Transmisson cooler
Discussion in '3rd Gen. Tacomas (2016-2023)' started by trucknrv, Dec 31, 2023.
  1. Dec 31, 2023 at 9:57 AM
    trucknrv
    trucknrv [OP] Active Member
    Western MA
    22 TRD sport
    Snowsport plow with front receiver hitch, Access lorado tonneau cover, AVC ventshades, Covercraft seat covers, Husky floor mats, K-N filter, Hydraulic lift arms for hood, Factory black running boards, Direct cable from battery for jumper cables, Oil plug valve, Front anytime camera, Baja design fog lights, Bed mat, Borla exhaust with black tip, TRD skid plate along with stainless cat plate, 6 new speakers, Puddle lights, Floorwell lighting, Aftermarket heated seats, Interior LED lights, Swing tool box for the bed, Redarc brake controller, Blackout kit, Ceramic coated, Timbren load boosters, LED bed lights, Zprecision bigger cup holder, Drivers grab handle, License plates negated when in reverse, Sequential smoke mirror lights, Bumper step, 3rd brake light smoked out, Factory painted door edge guards, Door sill protectors, Mesa stick shift with additional buttons for the ECT, Extra 110V plug for the back seat and anytime 400 W plug for the bed, OTT tune, Protech for radio and dash film, Bigger radio knobs, LED hood light, Added LED strip backup light under the tailgate, AlphaRex tail lights. I am sure there is more but wife is starting to give me the side eye to add more! Like I heard they are not mods but it's a BUILD!
    I currently own a 2022 TRD Tacoma double cab 4x4 SB with an automatic transmission. I plan on towing a travel trailer cross country when we retire in a few years. The gross weight of the trailer will be 4000 lbs. so that might be pushing its limits a bit. The Sport doesn't come with a tranny cooler that I see but I believe the off road does. Was wondering if the best thing for me to do is to add a transmission cooler? I would think towing between 300- 500 miles a day that a cooler would be a great idea. I am semi handy but not sure if this is something I should attempt as it is something I want done right. Thanks in advance!
  2. Dec 31, 2023 at 10:03 AM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
  3. Dec 31, 2023 at 11:54 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    The transmission cooler was eliminated by year,,, not model, I think it was a midyear change in 2020.
    4,000 unloaded will be miserable to either tow fully loaded, or miserable to load and have to constantly pick things up along the way, cause you are counting calories to make weight.
    mic_sierra likes this.
  4. Dec 31, 2023 at 1:59 PM
    trucknrv
    Western MA
    22 TRD sport
    It's rated at 6400 .. I have the OTT tune, timbren load boosters, brake control obviously and have a equalizer distribution setup to help distribute the load. It won't like hills but should do fairly well on the flats. Just think a tranny cooler would help additionally.
    Gatafly, TacoManOne and 3JOH22A like this.
  5. Dec 31, 2023 at 2:14 PM
    mattleg
    mattleg Well-Known Member
    Kansas
    2020 OR DCSB AT 4WD
    It still has a transmission cooler located in the main radiator end tank. The extra air cooler is what was eliminated on later 2020's. It was pretty small anyway.
    Probably not strictly necessary, but a good idea for longevity of fluid and transmission. You may want to use a scan gauge or similar first, see how you feel about the temps before making the effort.
    AmateurTaco1313 and Chew like this.
  6. Dec 31, 2023 at 5:53 PM
    KeithF40
    KeithF40 Well-Known Member
    Keith
    2019 Black Toyota Tacoma SR V6 4x4 Double Cab
    dont think it makes much of a difference but was looking into this myself as well
  7. Dec 31, 2023 at 5:59 PM
    Gfenza89
    Gfenza89 Well-Known Member
    2024 Tacoma SR5 4x4 DCSB
    Still have the trans cooler in the radiator and another trans cooler/warmer that sits next to front section of the transmission under the truck. It’s cooled and warmed by the engine coolant plus another similar unit that cools the engine oil with engine coolant
  8. Dec 31, 2023 at 6:04 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Pin the transmission thermostat open. That's about it.
    PTSDTherapy and mic_sierra like this.
  9. Dec 31, 2023 at 6:12 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    The OTT guys are a great group of guys.
    And developed the best tune for the 3.5 Tacoma.
    But it’s still going to be a less than fun towing a 4k lbs. camper.
    Add wind resistance and it’s an anchor.
    The 3.5 and 4.0 are equal in terms of “power”.
    But the 4.0 makes torque a little lower in the RPM range.
    You’re going to have to use your gears and let the engine eat.
    Like run at or above 2,750-3,000 RPM or more.
    I guess what I’m saying is, if you plan to tow the camper a lot.
    I’d maybe look at a full size truck.
    Or you could add boost to the 3.5.
    But by the time yo do that, you could have traded yours in for a full size.
    Don’t get me wrong, I’m not saying the Tacoma can’t do it.
    It will, I’ve done. But only because I had to.
    As for the trans cooler.
    Maybe this will help
    https://www.tacomaworld.com/threads...l-toyotas-write-up-with-many-pictures.526283/
    Chew likes this.
