Transmission cooler hose diagram
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Orbang, Apr 29, 2021.
  1. Apr 29, 2021 at 4:53 PM
    Orbang
    Orbang [OP] Active Member
    Gerald
    Tacoma 2006
    Hi all,
    Does anyone have a diagram with part numbers for the transmission cooler hoses that is part of the radiator (not the separate cooler in the very front).
    I need to purchase the hose that connects to the radiator but can't find any info anywhere.
    Thanks
  2. Apr 29, 2021 at 8:11 PM
    caribe makaira
    Caribbean, Puerto Rico
  3. Apr 29, 2021 at 8:28 PM
    Orbang
    Gerald
    Tacoma 2006
    Hi there, thanks for the quick reply. I google hoses 32941 & 32942 and they seem to be the ones going to the small transmission cooler that sits in front of the condenser.
    I'm looking for the hose that connects to the radiator. Not sure if it is on the drawing 2 of 2 which is mentioned on your drawing but not shown.
  4. Apr 29, 2021 at 8:44 PM
    caribe makaira
    Those are the ones you are seeking. These are 2 of 2, not the ones you want.
    Pearson likes this.
  5. Apr 30, 2021 at 1:22 PM
    Orbang
    Gerald
    Tacoma 2006
    OK thanks. I went to Toyota today. $104 & $75 for the two hoses. Ordered them but that's a crazy price for a couple rubber hoses. I'm going to see when I remove the old ones if they are usable as I'm only changing them because I'm replacing the radiator. My truck is a 2006 and I'm pretty sure their the original ones.
    Was able to find aftermarket upper and lower rad coolant hoses but nothing for the transmission cooler hoses.
    If anyone has found any aftermarket ones or got away with just using rubber hose rated for transmission lines let me know what you used. I wasn't sure on the inner diameter size as I haven't removed them yet.
    Thanks
