Transmission Service Interval - Aisin Recommendations
Discussion in '3rd Gen. Tacomas (2016-2023)' started by lavrishevo, Sep 10, 2023.
  1. Sep 10, 2023 at 6:12 PM
    lavrishevo
    lavrishevo [OP] Well-Known Member
    2023 Trail Edition
    This is interesting, I did not realize it was this often myself, I thought it was 30k miles. Aisin recommends a drain and refill every 20,000 km / 2 years. That’s roughly every 12.5k miles! Lol, and Toyota says every 60k miles.
    I do understand the logic, if you drain the pan and replace 3 of the 9 - 12 or so quarts every 12k the fluid is kept fresh and is ideal for longevity. So who is right? Toyota or the transmission manufacturer? Which company has the most interest in promoting longevity? Aisin, obviously. Services intervals in our manuals are BS. Marketing takes priority over engineering.
    GarrettTacoma and D.A.S. Taco like this.
  2. Sep 10, 2023 at 6:22 PM
    MadKatt
    MadKatt In need of serious help..
    Frozen Midwest Tundra
    2019 TRD OR DCLB Calvary Blue
    :goingcrazy:
    Stevie17 likes this.
  3. Sep 10, 2023 at 6:37 PM
    lavrishevo
    2023 Trail Edition
    I plan on switching to a full synthetic fluid very soon and I’ll do a drain and refill every 20k. I’m also going to do my gear fluid as well, just start doing it myself.
  4. Sep 10, 2023 at 6:56 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Sounds like a blanket statement.
    So we are group all transmission and their operating conditions in to one?
    Ok, I guess?
    hiPSI, TireFire and Stevie17 like this.
  5. Sep 10, 2023 at 7:03 PM
    lavrishevo
    2023 Trail Edition
    No, but the logic is clear. If you continually introduce new fluid into the system you maintain ideal operating environment. Maybe it seems excessive and it may be. If UOA’s show the fluid breaks down by 30k miles and we all know WS is not synthetic fluid I agree with the logic. I do know on my Lexus forums guys getting tremendous mileage out of the units changed the fluid often, not all at once either. Regular drain and refill is the best way to maintain these units.
    D.A.S. Taco likes this.
  6. Sep 10, 2023 at 7:03 PM
    Stevie17
    Stevie17 Well-Known Member
    Stevie
    Crossville, Alabama
    24 Celestial Silver Sr 5 DCSB 4x4
    Did my transmission and differential’s front and back at 80000.
    AmateurTaco1313 likes this.
  7. Sep 10, 2023 at 7:07 PM
    TnShooter
    Deogee
    STOCK
    Possibly. I can’t see how changing it that often will hurt it.
    I’m just lazy, and I figure the engine (timing components) or frame will need replaced before the transmission, if I do what Toyota says.
    wayupnort likes this.
  8. Sep 10, 2023 at 7:12 PM
    lavrishevo
    2023 Trail Edition
    Your transmission is much more likely to fail before the engine. The lack of maintenance is why. Toyota service intervals are designed to get through the warranty period. Nothing more.
    lynyrd3 likes this.
  9. Sep 10, 2023 at 7:18 PM
    TnShooter
    Deogee
    STOCK
    Maybe.
    Oddly enough it seems like a bigger expense related to the engine or frame usually decommissions the truck first. At least on one 2nd Gen trucks.
    SmoothTRD likes this.
  10. Sep 10, 2023 at 7:18 PM
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    Not Karen
    The wild west
    2016 SR5 DCSB
    Aesthetically Challenged
    are you inquiring or lecturing?
    Sharpish, hiPSI and musicisevil like this.
  11. Sep 10, 2023 at 7:20 PM
    TnShooter
    Deogee
    STOCK
    He is telling us….
    Not asking.
    The advice isn’t “bad”.
    I’m just not one to follow it.
    12k seems excessive to me?
    tollster64 and hiPSI like this.
  12. Sep 10, 2023 at 7:22 PM
    Bishop84
    Bishop84 Well-Known Member
    All the plugs would be stripped and damaged if you did it that often.
    60,000 miles is fine. Shorter if you abuse it.
    tnhawk, SmoothTRD, hiPSI and 3 others like this.
