TRD pro 4 runner rims with stock TRD Sport tires?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Sgrif513, Dec 1, 2018.
  1. Dec 1, 2018 at 10:59 PM
    Sgrif513
    Sgrif513 [OP] Well-Known Member
    2019 Cement TRD Sport DCSB
    Hoping for some help with this. I just bought some TRD pro 4 runner wheels (17 X7) FOR MY 2019 TRD Sport. Can I use the stock tires (Toyo A 30s) with these wheels or is the wheel not wide enough? Tried to have them mounted today and tire shop says the wheels are not wide enough. Thanks!
  2. Dec 1, 2018 at 11:05 PM
    dc2’s
    dc2’s Well-Known Member
    California
    2017 Toyota Tacoma trd 4x4 off road
    Added a driver
    What’s the tire size and brand on your stocks?
  3. Dec 1, 2018 at 11:12 PM
    Sgrif513
    TOYO OPEN COUNTRY A30 P265/65R-17
  4. Dec 1, 2018 at 11:15 PM
    Rainoffire
    Rainoffire Well-Known Member
    2017 QS DCLB TRD Sport
    Yes
    They will fit.
    I ran my stock Toyos until my MT ATZ3s came in.
    Sgrif513[QUOTED][OP] likes this.
  5. Dec 1, 2018 at 11:17 PM
    Sgrif513
    That's good to hear. I want to run the stocks until it's time for new tires. Thank you!
  6. Dec 1, 2018 at 11:22 PM
    Rainoffire
    I believe the size of the TRD Pro wheel is the same as the TRD Sports anyways.
    Tire shop might be smoking something.
    Edit: a word
  7. Dec 2, 2018 at 1:56 AM
    Amanelot
    Amanelot Member
    Texas
    2016 MGM TRD Sport DCSB
    Where are you at OP. I might be able to help
  8. Dec 2, 2018 at 7:32 AM
    Sgrif513
    I'm in southern California.
  9. Dec 2, 2018 at 7:33 AM
    Sgrif513
    The stock wheel is 7.5 inches wide where the pro wheel is 7 inches wide. I'm gonna try another shop for sure.
    shakerhood likes this.
  10. Dec 2, 2018 at 10:17 AM
    Amanelot
    Amanelot Member
    Texas
    Too far away!
  11. Dec 2, 2018 at 10:24 AM
    Sgrif513
    Dang! Lol. Thanks for the offer.
  12. Dec 2, 2018 at 10:31 AM
    whoispurplegoo
    whoispurplegoo Well-Known Member
    SE Florida
    2018 MGM Sport 4x4 DCSB
    You can, but it’s not in the width range of most 265/65R17 tires, which is usually a minimum recommended rim width of 7.5 inches. This is probably why the shop won’t put them on.
    Your tires will bulge, but I’ve seen a few people here run the stock A30s on the 4R wheels. I didn’t like how it looked, so I went with new tires when I got the wheels.
  13. Dec 2, 2018 at 12:48 PM
    Sgrif513
    Thanks. It sounds like a likely reason that wouldn't do it. Thank you for the info!
  14. Dec 2, 2018 at 1:01 PM
    Sgrif513
    I'm curious. Which tires did you go with?
  15. Dec 2, 2018 at 1:10 PM
    whoispurplegoo
    SE Florida
    Yokohama Geolandar G015 in 265/70R17 in a standard load rating. A little more aggressive look without going to a heavy A/T tire.
    Stocklocker and 09 Redneck like this.
  16. Dec 2, 2018 at 1:29 PM
    Sgrif513
    Thanks. Your truck looks awesome!
  17. Dec 2, 2018 at 4:58 PM
    The_Devil
    The_Devil Well-Known Member
    E
    2018 Tacoma TRD Off-Road
    DIY Tonneau, Toolbox, Lift, TRD Wheels, TRD Grill
    My understanding isthe Sport has on road tires so this may not apply to you.
    The 265/65R17 is likely intended for a 7.5" wheel as others have suggested.
    I would not air down thatt tire on a 7" wide wheel. Your chances of losing the bead off road and damaging the wheel, truck. etc. Is higher.
  18. Dec 2, 2018 at 5:04 PM
    Amanelot
    Amanelot Member
    Texas
    Those tires, on those rims hurts to look at. Makes my skin crawl. I'm not trying to be a dick, but that does not look safe
  19. Dec 2, 2018 at 5:13 PM
    The_Devil
    E
    I made an earlier comment about not being right for Off-road use. Looking at the photos of the bulging, I would also point out that hard on-road braking while cornering, could also cause the bead to slip and the reulting loss of vehicle control could be a disaster. New tires highly recommended
  20. Dec 2, 2018 at 5:37 PM
    Amanelot
    Amanelot Member
    Texas
