TRD Pro Grill and Garnish info, Updated.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by FreshMexicanTaco, Aug 3, 2019.
  1. Aug 3, 2019 at 12:57 PM
    FreshMexicanTaco
    FreshMexicanTaco [OP] The Taco Garage
    AJ
    San Diego
    2019 spiced up Taco with guac, no onions.
    Dashtop Multi-Mount!, Pro grille, snug top, Kings BFGs, Front and rear view camera anytime, CMC, prinsu and more to come!
    I have been seeing grilles and garnishes for a few years now and I will do my best to keep this thread updated with all the relevant information.
    GRILL
    1. All Tacoma models and trims are compatible with the TRD Pro grill, OEM or not.
    2. 2016 -2017 models do not need the TSS Grill garnish. 2018 - 2021 have a radar in the grill that enables dynamic cruise control and emergency breaking (very important safety features) and they will require the "garnish" to operate and protect the radar properly. Some newer models also have front facing cameras and if yours has it, there is still not a bolt on solution for mounting that camera on an aftermarket pro grille. (that I am aware of)
    3. You can find OEM grilles with no garnish for about $400 now a days. Some dealers will require you to have a REAL TRD Pro (or it's VIN;)) to sell you a grill. Replicas will range from about $100-$250 depending on where you buy, but beware, not all replicas are the same as shown on THIS VIDEO. We have come across at least 7 different versions and they don't all look or fit the same. You can find a great one .​
    GARNISH
    1. The garnish provides a smooth surface for the radar to see through and prevents any debris from hitting the radar through the grill openings.
    2. Currently Toyota dealers sell the garnish for about $350, the garnish is nothing more than a flat piece of plastic that mimics the grill's honeycomb pattern, so Toyota's prices are just a way to stop us from using the TRD Pro grill.
    3. Ebay / Amazon is flooded with REPLICA garnishes being sold as OEM! THOSE garnishes may or may not work properly there's no real way to tell which ones are good and which ones are not based solely on the generic descriptions you see, TW is a great way to find a good one.
    RADAR RECALL
    1. If you want to install a pro grill it is a good idea to get the recall service done before, you shouldn't have any problem after that.
    2. Those of us with TRD Pro grills installed may have issues with dealers trying to perform the recall required service. Toyota has denied the repair to several customers of mine because of an "aftermarket-grill" some others have had no issues at some better dealers.
    3. One customer of mine had his radar completely de-activated by Toyota because of this. WITHOUT HIS PERMISSION. Now he has to re-install the original grill, bring it back to the dealer and then re install the pro.
    So if you are in the market for a garnish... some of the replica garnishes work fine but some are absolute trash. You have to do some research before buying an aftermarket garnish or buy from someone who will take returns. If you have never seen a real OEM garnish you would have a very hard time trying to figure out wether a seller is scamming you or not. Here's some help:
    AS OF 1/22/2021 it is basically impossible to find OEM garnishes being sold for less than $250. All new garnishes under $250 are fake (trying to pass as OEM).
    Here are some images to show you some of the differences between OEM/non-OEM garnishes:
    I DO NOT ENDORSE THE FOLLOWING STATEMENT, THIS IS FYI ONLY.
    There are a lot of people who have been and continue to use the grill without garnish on their 2018-2019 and have zero issues. Sometimes the grill will cause an error that seems to disappear after a few days. I believe this might be to the sensor or computer "re-calibrating" itself after a few on-off cycles. The garnish also protects the sensor from rocks, not using it can lead to Foreign Object Damage (FOD).
    OEM garnishes will always be wrapped in paper:
    jdWGGJQAt2U7lVzmlAVutYNu5Y3oZKyfzVhhVwoG_ca1bbb70afa4a0ee4a78204c3a3395caf68948e9.jpg
    Replicas come in a variety of boxes and some are no getting the paper wrap too in an attempt to fool you.
    jeIRRKSS-2hEf5e2fAPCqwKx5ETmC-GRaI0PXhdd_ee15a2fc51e62a0b2d56c65f925be4eeefeb4298.jpg
    OEM Labels are better made:
    0YZjWlgjQh8mV8rR9gfo3Npw0qYnA5gCF02ITYI0_07621fcfbda23084662c9e08f32218f86d200c8c.jpg
    Replica: (they couldn't even spell radiator right)
    0GMRR_c1Ch3jGw3weEu2kzY2ix0_izT8EDfRMEcJ_974a5daab9fea365b8f0dec87cf2b1ca99d5b234.jpg
    Side by side:
    Replica | OEM
    VxGlPKlVKs9Bg35idFlSUGjd_XxpQ1utvZZPgH02_9a760a2625a4aa6686ecb583113dc8c5c17a093b.jpg
    OEM has NO plastic film, MOST Replicas have the film, but even if they don't they could be replicas.
    OEM:
    AWYA9YWSBX47X0uD17zBkatc6-Uc1GTtawJyROfu_0066155c841a69e9338b0adcd09fe4a1c010e63c.jpg
    Replica:
    R0nk4nYw_AAt-I6fLRkK7fDh_83TcOtNZYJSSwg8_2f1da0b38042be66f9e3a76be0116f4c6110f6e2.jpg
    The backside is better molded and crisper on OEM, especially obvious in the "TOYOTA" lettering, if there's no toyota lettering, they are not OEM.
    OEM:
    -pL4HT_FpNB42YeSvVOU5yFZU8obowb16KKL5xUe_ae9614d3a26d761042d4a5af6f6e1d319618827b.jpg
    Replica:
    oWjKrGWTtYYhN_rFjuQa_Bgq7-AVoO_LnSLD_tAp_9596ff9d0a030c0abbf4a2ac770a07e4bdeceb15.jpg
    Thank you for making it this far down the post, if you have found this information useful, please consider visiting where you will find the best version of the replica along with some other Tacoma goodies.
    DannyR, japjoe7, pingo2013 and 39 others like this.
  2. Aug 3, 2019 at 12:58 PM
    Saeros
    Saeros #dealermole
    Canada, Eh!
    2022 Venza Limited
    Well done sir!
    danmtchl likes this.
  3. Aug 3, 2019 at 1:04 PM
    H6G
    H6G Well-Known Member
    Far from home...
    ‘18 Blk. Pro/ ‘17 GT350
    '22 Pro suspension/ Custom Deaver springs/ ECGS and...
    Notice how the word 'Radiator' is spelled on the replica box.....
  4. Aug 3, 2019 at 1:05 PM
    FreshMexicanTaco
    AJ
    San Diego
    I hadn't noticed that! I'll make note of that thanks!
    danmtchl and H6G[QUOTED] like this.
  5. Aug 3, 2019 at 1:06 PM
    Buck Rogers
    Buck Rogers Well-Known Member
    LA (Lower Arkansas)
    96 Taco, 07 FJ gone but not forgotten, 19 Taco
    One post with pictures is worth a thousand without.
  6. Aug 3, 2019 at 1:08 PM
    dlanzer
    dlanzer Well-Known Member
    Derreck
    PA
    2019 TRD Off-Road DCSB 4x4 SSM Premium & Tech Package
    Wow, I didn’t realize the garnish got so steep. When I purchased my OEM garnish it cost about $50.
  7. Aug 3, 2019 at 1:10 PM
    FreshMexicanTaco
    AJ
    San Diego
    Toyota raised the prices in July, they change pricing very 6 months so we know that at least for the next 5 months OEM garnishes are not likely to be any cheaper than $250
    danmtchl, Santa Fe Ranger and H6G like this.
  8. Aug 3, 2019 at 1:19 PM
    FreshMexicanTaco
    AJ
    San Diego
    Here's some asshole trying to pass a Replica as a OEM but charging even more than OEM
    33! SOLD Already!
  9. Aug 3, 2019 at 1:20 PM
    VB25
    VB25 Well-Known Member
    2018 TRD OR ACLB AT
    I bought a 100% OEM garnish a month and a half ago for $52 US from toyotaparts4u eBay seller. The proper sensor wire harness was like $25 as well. 2016-2017 Grille which I added the garnish to was $375 US. Daamnn Toyota is up to something obviously.
    02Duck and danmtchl like this.
  10. Aug 3, 2019 at 1:25 PM
    Epoch
    Epoch Active Member
    2018 Quicksand Tacoma TRD Off-Road
    I think I paid $150 for mine a year ago, is it just artificial scarcity driving the price up? Certainly Toyota doesn’t care about an aftermarket community putting a different grill on...
  11. Aug 3, 2019 at 1:25 PM
    AZn8v
    AZn8v Well-Known Member
    2019 TRD OFF-ROAD
    Solid post. I just checked and indeed it looks like the legitimate $49 Ebay OEM Garnishes are no longer available. I was able to buy an OEM grille an extended harness and the garnish for $270 total last month.
  12. Aug 3, 2019 at 1:26 PM
    VB25
    2018 TRD OR ACLB AT
    They actually do care. The more trucks around that have the grill, the less “exclusive” the 2020 TRD pro will appear to buyers.
  13. Aug 3, 2019 at 1:32 PM
    H6G
    Far from home...
  14. Aug 3, 2019 at 1:32 PM
    AZn8v
    2019 TRD OFF-ROAD
    OP indicated a few days ago you still had several of the OEM available.....Is that still the case?
  15. Aug 3, 2019 at 1:34 PM
    FreshMexicanTaco
    AJ
    San Diego
    EXACTLY, like I said, its ok to use replicas but its not ok to sell and price replicas as OEM. Of course now that Toyota sells its garnishes for astronomical prices 50 for a fake doesn't sound that bad.
  16. Aug 3, 2019 at 1:35 PM
    FreshMexicanTaco
    AJ
    San Diego
    I do, unfortunately I cannot get any more for a good price so the ones I still have I am only selling bundled with my TRD Pro grilles.
    danmtchl and Saeros like this.
  17. Aug 3, 2019 at 1:37 PM
    AZn8v
    2019 TRD OFF-ROAD
    Gotcha......I don't need one but if anyone does it would be a good time to get one from you.
  18. Aug 3, 2019 at 1:50 PM
    Santa Fe Ranger
    Santa Fe Ranger Active Member
    Tony
    2019 Quicksand Tacoma TRD Off-Road
    I got my grille and garnish from the OP. Arrived in perfect condition and is a quality product. I purchased it with the OEM garnish pre-installed and black Letters ( ). Works perfectly on my 2019 TRD Off-Road with TSS.
    BTW, I priced the OEM garnish a couple of weeks ago at my Toyota dealer and even the dealer was shocked that the price had risen to about $400 JUST FOR THE GARNISH. I guess Toyota doesn't like the fact that a TRD Off Road truck looks like a TRD-PRO truck with a few easy mods (grille, wheels, etc.)?
  19. Aug 3, 2019 at 2:26 PM
    pro_rome
    pro_rome Active Member
    California
    ‘19 Super White TRD Pro MT
    I’ll take it! PM sent
  20. Aug 3, 2019 at 2:37 PM
    5150 Taco
    5150 Taco Well-Known Member
    Pete
    Paso Robles
    2019 TRD Off Road Quicksand
    In the process of doing the Kicker Speaker Upgrade. TRD PRO grille.
    I have a 2019. How well does your grille fit? Do you guarantee the product?