  13. Sep 10, 2023 at 7:26 PM
    KY_Rob
    KY_Rob Well-Known Member
    Rob
    North East Ohio
    2022 DCSB TRD-OR 6MT
    OEM: TRD Pro Grille & Garnish, TRD Pro Skid Plate, TRD Pro Rear Tail Lights, TRD Pro Shift Knob (MT), Tailgate Remote Lock, Black Chrome Exhaust Tip, Black Emblem Overlays, Bed Mat Vorra65 AC Drain Mod Kit FBC Harness Solutions (aka daveeasa) D-I-R Harness with Aux out Total Chaos Bed Stiffners Taco Garage Dashtop Multi-Mount MESO: Gashole, Total Tails Stg1, V5 Switchback Mirror Turn Signals, HitchPod + S1, Vent Rings AJT Designs: Radio Knobs, Door Handle Covers (Removed) Black Forest Industries Shift Knob for R8…using an adapter MountainHatch Tailgate Insert KTJO4x4 Drivers Side Grab Handle Cali Raised Catalytic Converter Shields BajaDesigns NextGen Squadron SAE Amber fogs Bilstein 6112 Front & 5160 Rear ICON Add-A-Leaf pack ICON Sway Bar Relocation Blocks ECGS Bushing 17” SEMA Gunmetal Gray Wheels with LT255/75R17 KO2’s Active Off-Road U-Bolt Flip Kit w/Timbren Bump Stops Redline Elite Hood Struts
    The transmission manufacturer is likely not the ‘expert’ they’re being made out to be in this thread. Aisin is a contract manufacturer building many components and subassemblies to a specification. They probably even perform certain pre-designed tests for quality control per the spec from the manufacturer. They may have even done the design work required for those components and subassemblies, but again to a customer provided specification. Toyota is their customer and provider of the specifications. They buy components to a specific set of criteria, that I’m certain contains a maintenance interval.
    cwdog likes this.
  14. Sep 10, 2023 at 7:53 PM
    rtzx9r
    rtzx9r Well-Known Member
    Bueller
    2016 TRD Sport
    LS1 swap with nitros.
    So you think Toyota designed the transmission and then went through a huuuuge manufacturing transfer for Aisin to make it how Toyota designed it? I’ll bet dollars to doughnuts Toyota gave Aisin the specs for a transmission to fit the truck (e.g.bolt pattern to block, dimensions, and gear ratios) and they did 99% of the design work to meet what Toyota asked for. They would therefore know what longevity the unit has and how well to maintain it.
    Anapg77 likes this.
  15. Sep 10, 2023 at 8:04 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    I've posted this information several times over the years...
    What makes you think it's just a drain and fill at 12.5K?
    There is an older version of that, where they recommend a certain machine, implying full fluid replacement.
  16. Sep 10, 2023 at 8:12 PM
    splitbolt
    NW Arkansas
    FYI...
    This transmission is used in several other Toyota vehicles as well as the Isuzu D-Max.
  17. Sep 10, 2023 at 8:14 PM
    Clearwater Bill
    Billy
    Largo Florida
    Geez. Even on my street class SCCA car (driven hard, but with mechanical empathy) I only cut both the trans and Torsen service intervals in half and went from dino to synthetic.
    She's still holding together at 27 years old. :rolleyes:
    hiPSI likes this.
  18. Sep 10, 2023 at 8:18 PM
    lavrishevo
    2023 Trail Edition
    Many articles state 30k drain and refill. What I’m saying is I have seen and been advised by very knowledgeable individuals to start the drain and refill process early if you want to get the longest life out of your transmission. I personally don’t recommend flushing. The safest and surest way of extend the life of the unit is to consistently introduce new fluid on a frequent basis. And this was a big discussion when Toyota / Lexus was still calling it a lifetime fluid. Those poor suckers were loosing their units by 150k miles if not earlier but those that started early often saw 450k+ miles.
  19. Sep 10, 2023 at 11:44 PM
    Benny22
    Benny22 Well-Known Member
    20Tacoma
    I do a D&F every year, in six months it will be my 4th time. And I use Aisin ATF at a cost of $6. per quart from RockAuto.
    Spike Strip and Toolndie7 like this.
  20. Sep 11, 2023 at 12:06 AM
    mrkabc
    mrkabc Mall Crawler with a Locker
    Art
    Corona, CA
    2017 MGM DCSB TRD OR
    Morimoto XB LED Head & Fog Lights, Cali Raised Stealth Light bar, OEM Roof Rack, Homelink Compass Mirror, Power Tailgate Lock, LED bed lights, MESO mirrors, gashole, switch panel & Stage 2 tails, PRO grille. Where's the mall?
    lynyrd3, 4x4spiegel and skidooboy like this.
