Transmission fluid recommendations
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PFD FIRE, Nov 3, 2022.
  1. Nov 3, 2022 at 9:21 AM
    PFD FIRE
    PFD FIRE [OP] Well-Known Member
    David
    San Diego
    2011 Toyota Tacoma TRD Sport
    265/75/16 Goodyear Duratrac Tires, Total Chaos UCA, Bilstein 6112 Coilovers (front) Bilstein 5100 (rear), TRD CAI, TRD Cat Back Exhaust, Rough Country/Lamphus LED lights, rear ARB locker, Baja Rack
    I have a 2011 Toyota Tacoma 4.0L V6 and I’m planning on changing out the transmission oil. Is their a particular synthetic transmission oil that you can recommend or should I go with Toyota brand transmission oil?
  2. Nov 3, 2022 at 9:47 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    You are going to pay ~ 75$ for 3 gallons of valvoline maxlife atf https://www.walmart.com/ip/Valvolin...smission-Fluid-ATF-1-GA/15125768?athbdg=L1100
    Which is about the only trans fluid you should substitute for the stock toyota WS fluid.
    You are going to pay ~ 120$ for the 12 quarts for the proper Toyota WS. Is a savings of 45$ over the course of 60k miles (recommended change interval, most go further) worth it to you?
    TRDSport10 and Otterstuff like this.
  3. Nov 3, 2022 at 9:59 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Valvoline MaxLife ATF as sated above.
    Read this thread to understand the correct temp check procedure and also note there is an updated temp range per this TSB on pg 106
    https://www.tacomaworld.com/threads/how-to-drain-refill-automatic-transmission.63851/
    wmb67 and Dm93[QUOTED] like this.
  4. Nov 3, 2022 at 10:08 AM
    saint277
    saint277 Vigilo Confido
    Got 20k on my MAXLIFE, if it was gonna cause issues it would have done so by now.
  5. Nov 3, 2022 at 10:10 AM
    jlemmond
    jlemmond Well-Known Member
    josh
    Monroe, NC
    2006 GX470
    I also use MaxxLife in my A750
    wmb67 likes this.
  6. Nov 3, 2022 at 10:31 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Stay with WS if doing a drain/refill. If doing a flush, you have the choice of staying with WS or switching to MaxLife as many have done. I run MaxLife in my Tacoma and the two Lexus vehicles I maintain.
    Ricardo13x likes this.
  7. Nov 3, 2022 at 11:14 AM
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    I am big fan of Valvoline MaxLife
  8. Nov 3, 2022 at 12:12 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Is the truck an Automatic or Manual?
    Dm93 likes this.
  9. Nov 3, 2022 at 12:24 PM
    Stemmy
    Stemmy Certified Wombat Rancher
    Rob
    Pennsylvania
    2013 Pyrite Mica DCLB
    changed my '13 over to MaxLife at 40K, I'm at 123K now and zero issues.
    jackn7 likes this.
  10. Nov 3, 2022 at 12:42 PM
    SR-71A
    Zack
    Southern Maine
    fair, fair
    TnShooter[QUOTED] likes this.
  11. Nov 3, 2022 at 3:24 PM
    Chuy
    Lakeside, CA
    Silver Taco
    He has an AT based on his other postings, and a valid point; I jumped to conclusions myself.
    TnShooter likes this.
  12. Nov 3, 2022 at 4:03 PM
    TnShooter
    Deogee
    STOCK
    I used to check peoples prior post.
    But admittedly, I’ve gotten lazy, and now just ask.
    If find it much easier to ask, the more we know, the better we can help.
    If it’s indeed an AT, I agree with the rest.
    MaxLife is good.
    I personally don’t like mixing AT fluids.
    So I opted to stick with WS. Because I have not done a full system evacuation.
    Drain and Fill is all I’ve done.
    Chuy[QUOTED] likes this.
  13. Nov 4, 2022 at 7:57 AM
    Raylo
    Raylo Well-Known Member
    MD, USA
    2023 Tundra SR5 OffRoad; (2009 Tacoma - sold)
    All stock, except for audio and convenience add-ons
    Based on recommendations here I went with the MaxLife when I did a flush and fill a few years ago at around 100,000 miles. Now at 136,000 with zero issues. But if I had it to do over again... and if I keep the truck long enough to need it again... I'd probably use the Toyota WS. When I drained it that stuff still looked pristine. The MaxLife seems solid, but if the WS isn't broke, why "fix" it?
  14. Nov 4, 2022 at 8:28 AM
    saint277
    WS isn't broke, but it is expensive. I also prefer a fluid I can get in most auto parts store in case a need to top off for some reason. Don't have to drive to a dealer or wait on an internet order for maxlife.
    SR-71A likes this.
  15. Nov 4, 2022 at 8:39 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    I only do drain and fills. I don’t see the logic in switching, full flush, no problem.
  16. Nov 4, 2022 at 11:05 AM
    Raylo
    MD, USA
    Topping off is really a non-starter with these things since there is no dip stick. If you get a leak (like the pinhole leak I got once in a trans cooling line) you are in a bad way. It needs to be fixed ASAP since there is no easy way to monitor level or top off on a regular basis. But that is a whole other discussion.
  17. Nov 4, 2022 at 11:52 AM
    saint277
    I do a level check every oil change, just because Toyota didn't grace us with a dip stick doesn't mean you shouldn't be checking.
  18. Nov 4, 2022 at 12:39 PM
    TnShooter
    Deogee
    STOCK
    You go through temp check mode and it every 5k miles?
    You are better off with a fast trickle from check plug. It’s seem like checking it that often would eventually result in a slightly low fill eventually? Or are you topping it off when it needs it?
    Myself, I wouldn’t check it until every 30k
    if were worried about.
    To be honest, I don’t check mine.
    I check for leaks, the only time I check it is when I drain and fill.
  19. Nov 4, 2022 at 12:42 PM
    saint277
    I use my scan gauge to get the temps, generally after my oil change the trans temp has dropped from warm up to the appropriate range or need only a min or too at idle to get into range. Pop off the level plug, get some drops, maybe every 3rd or 4th oil change I add 1/2 a quart.
  20. Nov 4, 2022 at 8:12 PM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    I always get the real deal.
    TRDSport10 likes this.
