Transmission Fluid, Dexron III Replacement
Discussion in '1st Gen. Tacomas (1995-2004)' started by RoscoeTT, Dec 17, 2021.
  1. Dec 17, 2021 at 6:12 PM
    RoscoeTT
    RoscoeTT [OP] Well-Known Member
    New York
    2002 Toyota Tacoma
    Purchased an 02 Tacoma with Dexron III fluid that’s in need of changing. I know Valvoline makes a solid product but I have two options. Valvoline Full Synthetic MaxLife or Valvoline Dexron/Mercron II/III. Which do you think is best? If I do synthetic, will it be okay mixing with the factory tranny fluid? I’m just doing a simple pan drain, clean and reseal. Refill what I removed basically.
  2. Dec 17, 2021 at 6:20 PM
    Nessal
    Nessal Well-Known Member
    Texas/Bay Area
    2003 V6 4X4 TRD DCAB
    Maxlife. It will be ok.
    CS_AR and Superdave1.0 like this.
  3. Dec 17, 2021 at 6:32 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    CS_AR likes this.
  4. Dec 17, 2021 at 6:48 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Seagull233 and TnShooter like this.
  5. Dec 19, 2021 at 6:26 AM
    RoscoeTT
    New York
    2002 Toyota Tacoma
    Ok! Thanks for the input everyone.
  6. Dec 19, 2021 at 12:08 PM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    Only the original DEXRON II from GM Delco in a metal can. LOL -- Considering our trans note this ancient D-II fluid, any modern DEX II/III equivalent will work.
    We see many good reviews from Valvoline Full Syn Maxlife. I've changed all of my vehicles to use that fluid.
    Dalandser likes this.
  7. Dec 19, 2021 at 1:20 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    Yeah the max life is the way to go.....
    and it works great on power steering......
    Pressurize hydraulic hoses have to be replaced every 5 yrs....
    they degrade inside out from the heat and the break down of the protective additives in the trans fluid over time...
    just like the coolant flowing thru your aluminum heads.....
    changing fluids ahead of time is how to get max life out of your tools....
    Old brake fluid is extremely corrosive....
    and the Valvoline syn gear lube for the back diff.:brianr:....
    If you fail to replace hoses they put CRAP thru steer motors, valves ect, as they break down.......never even know it....til one day......
    GilbertOz and CS_AR like this.
  8. Dec 19, 2021 at 1:27 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Been doing drain and fills for a few years. I’m about 70% MaxLife 30% WS.
    CS_AR likes this.
  9. Dec 19, 2021 at 1:27 PM
    CS_AR
    You bet. I switched to the new Valvoline flex fill bottle for diff lube. Easy to dispense. No messy pumps.
  10. Dec 19, 2021 at 2:03 PM
    O'Silver_Taco
    MD
    When I dropped the tranny pan it was a complete waste of time...
    that metal screen had zero refuge on it.....
    So from now on I use external transmission filter (raybestos) and only do changes using a hydrolic oil syphon pump.....
    Everyother oil change I suck 2 qts max life out of dip stick tube...
    and put two back in......
    should give me a complete turn over every 20K or so....
    But for the conversion it was a major deal to flush out 9 qts including torque convertor...took a lot of work and sauce......
    You never want to mix old with new in anything petro based.....
    think it took me 4 gals+ /($100).....and since tranny was well used.....I opted to put in half a bottle of the lucas tranny conditioner to be safe......
    There's video on how to pull trans line cooler hoses....flushing and using a hydrolic transfer pumping fresh right back in.....
    https://www.northerntool.com/shop/t...x919Z6ZvvKC_vOcrb40aArYwEALw_wcB&gclsrc=aw.ds
    $20 Tool Makes Car Service Painless - YouTube
    CS_AR likes this.
  11. Dec 19, 2021 at 2:28 PM
    O'Silver_Taco
    MD
    Dont buy max life from auto stores.....wally .dot com and amozon is almost half price....
    18 vs 29
    just got to work the free shipping thing....min order....
    Wally box stores around here are out of stock....so online was only option...
    Nessal and CS_AR like this.
  12. Jun 1, 2022 at 1:47 PM
    desert-rat
    desert-rat Well-Known Member
    somewhere in Utah
    2001 Tacoma Limited TRD SC DC
  13. Jun 1, 2022 at 3:31 PM
    1bad2k
    1bad2k Well-Known Member
    Lone Star State
    2017 Tacoma TRD PRO
    I just did mine a couple months ago. I used amsoil. I bought 13 quarts and just did the DIY flush method with the cooler return line removal.
