Transmission cooler inlet and outlet
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ucdbiendog, Jun 9, 2024.
  1. Jun 9, 2024 at 8:43 AM
    ucdbiendog
    ucdbiendog [OP] Well-Known Member
    Reno, NV
    2014 DCSB TRD OR
    Bilstein 6112 + 5160 + Dakar MD, Stubbs HD-SKO sliders, BAMF skids, BAMF front bumper, Relentless Rear
    I’m in the middle of installing a Hayden oil cooler (you can see mounting brackets on the left where it will go) after the stock cooler. However, outlet barb (left barb in the pic) on the stock cooler comes out at a weird angle and I’m having a hard time routing a line to the left (where the new cooler goes) without some tight bends. Since both barbs are on the bottom, can I change the flow direction in the stock cooler? In other words, route the inlet tube to the left barb, and have the right barb go to the new cooler? TIA
    GREENBIRD56 likes this.
  2. Jun 9, 2024 at 9:13 AM
    GREENBIRD56
    GREENBIRD56 Well-Known Member
    Casper / Tucson
    014 Taco 4Dr 4wd
    This is a good idea - the angled outlet from under the factory cooler is a more natural flow path when configuring the new piping. If there are no flow controls in the factory cooler (free in either direction) there isn't any down side to this.
  3. Jun 9, 2024 at 10:16 AM
    ucdbiendog
    Reno, NV
    2014 DCSB TRD OR
    That’s exactly what I’m wondering, if there is any directional flow control in the factory cooler
  4. Jun 9, 2024 at 11:00 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
  5. Jun 9, 2024 at 11:18 AM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    The stock cooler doesn't have a check valve or anything. If your Hayden unit is substantially larger, I would delete the OEM - fewer connections means fewer leak points. I replaced my OEM with a Hayden 696 and have run it hard in some very hot weather with acceptable, and very stable, trans temps.
  6. Jun 9, 2024 at 12:07 PM
    ucdbiendog
    Reno, NV
    2014 DCSB TRD OR
    I thought this was a peculiar oem setup as well, I’d think it would trap air inside. I was originally going to delete the oem, but hd second thoughts when towing recently got temps up to 235F. Very briefly. Guess I can go without oem first and figure out how to add it back in later if needed. I have the Hayden 698 which is a little bit smaller than the 679
  7. Jun 9, 2024 at 12:08 PM
    ucdbiendog
    Reno, NV
    2014 DCSB TRD OR
    any towing? I pull a small travel trailer (3000 lb empty) so would rather have more cooling than needed
  8. Jun 9, 2024 at 1:30 PM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    No towing for me.
  9. Jun 9, 2024 at 2:40 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I know some of the Hayden coolers have an internal by-pass.
    This allows the fluid to warm up faster. Once it gets "warm" the by-pass opens and colling begins.
    I can not say for certain what will happen if you hook it up backwards. But the by-pass may not work right.
    You definitely, don't want to "delete" the cooler hooking it up backwards.
  10. Jun 9, 2024 at 4:31 PM
    Chuy
    Lakeside, CA
    Silver Taco
    Naw, no air is going to get trapped. The transmission is vented, so any bubbles float up and dissipate. I say leave the oem cooler, especially if you’ll be towing. The hose inlets/outlets are long enough you can put two mini hose clamps at each end.
  11. Jun 9, 2024 at 9:17 PM
    GREENBIRD56
    Casper / Tucson
    014 Taco 4Dr 4wd
    The photo the OP included is exactly like my '14 - the factory aux cooler has both ports on the bottom. On the Hayden 670 series (mine is a 677) the instructions say their in/out ports are interchangeable. They also say that fluid will short circuit directly from port to port until the temp rises. The OEM trans cooling chamber in the engine radiator exits from the top port and immediately drops down to roughly the same elevation as the two bottom ports in the little aux cooler. I don't think Toyota engineers were thinking that bubbles may be trapped in these components when pressurized- if so, the arrangement might be designed differently.
    ucdbiendog[OP] likes this.
  12. Jun 9, 2024 at 9:45 PM
    ucdbiendog
    Reno, NV
    2014 DCSB TRD OR
    Ended up taking out the OEM cooler, for now. I was able to blow fluid both ways when I got it out so doesn’t appear to have any kind flow directionality. Have a short camping trip this weekend so will see how the temps are while towing. Thanks all! And a photo for completeness
    GREENBIRD56 and deanosaurus like this.
  13. Jun 9, 2024 at 10:17 PM
    caribe makaira
    Caribbean, Puerto Rico
    I would've followed the orientation of the rest of the "cooler's already installed, radiator and A/C. As in hot inlet on passenger side. Not as you installed it, hot on top.
  14. Jun 10, 2024 at 6:41 AM
    ucdbiendog
    Reno, NV
    2014 DCSB TRD OR
    hot is on the bottom, not top. Thought being it will help push air out as the bottom fills up.
    nd4spdbh likes this.
  15. Jun 10, 2024 at 8:10 AM
    caribe makaira
    I meant the orientation of the cooler itself, as in both ports on top, hot input to passenger's side.
    And I think the hot is the top hose.
    Hot from transmission to top driver's side radiator nipple, out bottom radiator nipple to hose to top pipe to hose to cooler. "Cooled" from cooler to hose to bottom pipe to hose to pipe under radiator to hose to pipe to transmission.
  16. Jun 10, 2024 at 10:08 AM
    ucdbiendog
    Reno, NV
    2014 DCSB TRD OR
    I just double checked and flow is as below. The instructions that came with the hayden cooler said it could be mounted horizontally or vertically.
    hoffengineering likes this.
  17. Jun 10, 2024 at 10:33 AM
    BlkDakDave
    BlkDakDave Well-Known Member
    David
    CC TX
    07 AC PreRunner TRD/Off Road
    Your cooler is mounted the way I did my Long Tru-Cool LPD 4454 four years ago. Since then I have logged thousands of miles through many states includingi AZ, NM, UT, CO and my home state of TX. Zero issues. You'll be fine.
  18. Jun 10, 2024 at 11:39 AM
    hoffengineering
    hoffengineering Well-Known Member
    Taylor
    Orange County, California
    2015 DCLB 4X4
    That's similar to how I have mine mounted. Looks good.
  19. Jun 10, 2024 at 11:41 AM
    ucdbiendog
    Reno, NV
    2014 DCSB TRD OR
    Nice, thats a very clean install
  20. Jun 10, 2024 at 1:33 PM
    caribe makaira
    "Looks" trumps science. You guys are a :woot::laugh:
