transmission shifts hard after sitting for a week
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dieselfan, Mar 6, 2021.
  1. Mar 6, 2021 at 11:51 AM
    dieselfan
    dieselfan [OP] Well-Known Member
    Joe
    western Pa
    2012 DC TRD 4X4
    Stock
    My 2012 truck shifts kinda hard the first drive in the winter after sitting a week, is this the torque converter draining back?
  2. Mar 6, 2021 at 11:58 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Have you checked the fluid levels?
  3. Mar 6, 2021 at 12:05 PM
    dieselfan
    Joe
    western Pa
    2012 DC TRD 4X4
    Stock
    It was done when new and at proper level.
  4. Mar 6, 2021 at 7:53 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Sounds like a solenoid valve sticking a bit after sitting idle.
    Does it just do it the first time and never after?
    May need a drain and fill.
    12TRDTacoma and TnShooter like this.
  5. Mar 6, 2021 at 9:26 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Can you give us more details of when it does and what gears it seems to shift hard in?
    My truck will shift harder in gears 1-4 when it’s really cold (30 degrees or less)
    And it shifts even harder into 5th gear with a “clunk”.
    This is considered normal. Mines done it since I got it with 27k miles on it.
    I had the dealer inspected it, they said it was normal.
    It has 137k on it now and it still does it.
    Changing the transmission fluid did not help mine.
    At this point, I consider NORMAL for the truck to shift a little bit harder when really cold outside.
    Normal is NOT slamming into gear.
    Although, the 5th gear shift can be a bit “harsh” if you aren’t familiar with it happening. Again, this is only when it COLD outside.
    Jimmyh likes this.
  6. Mar 7, 2021 at 4:40 AM
    dieselfan
    Joe
    western Pa
    2012 DC TRD 4X4
    Stock
    My truck has 45000 miles on it . I may only drive 1or2 days a week. I live in cold Pa, yesterday I take it for gas and I drive very easy, temp was 25 degrees. It seem like 0n the 3rd or 4 th gear change I left off the gas and the was a slight bang shift. I drove a mile got gas then came on the highway with a much harder gas and truck shifted fine. I was wonder could a weak battery cause this? The battery is the original battery. Thanks for your help.
  7. Mar 7, 2021 at 4:45 AM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    how many miles ????
    could be temp
    miles
    normal wear / tear
    all the above
  8. Mar 7, 2021 at 4:45 AM
    TnShooter
    Deogee
    STOCK
    No, the battery shouldn’t cause this.
    I think the 25 degree temps is what caused it.
    If it doesn’t do it when it is warm, I wouldn’t worry about it.
    I’d wait and see if it continues to do it when warm weather gets here.
  9. Mar 7, 2021 at 4:48 AM
    Tacoma Mike
    Southern Maine
    Cold delayed shifts
    Normal
    When your accelerating up to shift speed and the truck prepares to shift and you back off the
    gas the line pressures and software parameters are set and then YOU CHANGE THE PARAMETERS OF NORMALCY.
    It’s going to shift harder
    Mine shifts harder
    My 96 shifted harder
    My 85 shifted harder.
    Don’t play with a battery.
    Don’t do a d and f for this
    The only thing you need to do is JUST DRIVE..
  10. Mar 7, 2021 at 5:03 AM
    dieselfan
    Joe
    western Pa
    2012 DC TRD 4X4
    Stock
    Does your transmission seems like at 38 to 42 mph the trans has a wired feeling? If you give it more gas and it shifts the feeling goes away. This truck has done this from new. Thank you.
  11. Mar 7, 2021 at 5:07 AM
    Tacoma Mike
    Southern Maine
    Who are you asking?
  12. Mar 7, 2021 at 5:23 AM
    TnShooter
    Deogee
    STOCK
    I depends, if the transmission and truck temps are COLD.
    My truck wants to stay in 4th gear longer it seems.
    I don’t know what the speeds are, I just know the engine rpm seem to be a bit higher.
    I guess this could be described as “weird”?
    Again, if your truck does not do this once it is warm. Then I’m going to say it is fine.
    If it only does it when it is cold outside after sitting for a long time (over night) - This is Normal
    If it does it every day, all day, and every time it shifts. - This is not normal.
  13. Mar 7, 2021 at 8:39 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    I have a different transmission ( 4 Speed, 4 banger ), but the only thing I have noticed is that it doesn't lockup until the engine temperature is at 130 degrees F. This is normal on all transmissions. I thought it was strange too the first time I noticed it. Monitored the Ultragauge and noticed that as soon as the engine temp gets to 130 degrees boom lockup, RPM drops and all is well.
    And if it is really cold it will take longer to get to the magic temperature.
    TnShooter likes this.
  14. Mar 7, 2021 at 8:55 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    A very cold transmission will always shift much harder initially and smooth out as it warms up. Especially on these trucks.
    As stated previously it's a normal thing. Drive it and pay no mind to it unless you start to notice erratic shift behavior.
    Jimmyh and TnShooter like this.
