Transmission Crossmember Bolts OEM #
Discussion in '2nd Gen. Tacomas (2005-2015)' started by zerotimeouts, Aug 11, 2021.
  1. Aug 11, 2021 at 2:52 AM
    zerotimeouts
    zerotimeouts [OP] Well-Known Member
    Nor Cal
    2011 DCSB 4.0 S/C
    Missing one of the 5” bolts that goes through the Crossmember and can’t figure out part number. None of the frame diagrams I’ve seen have them listed.
    I know they are about 5” long and 14mm.
  2. Aug 11, 2021 at 3:22 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    What engine, transmission, 2WD/4WD, and year is your truck?
  3. Aug 11, 2021 at 3:33 AM
    zerotimeouts
    Nor Cal
    2011 DCSB 4.0 S/C
    2011 4WD 4.0 A/T
  4. Aug 11, 2021 at 3:35 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    I'm stopping in to my local Toyota dealer today to pick up some parts that I ordered.
    If you want to PM me with your VIN, I can get part numbers if nobody else can find them.
    Also a picture of where they go, I do have an idea of which bolts you mean.
  5. Aug 22, 2021 at 10:25 PM
    zerotimeouts
    Nor Cal
    2011 DCSB 4.0 S/C
    2 long bolts on either side are what I am looking for. All the parts store diagrams for frames do not have them pictured.
  6. Aug 22, 2021 at 10:53 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    I just removed mine to install a skid plate and had to use longer bolts. Do you ever make it up to Reno?
  7. Aug 22, 2021 at 10:57 PM
    zerotimeouts
    Nor Cal
    2011 DCSB 4.0 S/C
    UnFortunately not very often. I threw a grade 10 bolt from HW store in for now. Someday I'll find the correct part number and swap it out when I'm ordering other stuff. Thanks though
    stickyTaco[QUOTED] likes this.
  8. Mar 12, 2023 at 9:56 PM
    Nemesis-dsl
    Nemesis-dsl Well-Known Member
    21 Trd Sport.
    Does anybody know the torque spec on these bolts for the cross member brace bars?
  9. Mar 13, 2023 at 4:11 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Is this for your 2021 model truck?
    Is your truck an Auto?
  10. Mar 13, 2023 at 4:12 PM
    Nemesis-dsl
    21 Trd Sport.
    Yes, i believe it is 15 ft lb on the M8 bolt.
  11. Mar 13, 2023 at 4:17 PM
    TnShooter
    Deogee
    STOCK
    This is for a 2016. I don’t see why it would be any different.
    Looks like 24 ft/lb
    Nemesis-dsl[QUOTED] likes this.
  12. Mar 13, 2023 at 6:50 PM
    Nemesis-dsl
    21 Trd Sport.
    Thanks so much. This is helpful
    TnShooter[QUOTED] likes this.
  13. Mar 15, 2023 at 9:08 PM
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    90105-10114 - Bolt; Qty: 4
    94150-11001 - Nut; Qty: 4
    Jeff
  14. Mar 31, 2024 at 8:37 PM
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
    Need some longer bolts for this same spot since I got skids I need to put on. Anyone know the size? I probably need about an inch or so longer than stock
  15. Apr 1, 2024 at 2:55 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
