0-8726-20339ADA7478.jpg A120B5ED-3573-47C5-9C4F-8C243C94744A.jpg
    I made sure to leave myself as much room for error as possible, and left the most pieces on the TRD PRO grille. Then I would go back and cut after measuring. Same process repeating until it fits good.
    D9162699-A0B2-44AD-8931-B30AA2EF52FE.jpg 9185231A-4116-4777-8189-37CB63DC3A87.jpg
    I used JB weld to cement it in place. I also wanted to paint the letters white because my truck is black and I love the look of the white letters! Masking was a pain... I scuffed the letters with some high grit sandpaper and used self etching primer. Then sprayed with arctic white enamel paint.
    It came out pretty good with a tiny peel at the bottoms of the letter “A”. I made sure to use an wxacto knife as I peeled away from the letters and it was the best method to get clean lines.
    I am pretty happy how this came out. I decided against clear coat as I’ve read that it fades the white into a yellow color. Then I reinstalled the letters held on by 4 screws in the back. I also had to cut some plastic from the bottom of the grill where a a sensor goes on the 3rd gens I believe. This has to be cut, in order for your grille to fit back inside the mounts on the truck, otherwise it won’t let it sit flush.
    I was a little sloppy with the JB weld for sure. But I know it’s not going anywhere haha! I will go back and sand it later but for now I was ecstatic to fit back on the truck. My truck isn’t a looker either, but man does it look cool with the TRD Pro Grille! I hope this helped anyone who wants to do this for 98-2000 Tacoma!
    Side note, I’m getting a new bumper in the next month so it’ll look way better after I have installed. I’ll update with a pic when I get it!
    After:
    LSUdude likes this.
  2. Jul 10, 2020 at 5:20 PM
    Madjik_Man
    Colorado Front Range
    Looks great. Nice work.
    SkunkMan17 and Godzilla619[OP] like this.
  3. Jul 10, 2020 at 5:25 PM
    Godzilla619
    David
    San Diego
    Mid travel
    Thanks! It may have added 15HP!
    SkunkMan17 likes this.
  4. Jul 10, 2020 at 6:13 PM
    SkunkMan17
    SkunkMan17 Jerry-rigging everything
    Owen
    Montana
    1997 Tacoma RC 4x4
    Tasteful modifications :)
    Looks good
    Godzilla619[OP] likes this.
