transmission overheating on hills
Discussion in '1st Gen. Tacomas (1995-2004)' started by K DUB, Dec 28, 2013.
  1. Dec 28, 2013 at 7:44 PM
    K DUB
    K DUB [OP] Member
    oregon
    02 DC TRD 4x4 V6
    285/75 TOYO R/T on 16 alloys,k&n cold air intake, ARB bullbar, icon 2.5 w/ ccdv extended travel coilovers , icon upper control arms, tundra brake upgrade, Dakar leaf pack, greaseable shackles, wheeler's anti-sway kit, spydertrack wheel spacers 1.25",tranny cooler, IPF fog lights, LED headlights , rack it lumber rack, AIR lift airbags
    hello everyone, first time posting here and have got a serious issue. the AT/oil light is coming on at the top of long steep uphill grades with a load of only a couple of passengers and the camper shell. the yota is a 2002 double cab TRD with 200,000 miles and i just got the transmission rebuilt last july after the torque converter continued to malfunction and eventually seized. because of the amount of metal debris in the old tranny fluid, the shop warranty required a new tranny cooler. my mechanic decided to save me replacing the radiator/oil cooler by adding an aftermarket tranny cooler and bypassing the original oil cooler inside the radiator. any ideas of to cure the problem of my tranny overheating and why this might be happening?:confused: even in 40-50*F temps this is happening, and not going over 55mph. thanks for listening any advice appreciated:)
  2. Dec 28, 2013 at 7:50 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Any pictures of how the aftermarket tranny cooler is installed? If the cooler is too small / too restrictive / doesn't get enough airflow, then it won't perform as well as the OEM radiator.
  3. Dec 28, 2013 at 7:59 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Are you in over drive? Running in drive only, circulates a lot more oil thus giving you more cooling.
    I'm still thinking you don't have enough cooling oil. Aftermarket coolers work better when they are plumbed along with your original radiator tranny cooler.
    Before you start throwing a shit load of money, spend $110 bucks and get a new radiator. 200k on the clock means that your original is ready for replacement. Radiators are so cheap on the internet, it is a no brainer. They are easy to change too.
    KO
  4. Dec 28, 2013 at 8:13 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    I cannot confirm this, only restate what I have read, that is, the light is set to go off above 250 degrees F.
    My personal experience is from monitoring with a scangauge. I have never tripped the light but my temps have maxed out at 235*. I have since learned that turning off the overdrive in those situations helps a lot to reduce temps, sometimes as much as 30*.
    Are you still stock, gears and tire size? Larger tires without regearing will compound the problem, making your trans work all the harder, thus more heat.
  5. Dec 28, 2013 at 8:31 PM
    K DUB
    K DUB [OP] Member
    oregon
    02 DC TRD 4x4 V6
    ok thanks you guys for all the info, here is my reply to the questions asked: no picture yet of tranny cooler, will post soon if possible or needed. one time was in overdrive off when light came on but most times have been IN overdrive, now that i know it circulates more oil to have it off i will do that, as well as replace the radiator soon, good idea right?! and about the tires they are 285/75 so much larger than stock, and can sombody point me to some info about re-gearing and cost/time involved?
  6. Dec 28, 2013 at 8:41 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Regearing is expensive but is the best mod I have done to my truck.
    Are you a 4x4 or a 2WD? Can't tell from your info.
  7. Dec 28, 2013 at 8:43 PM
    K DUB
    K DUB [OP] Member
    oregon
    02 DC TRD 4x4 V6
    4x4 TRD with ARB bumper no winch yet and snug top is only extra weight
  8. Dec 28, 2013 at 8:57 PM
    Digiratus
    Roaming the PNW
    The RedHead
    If you regear, you have to do the front also. Will double the cost basically.
