Transmission Bell housing
Discussion in '1st Gen. Tacomas (1995-2004)' started by Alexis_chavez132, Dec 16, 2022.
  1. Dec 16, 2022 at 9:40 AM
    Alexis_chavez132
    Alexis_chavez132 [OP] New Member
    Alexis
    1998 Toyota Tacoma 3rz 5spd
    I’m kinda confused on the bellhousings on the Tacomas all the transmission I’ve found on Facebook have the starter on the right. But they are the same transmission as the one in my truck. My starter goes on the left. Do I just switch the bell housings?
  2. Dec 16, 2022 at 10:44 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    The starter location on the passenger side is for the 3.4L v6 engine. Your stuck info indicates you have the 2.7L 4 cylinder engine. Do not change the bell housing. Instead make sure you are selecting a starter for your engine.
  3. Dec 16, 2022 at 10:56 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Learned something new!!
  4. Dec 16, 2022 at 11:12 AM
    Alexis_chavez132
    Alexis
    I’m sorry, I wasn’t very clear, I ended blowing up my transmission due to an input shaft seal leaking I didn’t catch the leak because it was leaking straight to a skid plate I’m currently shopping for a new transmission. And the transmissions I come across are right side starter and I need one that’s left side that’s why I was wondering about the bell housing swap
  5. Dec 16, 2022 at 11:46 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    I think what they are trying to tell you, is that you need to look for a transmission from your same engine type, not just the transmission model. If you get the same model but from a different engine configuration you might have to swap more than just one item, so it's probably a lot easier, in the long run, to look for manual transmissions from another 3rz.
    Alexis_chavez132[OP] likes this.
  6. Dec 16, 2022 at 12:11 PM
    USMILRET
    USMILRET Tacoma Owner
    1998, 2007 and 2020 Tacoma
    I would make every effort to find an exact match model type transmission for your truck.
  7. Dec 16, 2022 at 12:23 PM
    Bivouac
    OP you should be looking for a W-59 Transmission!
  8. Dec 16, 2022 at 12:48 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I suspect he needs an auto, not a manual.
    Bivouac[QUOTED] likes this.
