Transmission won't shift after DIY Transmission service
Discussion in '1st Gen. Tacomas (1995-2004)' started by Jedi Joe, Nov 29, 2018.
  1. Nov 29, 2018 at 12:08 PM
    Jedi Joe
    Jedi Joe [OP] Member
    Joe
    2011 Tacoma Pre-Runner
    Hi all, I went from a 2010 prerunner to this 1997 Deluxe 4wd access cab with the 2.7 and auto tranny. 215k hard miles. Bought it cheap and decided to drain all fluids and start fresh. I just changed the tranny filter and oil (did not flush) and it won't come out of my garage. I can move the shifter but when it tries to change gear nothing happens. Engine revs a little more for a second and then nothing. Dipstick is reading perfect on the "cold" part of the dipstick. Transmission shifted perfectly before I did this...I read in other forums that this thing could happen if you flush the tranny, but I didn't think it would do it if I just drained and refilled. Worried I destroyed it somehow.
  2. Nov 29, 2018 at 12:13 PM
    wheeliest
    wheeliest ///////////////////
    Json
    TMPE AZ
    05-SWB-DCSB-4X4-V6-SR5-SPORT
    NO SWAYBAR, Spacer lift with dirty4's
    how much did you drain and how much did you fill & what transmission fluid did you use?
  3. Nov 29, 2018 at 12:17 PM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    When you drained the transmission fluid, you removed all of the friction material that was suspended in the fluid.
    The only fix is to replace the transmission, or have it rebuilt.
    Was the fluid really dirty?
    Timmah! likes this.
  4. Nov 29, 2018 at 12:24 PM
    BLACK04TRD
    BLACK04TRD Well-Known Member
    Bethesda, MD
    2004 Tacoma TRD, 3.4L, 5spd -- SOLD
    Stock AF
  5. Nov 29, 2018 at 12:27 PM
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
    Probably not enough fluid. How much did you put in with a Drain and Fill?
  6. Nov 29, 2018 at 12:27 PM
    vanrynd
    vanrynd Well-Known Member
    dan
    West Chester, Pa
    2017 Off Road DCLB
    WIP
    yikes:facepalm:
  7. Nov 29, 2018 at 12:43 PM
    Jedi Joe
    Joe
    I caught a gallon and then I guessed about a quart came out when I removed the filter. Added as close as I could the amount that I changed. Yes all the fluid was disgusting and black. Idiot who had it before me didn't take care of it at all. I've added another quart just to see, same thing. Valvoline full synthetic Dex II/III approved. Not Toyota but correct fluid.
  8. Nov 29, 2018 at 3:03 PM
    LazyEye
    LazyEye Active Member
    2001 Tacoma double cab 4x4
    i had no idea something like that could happen with a simple drain and fill and filter change!
  9. Nov 29, 2018 at 3:07 PM
    v5ensx
    v5ensx CARB legal is not CALI legal
    really? by draining the fluid, you now have to repair the transmission?? That must apply to engine oil change too then....
  10. Nov 29, 2018 at 3:09 PM
    v5ensx
    So vehicle shift into R N D etc but wont move? Is that the issue?
    Did you happen to unplug any harness/pigtail from the multiple solenoid by accident when removing filter for better access? If so, that might be your problem.
    Another thing to consider is, did you by chance move/adjust or take off the shifter rod attachment to the neutral safety switch. Highly unlikely cause, but a slightly off-alignment to the switch can cause your issue as well.
    One more thing and I seen it happen before many time. You didn't drain the ATF fluid and accidentally top off your motor oil instead right?
  11. Nov 29, 2018 at 3:35 PM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    It does happen but not that often. Happened to me once. Was doing a service on a car at work which included a drain and fill of the transmission. The fluid was beyond black, who knows if it was ever changed. The car had well over 100K on it.
    I finished the service, put the car in reverse and it didn't want to move (it had the correct amount of fluid). From that day we tell customers with high mileage cars and lack of maintenance that it could happen.
  12. Nov 29, 2018 at 3:42 PM
    OneWheelPeel
    Phoenix, AZ
    True but usually they fail in a couple hundred miles. Not much better but still.
  13. Nov 29, 2018 at 3:48 PM
    07regtacoman
    07regtacoman Well-Known Member
    Davis Ca
    07 Silver REG Cab
    Painted arm rests, 2011 front grille,Readylift for 5lug.
    I would let it sit for a couple days but only start it up.Dont try to move it until the third day just to make sure the fluid has lubricated everything.Sounds stupid but we had issues after a fluid change where it had bad shifting and letting it sit worked.
  14. Nov 29, 2018 at 3:51 PM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    Customer paid for labor and Lexus paid for the transmission.
  15. Nov 29, 2018 at 4:28 PM
    OneWheelPeel
    Phoenix, AZ
    Which one was more?
  16. Nov 29, 2018 at 4:45 PM
    02hilux
    Planet: EARTH
    The customer portion, haha
  17. Nov 29, 2018 at 5:21 PM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    Transmission.
  18. Nov 29, 2018 at 5:51 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    You need to go by the actual fluid capacity when you fill it instead of just adding however much you think came out.
    As mentioned, the black particulates were suspended friction materials from deterioted clutches. Sounds like it's time for a rebuild
  19. Nov 29, 2018 at 8:55 PM
    Timmah!
    Timmah! Well-Known Member
    TIM
    This is the correct assessment. When a transmission is abused and the fluid is never changed, excessive wears happens. The black nasty ATF is holding suspended clutch material in it and keeping the transmission shifting properly. As soon as you drain out that old fluid and replace it with new fluid, you lost that friction material. Also, an abused transmission will have sludge build up in it. ATF has detergents in it. When you introduce new fluid with fresh detergents in it, it can break loose some of that sludge and then it can potentially cause problems like blocking passages in the valve body causing the transmission to be starved of fluid.
  20. Nov 29, 2018 at 10:58 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    the big question is... since you replaced the filter are the little gaskets on the filter missing or possibly double gasketed. if theyre not there or double gasketed the transmission fluid wont get pumped into the transmission valve body
    basically the pump wont create suction to pull the fluid into the valve body
