Transmission fluid topping off using the Level check valve
Discussion in '3rd Gen. Tacomas (2016-2023)' started by vimal, Jan 29, 2016.
  1. Jan 29, 2016 at 9:33 AM
    vimal
    vimal [OP] Member
    Vimal
    2016 Tavoma
    Hello, I am trying to top of my 2016 tacoma transmission fluid but have hard time reaching the fill Nut. Has any one filled fluid thru the level check using a tube?
    Thanks.
  2. Jun 9, 2016 at 1:50 PM
    DragNasty
    DragNasty Well-Known Member
    2016 Blazing Blue Pearl Limited V6 4X4
    The atf kit uses a fill tube and i think a pump. You should be able to get a filler kit for Atf fluid at an autoparts store...
    Kilokato likes this.
  3. Jun 9, 2016 at 1:54 PM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    Playing devils advocate here. Make sure you actually need fluid, did you check and it shows low?
  4. Jun 9, 2016 at 2:06 PM
    Nedburg
    Nedburg Member
    I am in the process too to check my tranny level..i had nothing come out of the overfill tube..and took me awhile to even find the fill nut.. so if it can be done through the overfill it would be great.. one thing I am curious of is. Does not removing the fill nut create a lock not allowing the fluid to come out . Or is mine just low too... I will probably answer my own question soon.. waiting for the transmission temp to come down..but if I don't have to fight with that fill nut .i won't. , I have a fill pump with a hose that could fill through the overfill tube..
  5. Jun 9, 2016 at 2:35 PM
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    good point on needing both nuts out to possibly create pressure
    for the fluid to flow properly as opposed to having just the over-flow
    bolt out.
  6. Jun 9, 2016 at 4:20 PM
    Nedburg
    Nedburg Member
    Just completed mine, almost a full litre low, so can't be sure if the fill bolt holds back the flow through the overfill or not.. cause mine was so low.. and the damn fill bolt is a PITA to get to.. and I do believe that heat shield is engineered like that to discourage people to service it themselves... blood has been spilt..lol, damn thing is sharp, I did read a warning about that but didn't believe it, paid the price.. good luck, and dont forget to check your diff too same size bolt and very easy to check my was low also.. more then half a litre... ?? So relieved for this site..
    PROseur and choupick like this.
  7. Jun 9, 2016 at 4:40 PM
    Rramv1416
    Rramv1416 Well-Known Member
    SO CAL
    2016 DCSB V6 SR5 BLACK w/Tow
    How close is the heat shield? I haven't checked yet.
    PROseur likes this.
  8. Jun 9, 2016 at 4:50 PM
    Nedburg
    Nedburg Member
    I can barely fit my hand between it and the tranny to get my figures on the bolt to get it off once it was too loose for the ratch .. best thing is to wear some gloves.. cheers
    PROseur likes this.
  9. Jun 9, 2016 at 4:51 PM
    Seabass
    Seabass Give it to me. I'll break it for you
    Adam
    AZ
    '06 Sport 4x4
    Just a bunch of old crap
    Why are you checking trans fluid on a brand new truck?
  10. Jun 9, 2016 at 4:52 PM
    OhioTaco68
    OhioTaco68 John 3:16
    Central Ohio
    16' Tacoma SR5 4x4 access cab Silver Sky Metallic
    AVS in channel window deflectors Predator steps Tinted front windows De-badged all chrome emblems Matte black tailgate lettering Matte black door badges Silver door sill lettering Weathertech mud guards Tacoma bed mat Interior LED lighting Lamin-X yellow fogs Hyper yellow DRL LED 3rd brake light bulbs CLEARZ 3rd brake light lens LED back up lights Access LITERIDER tonneau cover Console cover w/Toyota logo Hondo radio knobs NeoSupreme seat covers TRD shift knob Toyota Dark Satin Alloy wheels Toyo Open Country AT3 tires Red glovebox lettering Red vent rings/ control knobs Husky all weather mats Toyota bed mat
    What transmission temperature are you guys checking your fluid level at ?
