TRD lift kit w/1/4” top hat spacers
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Taco dv, Feb 20, 2025.
  1. Feb 20, 2025 at 12:13 PM
    Taco dv
    Taco dv [OP] Well-Known Member
    2020 Tacoma TRD off-road
    I’m going to install the TRD lift kit soon and was thinking about adding 1/4” top hat spacers up front to compensate for possibly sagging stock coils being that they have 70k miles on them. I want to achieve the full 2” lift. Any issues with that? 1/4” spacer would equal about 1/2” in extra lift. With such a small spacer I’m assuming there wouldn’t be much of a problem. Any feedback on this would be great.
  2. Feb 20, 2025 at 12:34 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Don’t assume your coil springs are “sagging”. Measure the distance between the center of your hub to your fender flare (both sides) and report back.
    Do you have any significant permanent added weight?
    TS4x4 likes this.
  3. Feb 20, 2025 at 1:10 PM
    Taco dv
    I currently have 1” top hat spacers with stock everything, so wouldn’t be a good comparison measurement. Don’t plan on adding any weight.
  4. Feb 20, 2025 at 1:19 PM
    gudujarlson
    Minnesota
    Sure it would. You can simply subtract the effect of the spacer.
    You need measure things, otherwise everyone can do nothing more than guess the answer to your question.
    My guess is that your coil springs are just fine and that combining spacers with increased-preloaded shock is a bad idea.
  5. Feb 20, 2025 at 1:57 PM
    Taco dv
    Is a TRD front shock, (basically) a 5100 shock, actually preloaded on top clip? I’ve seen mixed opinions on this. There is no pre-load spacer, and coil is still full length?
  6. Feb 20, 2025 at 2:08 PM
    poopshute
    poopshute Well-Known Member
    Colorado
    2017 Tacoma TRD Pro Storm Trooper
    A 1/4" top hat spacer is probably the only "safe" top hat spacer. Anything more and you're asking for trouble as your shock acts as the bump stop from full g-outs.
  7. Feb 20, 2025 at 2:09 PM
    Taco dv
    that was my thinking. It’s small enough to not cause problems, and get another 1/2” lift
    poopshute[QUOTED] likes this.
  8. Feb 20, 2025 at 2:11 PM
    poopshute
    Colorado
    Westcot designs uses a 1/4" top hat spacer with their TRD Pro shock kit and it hasn't caused issues for customers. You should be fine with a 1/4" but please don't go any bigger unless you drive your truck on pavement only and don't hit bumps hard (and what's the fun in that?).
  9. Feb 20, 2025 at 2:25 PM
    Taco dv
    Here’s the whole story. I currently have what actually measures 1 1/4” top hat spacers, so yielding about a 2 1/2” front lift. But, all the lift is from those spacers which I feel is not good. I am switching to the TRD lift kit which is a 2” lift. I don’t really want to go any lower than my current 2 1/2” lift I have now with the spacers. I could actually be fine with a full 2” lift if the TRD kit is accurate, but don’t want anything lower. I will keep my current 1.5” lift blocks in back, vs using the only 1” block that the TRD kit comes with. (I like a slight rake). So in a nutshell, I’m just getting rid of the larger top hat spacers and doing the TRD shocks all the way around.
    I’ve watched a few videos of TRD off-road trucks with the factory TRD lift, and they are plenty capable off-road for my needs. I had 285/75/16 k02’s but I downsized to 265/75/16’s.
    I like the “stock +” build/look.
    poopshute likes this.
  10. Feb 20, 2025 at 5:53 PM
    TSAVO
    TSAVO Well-Known Member
    Tempe, AZ
    2018 TRD OR
    I've been running a 1/4" spacer with this setup for 2+ years now with no issues. I did it to help with the heavier aftermarket front bumper that I have.
    Taco dv[OP] likes this.
  11. Feb 20, 2025 at 8:12 PM
    Taco dv
    Can you confirm you are running that with the factory TRD lift kit? If yes, how happy overall are you with that setup now that you’ve been running it a while?
  12. Feb 20, 2025 at 9:42 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Where did you get that 1/4 spacer yields 1/2 lift. I have it on driver's side for imaginary taco lean. But my both sides are at the same ride hight. Just curious
  13. Feb 20, 2025 at 9:46 PM
    Taco dv
    It’s my understanding that a top hat spacer results in the spacer thickness X2. So basically a 1” spacer for example, will yield 2” in lift height.
  14. Feb 20, 2025 at 9:49 PM
    Vlady
    Issy, WA
    That's the theory, but reality is totally different. I'm going 5th year on the lift and still scratching my head what da ef I put that spacer in for.
    Your front lift is also affected by the rear lift. So tread tw carefully
  15. Feb 20, 2025 at 10:54 PM
    N minus 1
    N minus 1 Ruff Road Designs
    San Diego, CA
    2014 TRD Off Road
  16. Feb 21, 2025 at 2:57 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    OP, forget the TRD rebranded and overpriced system and just buy Bilstein with more settings and a better warranty. Set them on the top setting and it will look perfect with the 1.5 blocks. I use the 5100s with a 1/4 spacer on the driver's side for the Taco Lean and a 1-inch block and it sits almost level with an ever so slight rake.
    Taco dv[QUOTED][OP] likes this.
  17. Feb 21, 2025 at 4:02 AM
    TSAVO
    Tempe, AZ
    2018 TRD OR
    Yes it is the TRD lift. It works as well as you could expect it too, save some money and just buy the 5100’s, same parts basically, different color and more adjustment options. The only reason I got these instead of 5100’s is because I have a friend that works at Toyota and they got them for me cheap.
  18. Feb 21, 2025 at 7:33 AM
    Taco dv
    I already bought the TRD lift kit. The lift parts only, not the grill. I debated hard on this or the 5100’s. I read a lot of people complaining about the stiff ride with the 5100”s set to top clip. I know TRD are supposed to be the same or a re-badged 5100, but if you look at side by side pictures they are different and possibly tuned differently. Who knows. Toyota had to have done atleast some testing and tuning with them. I also have a white TRD off-road truck with the red 4x4 off-road badging, and the TRD skid plate. The TRD shocks just match my truck color scheme perfectly. I know, who cares, but I like the looks of them, and they seem to perform really well off-road from a few videos I’ve seen.
    FunknNasty likes this.
  19. Feb 21, 2025 at 11:00 AM
    blu92in99
    blu92in99 Hates everyone, equally
    Elk Grove, Ca
    Same, when I still had my 3rd gen. I had the TRD lift kit, with a 1/4" spacer on the passenger side and 3/8" spacer on the driver side, to offset the bumper/winch and Taco lean. The winch/bumper brought the nose down 1/2" on the passenger side and 3/4" on the driver side. The spacers restored that height. Ride quality was unaffected to me.
    I also installed longer studs in the strut mounts when I added the spacers.
    TSAVO[QUOTED] and Taco dv[OP] like this.
  20. Feb 21, 2025 at 12:25 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    I don't use any spacers, and am perfectly level all around. Even with the extra weight of my rear steel bumper.
