transmission pump seal replacement
Discussion in '1st Gen. Tacomas (1995-2004)' started by baja1, Jan 10, 2017.
  1. Jan 10, 2017 at 6:12 PM
    baja1
    baja1 [OP] Member
    5vz-fe got a couple questions from a newbie!
    anyone have a trick to removing the old seal and......
    does this require draining the transmission? when that seal is popped out will ATF come flowing out? (the transmission is in, engine is out)
    thank you friends!