  11. Jun 9, 2016 at 5:10 PM
    Nedburg
    Nedburg Member
    There is a whole procedure to follow to get the proper temperature.. it is pretty easy to follow..
  12. Jun 9, 2016 at 5:11 PM
    JoeyDel
    JoeyDel Well-Known Member
    Joe
    South Jersey
    2003 Off Road AC and '16 AC Sport Silver Sky Metallic
    Have you ever checked your trans fluid? Because 2nd gens had the same issue. FWIW I think it's overblown, a 1/2 quart shouldn't mean much but some have reported much more.
  13. Jun 9, 2016 at 5:12 PM
    Nedburg
    Nedburg Member
    It is actually not that tight if a fit.. but it is a pain.. the fill plug is up beside that plug.. you can't actually see it. Took me a while to find it..
  14. Jun 9, 2016 at 5:15 PM
    choupick
    choupick Double Secret Probation
    The south
    2016 DCSB TRD SPORT 4X4 MGM
    Dents in roof from poorly loaded canoe. Broken side mirror from blown transfer truck tire. Scuffed up front bumper from thinking I was still in a corolla. Graham cracker embedded upholstery from a crazy kid.
    It's pretty tight when the engine is running and you are trying to work quickly. It got me...
  15. Jun 9, 2016 at 6:19 PM
    glider_guider
    glider_guider Well-Known Member
    2016 Red Tacoma TRD OR 4x4
    The third degree burns on my knuckles from trying to work next to a running truck's catalytic converter were worse than the cuts, in my opinion. :rolleyes:
    PROseur likes this.
  16. Jun 9, 2016 at 6:31 PM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    They will buff out, I' sure.. hehe
  17. Jun 9, 2016 at 7:14 PM
    Rramv1416
    SO CAL
    I see several bolts, which one is the one I'm needing??
  18. Jun 9, 2016 at 7:24 PM
    Nedburg
    Nedburg Member
    There is a 15/16(24mm) filler plug right near the green wire plug on the body of the transmission, you can not really see it have to feel for it and put the ratch onto it.. a long handle ratch works best, it is kind of a PITA..
  19. Jun 10, 2016 at 7:07 AM
    manofsteele2003
    manofsteele2003 Well-Known Member
    2016 Blazing Blue TRD Sport Double Cab
    17" TRD wheels w/265/70/17 BFG KO2s, Weathertech mud flaps, Gecko LED bed lights, more to come.
    Get a fluid pump and a couple feet of hose to extend it. Be sure to break the bolts free before starting the procedure and you should be good. Once you're in the temp range you actually have quite a bit of time to get it done.
  20. Jun 10, 2016 at 8:47 AM
    stevebaz
    stevebaz Well-Known Member
    2016 access cab, TRD offroad 4x4, Quicksand
    I used the Harbor freight pump. Remove the fill plug. The pump will screw onto the Toyota transmission fluid bottle. The plastic tube that goes inside the bottle will need to be trimmed some so the pump will screw all the way down. I used mine without screwing the cap all the way down. The transmission fill port has a 24MM bolt that has WS embossed on the head of the bolt.
    The end of the hose from the pump to the transmission has a clip that will hold it in place on the transmission fill port while the truck is running so it won't fall out on you or the hot exhaust system. Get this all ready before your dealing with a running truck and while everything is cold. Just so your not fighting a hot heat shield or a smoking hot catalytic converter. I used a small box lined with aluminium foil as my catch basin, a foil turkey pan would work better. Now start your truck and get it in check mode and follow the proper check procedure don't forget to pin open the transmission cooler switch. a small paper clip works well to pin back the valve after you push it in. I bought 2 bottles of fluid from Toyota and used one. When your done shut off the truck and let the exhaust system cool before undoing your fluid pump and plugging the transmission fill port and removing the paperclip.
