Transmission Range Sensor Problems
Discussion in '2nd Gen. Tacomas (2005-2015)' started by drewyota, Apr 25, 2021.
  1. Apr 25, 2021 at 7:52 PM
    drewyota
    drewyota [OP] Member
    3” Lift ARB OME Front Bilstein 5100 Coilovers Rear ARB OME Full Leafs Fox Shocks FJ Cruiser Tcase 4.56 Gears Hypertech Powerstop Drilled Rotors 17” KMC Enduro 315/70/17 Nito Terra Graplers
    I believe my issue is twofold. First of all, I would like to know if anyone knows a way of bypassing the Transmission Range Sensor (aka Neutral Safty Switch) on the 2nd gen Tacoma.
    I replaced the NSS about 2 years ago when my shifter gromet broke causing it to be sloppy end up in the wrong position and eventually fall off. After figuring all that out the truck still wouldn't tell what gear the truck was in and therefore would not start. I replaced the NSS and it worked. I believe it "broke" because it got mixed up with what position it was in with the shifter issue.
    Now my truck is currently stuck at the auto parts store waiting for my second NSS to come in. Getting another P0705 error code like two years ago. The night before it almost happened when the shifter was stiff but it ended up getting it back on. Again I believe the shifter assembly and rusty cable linkage are the main issue and end up breaking or making the NSS think it is broken. Currently, no lights on the PRND123 are lighting up. Right before it happened it thought it was stuck in a position when it was not actually stuck.
    1. Any way to bypass? (Don't want to be stuck in the middle of the woods next time the sensor goes out.)
    2. Any aftermarket auto shifters for the 2nd gen?
    3. Any linkage upgrades for smoother shifting? (Besides obviously lubricating the linkage under the truck.)
    4. Is there a way to reset the truck to recognize the NSS? In case the NSS it not actually broken and the truck just thinks it is.
  2. Apr 25, 2021 at 10:05 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    If it is not indicating the shift position it could be as simple as a blown fuse IG1 10 ampere. Or a damaged wire harness from that fuse to the Safety switch.
    Or do you know for a fact that the shift lever on the transmission is moving? Maybe you have a broken shift cable.
    Lots of possibilities here.
  3. Apr 26, 2021 at 5:59 AM
    drewyota
    I checked the IG1 fuse it was fine. Yes, the shift lever is moving.
  4. Apr 26, 2021 at 3:39 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    I would start searching for a wiring issue or test the Park Neutral safety switch.
  5. Apr 28, 2021 at 5:32 AM
    drewyota
    Update: replaced the nss and it is running now.
    but the sifter is very stiff and I believe needs adjusted. The light on the dash hunts for the gear position and I have to hunt for when shifting. Most noticeable with the drive positions. It gets to tight to get down to 2nd and 1st.
  6. Apr 28, 2021 at 3:17 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    https://www.tacomaworld.com/posts/23848652
    Jimmyh likes this.
  7. Apr 28, 2021 at 3:54 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    TnShooter[QUOTED] likes this.
