TRD Bead Lock Ring Torque Spec.
Discussion in 'Wheels & Tires' started by ttbaja, May 26, 2016.
  1. May 26, 2016 at 5:20 PM
    ttbaja
    ttbaja [OP] Member
    Hi Everyone,
    Can someone please tell me what is the exact torque spec for the 12 screws on the TRD Bead Lock Ring?
  2. May 26, 2016 at 5:22 PM
    SixthSnail
    SixthSnail I have no idea what I'm doing
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
    Aren't they fake beadlocks? Are you sure the ring is removable?
  3. May 26, 2016 at 5:36 PM
    ttbaja
    ttbaja [OP] Member
    Not a fake. I bought a genuine OEM TRD Bead Lock Ring from my Toyota Dealer for $72. Yes it's removable. The ring is fastened to the wheel rim with 12 torx screws.
  4. May 26, 2016 at 5:41 PM
    SixthSnail
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
    These ones right? The beadlock is fake. Toyota doesn't make real ones I don't think.
    I just didn't know the ring came off. Since they don't actually function as a beadlock, the torque spec shouldn't be all that important. Just throw some loctite on the screws and fasten them securely.
    ToyoTaco25 likes this.
  5. May 26, 2016 at 5:47 PM
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    Yup, not a real beadlock ring. It comes with what looks like blue locktite on the little bolts from the factory. I've removed mine several times and never reapplied any locktite, and have never had any of those bolts come loose.
  6. May 26, 2016 at 6:00 PM
    ttbaja
    ttbaja [OP] Member
    Yes that's the ring. Okay I'll just hand tighten them. Thanks guys.
    SixthSnail[QUOTED] likes this.
  7. Jun 30, 2020 at 7:50 AM
    Age315
    Age315 Well-Known Member
    AJ
    Castle Rock, CO
    2016 BBP Yeti Mobile
    TRD Baja Kit with JBA UCA's 1/2 inch spacer on top, Medium Dakars with BAMF hangars and super bumps all around. 285/75/16 Cooper Discoverer AT3 XLT's on graphite TRD faux beadlock wheels. Pro skid powder coated black with Pelfreybilt aluminum mid skid and aluminum gas tank skid.
    I know this is an old thread but I was looking for the same thing. I found some instructions and they say 75 inch pounds or 6.5 ftlbs.
    eurowner likes this.
  8. Jul 2, 2020 at 2:22 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Anyone found a suitable replacement for the plastic "washers"?
  9. Jul 2, 2020 at 6:06 PM
    Age315
    AJ
    Castle Rock, CO
    I got these and just put them on and it was the closest to the factory size I could find. 20200702_182336.jpg
  10. Jul 4, 2020 at 9:21 AM
    eurowner
    eurowner Duke Sky
    Scoty
    Thanks!
    Age315 likes this.
  11. May 24, 2022 at 5:48 AM
    microsnook
    microsnook Well-Known Member
    '20 TRD OR MGM MT
    mine has come loose, but I tightened it and had no luck fixing it? Its still loose....
  12. May 24, 2022 at 5:53 AM
    eurowner
    eurowner Duke Sky
    Scoty
    Use fresh Blue threadlocker and torque to spec 75 inch/pounds
  13. May 24, 2022 at 8:28 PM
    microsnook
    '20 TRD OR MGM MT
    I removed all of them and like the look and don't have to worry about it anymore. Thank you
  14. May 25, 2022 at 8:30 AM
    clenkeit
    clenkeit Well-Known Member
    Colin
    Lakewood, CA
    2010 White DCLB TRD Sport
    If you're not looking to use them down the road you can surely sell your old lock rings and make some extra $$. Parts for these wheels are in fairly high demand.
    microsnook[QUOTED] likes this.
  15. May 25, 2022 at 8:33 AM
    microsnook
    '20 TRD OR MGM MT
    This is a great idea.
    Maybe I’ll list them soon. Maybe someone will want them. I know after looking for a spare they’re hard as hell to find these wheels.
