Transmission washer help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bry33, Oct 20, 2023.
  1. Oct 20, 2023 at 7:42 PM
    Bry33
    Bry33 [OP] New Member
    I have 2nd gen, 2006 Pre-runner double cab 4X2 V6, which needs the fluids changed.
    But before I get started doing the transmission ATF change, do I need the drain and fill crush washers, before do the temp check? Or can I do temp check without them?
    I have a feeling that my Toco is low on ATF.
    And if so where can I get the drain and fill crush washers and other washers which will be needed . . . and part numbers would be nice to have also?
    My research has lead to this, from what I could tell is:
    Transmission
    #35178-30010 crush gaskets/washers for dropping the transmission pan (which have ordered and received). Which is used to change the filter and fluid—would be my guess. I ordered wrong crush washers to my limited knowledge.
    #90301-15004 crush gaskets/washers for drain and fill plug (which I didn’t order).
    Now, (2) different Toyota Dealership (T. D.) told me different part numbers.
    1st T. D. - part #90430
    2nd T. D. - part #35178-30010 crush gaskets/ washers for the transmission pan (which have ordered and received ten (10)
    I’m a little confused now.
    After looking up myself at a parts place online:
    90301-09012 = the black “O” ring used to check the ATF level when the Temp check is done. Now, do I need a new one to proceed to do this temp check?
    Or can I do it without?
    35178-30010 = crush washers for the drain/fill plugs. (Which I have.)
    Can someone tell me if I’m correct?
    Can anyone help me in my research before I start with the temp check?
    Also, the differential fluid change needs to be done. I have the fluid and crush washers for that already.
  2. Oct 20, 2023 at 8:11 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Ideally, you want new crush washers.
    Do I always use new ones? No.
    It’s kind of a pain to change the washer on the check plug in the middle of the procedure.
    If anything, go “easy” on tightening it at first. Then tighten it up good and snug after you do the check.
    You have to remove the check plug at least once AFTER replacing the fluid.
    Dm93 likes this.
  3. Oct 20, 2023 at 8:18 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Usually no need to replace crush washers unless they are completely flattened out or damaged.
  4. Oct 20, 2023 at 8:40 PM
    STOCKTRD
    STOCKTRD Well-Known Member
    In Traffic
    CustomTacos Mafia!
    Nachos, Lemon Heads, My Truck Is Stock!
    Info from the 2nd Gen DIY thread located in the 2nd Gen sticky section located on the top of the 2nd Gen. Tacomas (2005-2015) area:
    Tools:
    24mm socket
    14mm socket
    5mm Allen Wrench
    Hand Pump
    Torque Spec:
    Drain Plug 21 ft./lb DO NOT OVER-TORQUE (YOU'LL STRIP THE PAN/ BOLT)
    Overflow Plug - 15 ft./lb
    Refill Plug - 29 ft./lb
    Parts:
    Drain and Fill - 3 quarts
    $54 Toyota 00289-ATFWS Lexus & Automatic Transmission Fluid WS ATF World Standard, Pack of 4
    Toyota WS ATF fluid 00289-ATFWS
    Full Flush - **13+ quarts
    Fill Plug Crush Gasket - P/N 35178-30010
    Drain Plug Crush Gasket - P/N 35178-30010
    More Info:
    Drain and Refill - https://www.tacomaworld.com/threads/how-to-drain-refill-automatic-transmission.63851/
    Full Flush - https://www.tacomaworld.com/threads/diy-full-flush-for-automatic-transmission.68462/
    Tacoma-2012-TRD-88 and Dm93 like this.
  5. Oct 20, 2023 at 8:45 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Note the specified check temperature was changed from 115-130F to 97-115F per T-SB-0129-08.
