Transmission Fill Plug
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MountainLionResources, Jan 18, 2018.
  1. Jan 18, 2018 at 4:18 PM
    MountainLionResources [OP] Member
    Kagat
    2013 Black Tacoma v6 Double Cab Long Bed Base Model Auto Tow Package
    3 in body lift, Tri folder bed cover, window tint, custom seat covers, custom windshield cover
    From this parts list I'm unsure which part # is a tranny fill plug for my
    '13 v6 5At 4x4 Taco Base double cab.
    http://www.toyodiy.com/parts/p_U_201109_TOYOTA_TACOMA_GRN245L-CRADKA_3503.2.html?hl=35106A
    My best guesses are the
    PLUG, AUTOMATIC TRANSMISSION CASE (90341-A0001),
    PLUG (FOR AUTOMATIC TRANSMISSION OIL PAN)(90341-10021),
    PLUG (FOR AUTOMATIC TRANSMISSION CASE) (90341-14011), or
    PLUG SUB-ASSY, DRAIN (ATM) (90341-10011).
    The dealership recommended I get the last option- a drain plug because they suspect it has the same threads & same o-ring as the fill plug.
    Thank you. I hope to climb under her with a replacement plug for the stripped fill plug. Also fun fact the dealer I spoke to doesn't recommend flushing the tranny just drain & fill.
  2. Jan 18, 2018 at 4:24 PM
    Pigpen
    Northwest Montana
    They suspect? They're the dealership. They should know.
    I have a manual, so I don't know either. But the dealership? They should have the answer.
    inwood customs likes this.
  3. Jan 18, 2018 at 8:37 PM
    road2cycle
    road2cycle Well-Known Member
    Sonoma County, CA
    2014 Tacoma DCLB 4x4 Limited
    While I can’t tell you what the part number it is but I can tell you the fill plug is a lot larger than either of the tranny drain plugs. My dealership was hopeless as well . . . “the tranny is a sealed unit” until I suggested them to open up their parts catalog and take a look. They ordered me the wrong fill plug gasket so I reused the old one. Sorry can’t be of much help.
  4. Jan 19, 2018 at 5:24 PM
    docbrown
    docbrown Well-Known Member
    Tampa, FL
    05 Tacoma SR5 4X4
    Doug Thorley Long Tube Headers, Eclipse 6620 AVN GPS/DVD, K&N Drop-in Air Filter, Hose clamp mod, Redline Quick Lift Elites, Bilstein 5100's at .85, Firestone Ride Rite Air Bags, Weather Techs front and back, Bug Guard, and Factory Bull Bar, Wet Okole's up front, Bed Mat, LED interior lights, Fumoto Oil Valve
    Looking at the exploded parts diagram I can say it is not the 90341-10021. Still looking to see if I can determine which one it IS.
  5. Jan 19, 2018 at 5:30 PM
    docbrown
    Tampa, FL
    05 Tacoma SR5 4X4
  6. Jan 19, 2018 at 5:50 PM
    80schild
    80schild Well-Known Member
    Chad
    Flori-Bama
    2007 TRD Sport Access Cab
    The fill plug is towards the tail of the transmission on the passenger side. I can’t remember for sure, but I’m thinking it uses a 22mm socket, way bigger than the drain plug. Fill plug uses a rubber o-ring, drain plug uses a washer.
  7. Jan 19, 2018 at 5:56 PM
    docbrown
    Tampa, FL
    05 Tacoma SR5 4X4
    The OP was looking for the correct part number for the fill plug, not the location of it on the transmission.
  8. Jan 19, 2018 at 9:24 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
  9. Jan 20, 2018 at 6:04 AM
    80schild
    Chad
    Flori-Bama
    Ah. I misread it. :hattip:
  10. Jan 21, 2018 at 12:11 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Don't know the part#, but the fill plug is an M18 X 1.5 pitch X 10mm long bolt. Any such size bolt with a crush washer will work.
  11. Jan 23, 2018 at 3:25 PM
    Kagat
  12. Jan 23, 2018 at 4:06 PM
    Bocsy44
    Bocsy44 Well-Known Member
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    This that and the other thing.
    I ran into the same thing, I was asking about gaskets for the drain and fill plug, he found the drain plug gasket no problem and couldn't find the fill plug haha he says, "don't u just fill it through the dip tube?" I then explained about how our transmissions don't have one, yada yada, I didn't stick around to figure it out. I had looked a little on here as well and I couldn't find a straight answer for a part # hahaha I guess everyone on here doing drain and fills just re-use the old one?
  13. Jan 23, 2018 at 6:09 PM
    Pigpen
    Northwest Montana
    I reused mine in my manual tranny when I changed the fluid. I'm due for another , but it can wait until spring.
    Bocsy44[QUOTED] likes this.
  14. Dec 26, 2018 at 7:34 PM
    slvreagl
    slvreagl New Member
    Dan
    Well since I found this forum by googling information about my 2011 Toyota Tacoma 4x4 automatic transmission, and this subject because I needed to know how to refill my "sealed" transmission with no dipstick. I thought I would add what I found and did to refill my transmission.
    The guys that posted the fill plug is a 24mm on the passenger side are correct, it also is a 15/16" either size will work but it must be a SHORT socket.
    The transmission pan has a drain bolt, and a TORX overfill bolt. Haynes manual states to have the trans. at operating temperature, while running, remove the overflow bolt and the fill bolt ( I would do this when exhaust is cool) and fill the transmission until fluid drips out the overflow hole. Also the fluid was only available at Toyota known as ATF WS. I used a 3/8 poly tubing line inserted into the fill hole and carefully placed along the body up thru the engine bay, where I connected a screw on 1 quart spout from Autozone and inserted the poly tube into the spout tube. Worked great.
    Hope this additional info helps someone in the future.