  10. Jan 3, 2024 at 12:08 AM
    Blak Shinobi
    Blak Shinobi Well-Known Member
    taco
    2020 MGM Sport DCSB 4x4
    n/a
    you said you will retire in a few years , well you have some time to figure it out :)
  11. Jan 3, 2024 at 5:41 AM
    Hairless_Ape
    Hairless_Ape Well-Known Member
    South Jersey
    2021 F150
    Installing a trans cooler is not something you have to be worried about "doing right". If you can install a hose clamp, you can install a trans cooler. Any anxiety you might have will be worse than the install.
    Actually it's 5 hose clamps, a self tapper or two, and maybe an existing bolt.
  12. Jan 3, 2024 at 4:11 PM
    Da Voke
    Da Voke Well-Known Member
    Canada
    2020 DCLB Sport (Stolen and recovered)
    I’ve got a good friend that is a master mechanic. I asked about adding one to my 2020 and if he thought it was necessary. Long story short - synthetic transmission fluid is a different animal than traditional. It can take higher temperatures and still be very secure. What he actually said was “if it makes you feel better add a cooler but an external cooler hose failure is probably fatal to a transmission, and it happens”
  13. Jan 3, 2024 at 5:01 PM
    Williston
    Williston Well-Known Member
    New England
    2014 Tacoma SR5 4x4 DC SB V6 AT Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. OEM All-Weather floor mats (summer).
    Installing an external auxiliary transmission oil cooler is a great thing to do even if you never intend to, or end up towing anything. If you are thinking of towing something that is approaching 4,000 lbs, it's a no-brainier. Get the biggest one that will fit in front of the radiator/condenser and never look back. There is plenty of room to add one on a Tacoma. Don't by-pass the factory in-tank cooler and don't worry about over-cooling the transmission fluid. If it gets cold enough for that to happen, you truck probably isn't going to start anyway. It is a very easy job to do yourself, but if you're worried about having the skill to do it, an honest shop should be able to do it in about one hour of labor. Again: get a large one and from a name brand. (Hayden, Tekonsha, B&M)
  14. Jan 3, 2024 at 5:10 PM
    ernscott
    ernscott Well-Known Member
    2021 Tacoma
  15. Jan 3, 2024 at 5:16 PM
    mic_sierra
    mic_sierra Toshiba HDDVD is the future
    Elsewhere
    '21 DCSB TRD Sport 4x4 Auto
    x2 on this... simple mod that is the cost of a cotter pin
    That is because you cannot see it, it is a cooler within the radiator. Look down at your radiator and you will see the transmission lines as well as the engine coolant lines coming and going.
    Clean setup. My compliments - that's wassup.
    Williston and ernscott[QUOTED] like this.
  16. Jan 4, 2024 at 5:46 AM
    Hairless_Ape
    South Jersey
    2021 F150
    It is far more likely that the integrated transmission cooler inside the radiator is going to leak internally, mixing trans fluid and coolant, than it is a hose might rupture. And when that happens there is a 100% chance of catastrophic failure. Any master mechanic whos worth anything would know that.
    33yrsoftoys likes this.
  17. Jan 4, 2024 at 5:50 AM
    ernscott
    2021 Tacoma
    This is why I always take the extra step to run metal lines and protect them wherever they run close to any other metal surface. Highly recommended over the long lengths of rubber hose for sure.
  18. Jan 4, 2024 at 6:14 AM
    Schlappesepple
    Schlappesepple Well-Known Member
    Joe
    2020 4Runner ORP
    How does one get the title of master mechanic? Seems like it's always self-proclaimed. People can be masters of different areas too (e.g., I prefer transmission shops to work on my transmissions, not "mechanics").
    Anyways, for the OP: someone else already said it, but my advice is always start with the scangauge or ultra gauge and just monitor your trans temps. This will tell you whether or not you need the cooler. You'd probably end up buying one anyway, so it's kind of a wash to me.
    This also reduces your investment up front, in case you try it with the Taco a few times and decide that truck / trailer combination doesn't work for you. (Although it sounds like you've done some towing already based on your setup, so you may have a good idea of how it's gonna go.)
  19. Jan 14, 2024 at 7:00 PM
    k_j_souv
    k_j_souv Well-Known Member
    NorCal
    3G OR DCSB, Dual Case, 42s
    I decided on the Mishimoto cooler. It floats over the OE components allowing me to still utilize the OEM cooler. It uses 3 OE bolt location. It left the passenger side available for an oil cooler and steering cooler. IG user @maxari_co
    mic_sierra and lamjam like this.
  20. Jan 15, 2024 at 4:53 AM
    ClassyTacos
    ClassyTacos National Treasure 3, Times a ticking Nickolas
    Papalote
    Florida
    2017 TRD Sport 4x4
    Stockish
    I also did the Mishimoto with the fan wired to a simple on off switch not a temp switch. I reused the factory mounts with some minor fab work.
    Link to the cooler -- https://amzn.to/3RXzo2E
    CemenTRDgen, k_j_souv and mic_sierra like this.