    If you have the ability, tools and the space to do it, check out these guys. Very good reputation on this forum.
    http://eastcoastgearsupply.com/c-62270-assembled-3rds-clamshells.html
    If you don't have the above or the inclination, you can do what I did. Find someone to do the gear setup and install for you. I used these guys because of their reputation and their proximity. Regearing front and rear will cost you about $2,000.
    http://www.justdifferentials.com/
  9. Dec 28, 2013 at 9:13 PM
    K DUB
    K DUB [OP] Member
    oregon
    02 DC TRD 4x4 V6
    right on good to know, with that cost i will be waiting on that upgrade but i bet its well worth it:). any advice on new radiator and where to buy? should i get a new thermostat as well and any other parts while I'm replacing the radiator? thanks again
  10. Dec 28, 2013 at 9:18 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I have no personal experience with swapping the radiator. Mine is still the original one at 130K. Not sure about the t-stat but I would think new hoses are called for.
  11. Dec 28, 2013 at 9:37 PM
    koditten
    Kirk
    Central Michigan
    Which motor? I found a couple on ebay for $80. I've had good luck using radiators from ebay sellers. My 1998 has had 4 radiators, getting pretty quick at changing them. Lots of deer collisions around here.
  12. Dec 28, 2013 at 9:40 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    It should not overheat in OD on any terrain unless it is towing or hauling a heavy load.
    The mechanic probably bought a cheapie Aux trans cooler and it's just not up to doing the job.
    If the entire stock cooler is being bypassed and replaced with an external, it needs one probably 3x the size of the one that comes with the towing package.
  13. Dec 28, 2013 at 9:42 PM
    K DUB
    K DUB [OP] Member
    oregon
    02 DC TRD 4x4 V6
    3.4 liter v6 , any advice on brand of radiator? before the next deer collision you should consider arb bull bar, and save the radiator. tons of deer around here too thats why i just installed my bumper after the first deer collision. thanks again:)
  14. Dec 28, 2013 at 9:45 PM
    K DUB
    K DUB [OP] Member
    oregon
    02 DC TRD 4x4 V6
    i see, well that would explain the overheating if that is true, i know that the tranny cooler cost about $80 so that might be cheap. so when going uphill better to have overdrive off or on?
  15. Dec 28, 2013 at 9:49 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    If you've got the light coming on, that is SERIOUSLY overheated and it needs to be fixed immediately.
    Don't take it back to that mechanic for anything... he's an idiot and hopefully your new transmission has not been damaged by the overheated fluid.
    Correct the cooling configuration and change the fluid THIS WEEKEND.
  16. Dec 28, 2013 at 10:01 PM
    K DUB
    K DUB [OP] Member
    oregon
    02 DC TRD 4x4 V6
    wow, yes this is serious and thank you for the advice. so correcting the cooling configuration would be : new radiator to AUX tranny cooler and then back to tranny right? any advice on synthetic atf fluid?
  17. Dec 28, 2013 at 10:05 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    I usually use my O/D on long flats or freeways, if going uphill w/long grade, turn off O/D, push the ECT button if you hjave one & most certainly an aftermarket cooler thats got the plumbing squeezed down is going to create or at least magnify cooling issues & the A340-F DOES NOT DO WELL WITH HEAT, if you wait to flush/change fluids, its probably going to fail.. if you start getting some hard upshifts, its a ticking time bomb, already been thru it...
  18. Dec 28, 2013 at 10:10 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    All ATF is primarily synthetic.
    I'm not sure what your year trans requires, check the dipstick or the manual. If it calls for Dex-II or Dex-III, then Mobil-1 is good.
    If it calls for T-IV, that comes from the Toyota dealer.
    Amsoil claims compatibility with T-IV... I don't trust them with my trans.
    MindFork likes this.
  19. Dec 28, 2013 at 10:13 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Only time I come out of OD is if the trans starts "hunting" between gears... same goes for the 2-3... I'll pull it down to the lower of the 2 gears it's hunting for.
    Heat in the automatic trans comes from two sources... slippage on the plates, which only happens (in a healthy transmission) during shifts, and from the TC when it is not locked.
    Even on hills, if the TC is locked, and the trans is not hunting between 3-4, there is no need to drop it out of OD.
  20. Dec 28, 2013 at 10:33 PM
    K DUB
    K DUB [OP] Member
    oregon
    02 DC TRD 4x4 V6
    so does replacing the radiator also replace the original tranny oil cooler? if so thats the next step along with changing the fluid.
