Transmission won't shift into 5th gear.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by clayhopkins1, Dec 28, 2016.
  1. Dec 28, 2016 at 7:28 AM
    clayhopkins1
    clayhopkins1 [OP] Honey_Badger
    DAVID
    ST PETERSBURG
    Morimoto 5K, Spidertrax 1.25", 265/75r16 BFG KO2s on black TRD wheels, Bilstein 5100s front at 2.5" and 1" block rear with 5160s, SOS Concepts Hybrid bumper, Warn M8000 synthetic, Trail Recon 22" Light bar, Walmart slim profile LEDs (as reverse lights), All alpine interior audio with Navigation, LED interior lights, "trailer plug" mod, locker mod, fog light mod, Debadged everything, custom sheet metal stiffener for tailgate, Cali Raised ditch brackets w/ Rigid Pods, firestik 4' antenna, cobra handheld cb (currently broken), Amazon (S-Pod clone).
    I have a 2015 Tacoma double cab trd off-road with the 4L V6 and auto tranny. The transmission just started to act weird after I had an oil change done. The transmission downshifts slowly like if I'm slowing down to make a turn and then push the gas pedal to speed up on a road it'll jerk really hard like it's downshifting and then when I get on a road that's 45 or 55 the transmission won't shift into 5th gear or so it feels because it'll be at 3K rpm and if I let go of the throttle pedal the rpm will go down to 15-1800 rpm but is sluggish but if I even slightly touch the throttle it'll jump straight to 3K rpm. I want to avoid the speakership if possible. The truth has 35K miles on it and has a 2inch lift with 285s and a tube front bumper. I need help as this is my only vehicle and I need it to get me from home to the military base I work on which is 20 miles away on 45-55mph roads and don't wanna grenade my tranny or put unnecessary wear from rpm on my engine.
  2. Dec 28, 2016 at 7:33 AM
    randd
    randd Well-Known Member
    Eric
    Sunbury Ohio
    2015 4x4 DCSB Black
    You stated that this starts after you had the oil changed. I wonder if they accidentally drained your transmission fluid. It happens way more than you would think with this generation. Start with having the transmission fluid checked.
  3. Dec 28, 2016 at 7:37 AM
    glk21c
    glk21c Well-Known Member
    MD
    2007 Silver Tacoma TRD Sport 4x4
    a long shot but I wonder if whoever changed your oil mistakenly removed the drain plug on the transmission first, thinking it was the oil pan, and quickly put it back in after realizing there was red fluid draining out. Low trans fluid can cause all kind of weird issues in our trucks. I'm willing to bet if they did that then they probably would not know how to put trans fluid back in, let alone the proper procedure for putting it in.
    Good luck
  4. Dec 28, 2016 at 7:41 AM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    Check your oil level (engine oil). If they drained trans fluid instead of engine they may have super overfill ed the motor oil
    NAAC3TACO likes this.
  5. Dec 28, 2016 at 7:45 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    That mistake has been done before
    bigfoote13 likes this.
  6. Dec 28, 2016 at 8:22 AM
    clayhopkins1
    DAVID
    ST PETERSBURG
    That's a possibility I didn't think about. I just hope it didn't compromise the integrity of the tranny
  7. Dec 28, 2016 at 8:27 AM
    gainman
    gainman Semper Fi
    SW Florida
    Stuff
    if you catch it and correct it early enough it will be fine. Check it soon though.
  8. Dec 28, 2016 at 10:01 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Uh - Oh! Somebody dun fucked up. :anonymous:
    Pigpen likes this.
  9. Dec 28, 2016 at 10:09 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Curious, why wouldn't you want to go to the dealership? You have a year old truck, under warranty, with an expensive, major component experiencing issues?
    I'd agree on the trans fluid check, hopefully it wasn't you who changed the oil. ;)
    Firebird likes this.
  10. Dec 28, 2016 at 10:58 AM
    clayhopkins1
    DAVID
    ST PETERSBURG
    I didn't wanna go to the dealership because I have "lift kit, tires and other components and they would find a way to say they couldn't cover it.
    I checked the tranny fluid and it was almost empty. About a quart came out and there was about 12 quarts of oil in my engine as well. 5 quarts of ATF and 5.5 quarts of more oil later and it is running night and days difference now. First and last time I ever take my truck to someone else for an oil change.
  11. Dec 28, 2016 at 11:01 AM
    T4RFTMFW
  12. Dec 28, 2016 at 11:11 AM
    Firebird
    Firebird Notorious Member
    Phoenix
    Lewisberry, PA
    1993 FZJ80
    Pigpen likes this.
  13. Dec 28, 2016 at 11:42 AM
    randd
    Eric
    Sunbury Ohio
    2015 4x4 DCSB Black
    Glad you got it figured out.
  14. Dec 28, 2016 at 11:51 AM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    And you're not going to the shop that did the oil change and raise holly hell?
    14TACO4X4 likes this.
  15. Dec 28, 2016 at 12:15 PM
    mercerc
    mercerc Well-Known Member
    Carl
    Palmyra NY
    2011 D-CAB Black TRD Sport, JBL with Sat
    leveling kit, Cooper 255/80R17 tires on 4Runner rims, Leer cap, Ovtuned (not yet working), K&N filter, TRD catback, Riderite air bags
    when I take my truck to the dealer they love the lift and big tires.... they worked with me when I had an extended warranty issue so that the lift/tires would not be problem.... anyway I guess it depends on the dealer.
    as for the the transmission fluid, how did you know how much to put in? it is an interesting technique to check your fluid level in the transmission but a useful one. If you did not do the procedure (get it up to temp then check) you should do it. If you want to check the level search for for it this site and you will find tons of articles on it.
  16. Dec 28, 2016 at 12:27 PM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    Wow
  17. Dec 28, 2016 at 2:01 PM
    clayhopkins1
    DAVID
    ST PETERSBURG
    Yeah I took my truck to get a headlight replaced due to moisture and the dealer said they couldn't because I had a bull bar attached and I had an abs problem and wouldn't touch it because of the lift so that's why I don't like to go there anymore
  18. Dec 28, 2016 at 2:05 PM
    clayhopkins1
    DAVID
    ST PETERSBURG
    I looked up the procedure online and looked in the owners manual to see how much is suppose to be in there and then looked up how to check it and what temperature to check and then to check via drain plug.
    I l
  19. Dec 28, 2016 at 2:07 PM
    clayhopkins1
    DAVID
    ST PETERSBURG
    I can't because I got it done 120 miles away when I was out of town.
  20. Dec 28, 2016 at 3:46 PM
    08TRDOFFROAD
    08TRDOFFROAD Well-Known Member
    Dan
    21' Tundra Platinum & 08' TRD Offroad DCSB 4x4
    Bilstein 5100's w/front's set at 1.75", TRD exhaust, Colormatched grill, Illuminated 4wd selector switch, BAMF Bolt on Sliders w/kickout.
    I would still be making a phone call and have a conversation with the manager/owner....completely unacceptable!
    But, if your cool with the fact that they may have severely compromised the reliability and longevity of your truck, then by all means, do nothing...
    TrdSurgie, 14TACO4X4 and wegotajumper like this.
