Transfer case replacement advice
Discussion in '3rd Gen. Tacomas (2016-2023)' started by xplrodr, Feb 7, 2023.
  1. Feb 7, 2023 at 9:48 AM
    xplrodr
    xplrodr [OP] Active Member
    N. Texas
    2019 Cement Tacoma TRD OR DCSB
    I have a 2019 Off Road with 82k miles. Last week when going from 4Lo to 4H, something happened, and I heard a lot of grinding and lost power. I had my truck towed to the dealer, and I was told my transfer case was bad and would cost 4.6k to replace it.
    Is this a fair price?
    And I treat my Tacoma very well, and I am shocked the transfer case went bad so fast. Is this normal?
    Thanks!
    Junkhead likes this.
  2. Feb 7, 2023 at 9:55 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    I would get another opinion,,, now I know this isn't easy, as you had it towed and will probably have to pay a basic inspection bill and have to have it towed again. But, for nearly 5 large, I would want to know more than it's simply ,,,,bad? I would want pics, what specifically is bad or broken, and how did this happen?
    were you stuck and trying to work your way out?
    Do you hard core off road, are you a dirt/gravel road cruiser? Not that there is anything with the latter, that's what I do too. For beating,,, I'd buy a beater.
    na8rboy likes this.
  3. Feb 7, 2023 at 10:05 AM
    xplrodr
    N. Texas
    No, I wasn't stuck. I was going from a snow-covered dirt road, stopped at a stop sign, and past the stop sign was pavement. At the stop sign, I shifted into N and then changed the dail to 4H. When I took off, I heard a lot of grinding and lost power.
    I use 4WD often and I am very familiar with the shifting process and the proper steps.
    What sucks, is that I only owe 3.6K.
  4. Feb 7, 2023 at 10:10 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    IMHO, it would look for a used T case on someplace like car-part.com . I would bet that you could get it fixed for half of that. Be sure that it comes with the actuator and it was not removed.
    ColoradoTJ, Squirt and SR-71A like this.
  5. Feb 7, 2023 at 10:11 AM
    Chew
    Chewy
    Midwest
    19 TRD OR
    ahh I see, that sucks sorry to hear it.
    I would hold out hope the dealer is NOT actually diagnosing and giving you a FU price/quote. Not all dealers are bad, but many are busy, understaffed, and picking and choosing jobs.
    Again, what you should be asking them is- what specifically is bad? I am not replacing a low mileage unabused TC to the tune of 5k because you say it's simply bad.
    MR E30, Jojee117 and Junkhead like this.
  6. Feb 7, 2023 at 10:13 AM
    xplrodr
    N. Texas
    I searched eBay (lol) and found several TC on there for under 1k. Would it be too much of a gamble?
    I am honestly out of my element on all of this.
    Sinister184 and tonered[QUOTED] like this.
  7. Feb 7, 2023 at 10:14 AM
    xplrodr
    N. Texas
    Good advice, I'll try and get some additional information from the service personal.
  8. Feb 7, 2023 at 10:18 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    I would be extremely shocked if my transfer case went out and at 82k miles.
    Are you sure it’s the transfer case? They are very sold built units, takes some skill to damage one.
    Mark77 and SR-71A like this.
  9. Feb 7, 2023 at 10:20 AM
    xplrodr
    N. Texas
    I am just going by what they have told me...but I am very gentle with my truck. I use it a lot, but I don't shift hard and always follow the proper 4WD shifting instructions.
    Junkhead[QUOTED] likes this.
  10. Feb 7, 2023 at 10:20 AM
    Sociopenguin
    Sociopenguin 2 Fang Engineering
    Tate
    NW MO
    DevilPenguin
    Schtuff
    In my case, this would probably have tempted me to FJ case swap and twin stick it personally. But honestly, not using 4wd is usually worse on these cases.
  11. Feb 7, 2023 at 10:50 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I bought a used motorcycle engine from eBay. It's been going strong for over 40k now.
    Mark77 and xplrodr[QUOTED][OP] like this.
  12. Feb 7, 2023 at 10:56 AM
    Sinister184
    Sinister184 Well-Known Member
    23 Tacoma TRD OR 4x4
    They're usually pretty stout. I dont recall seeing one fail under normal/light use either outside of the actuator. If it's truly the whole case, I'd buy a used one and swap it.
  13. Feb 7, 2023 at 10:59 AM
    xplrodr
    N. Texas
    Is swapping one pretty difficult?
  14. Feb 7, 2023 at 11:00 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    What do you mean lost power? Like press the gas and nothing happens? Or press the gas and theres a bunch of grinding sounds? Might help narrow it down a bit
    There have been a few posts of the actuator being mis-timed and the truck not knowing its current status. But I dont think that would cause any grinding, at least not anymore than the typical hi <> lo shift
    Brucey likes this.
  15. Feb 7, 2023 at 11:01 AM
    RockfishTaco
    RockfishTaco Well-Known Member
    Nate
    Massachusetts
    How much of that 4.6k is labor vs parts? If it 100% needs a tcase, I would ask if you could supply your own part and find something on car-parts.com.
    Looking locally to me, a tcase with under 50k miles is roughly $300-$500 on there. I'm also sure they're quoting labor for pulling complete trans and tcase together as I'm about 90% sure shop manual says that's how to do it... if that's the case and you can't do the work yourself; I'd shop around for a shop that'll put in a used tcase and charge a lot less labor.
    Swapping a tcase isn't too hard if you have a lift. I could remove/install one on my 2nd gen in less than 2 hours start to finish with a lift fwiw.
    MR E30 and SR-71A like this.
  16. Feb 7, 2023 at 11:02 AM
    xplrodr
    N. Texas
    Press gas, no power, lots of grinding. Both in D and R.
  17. Feb 7, 2023 at 11:05 AM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    I would have the truck towed to a reputable transmission shop in your area. Transfer cases aren't very complicated and are able to be repaired in most cases.
    If not, they can source a used one and open it up and go through it before they install it.
    Bcjammerx, RustyGreen and xplrodr[OP] like this.
  18. Feb 7, 2023 at 11:05 AM
    xplrodr
    N. Texas
    I have access to a lift, but never swapped one. I asked service and they said labor is $800, so the rest is the part. I would be completely find with paying $800 in labor if I could get the part for $300-$500 lol
    ToyoTaco25 likes this.
  19. Feb 7, 2023 at 11:09 AM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
  20. Feb 7, 2023 at 11:10 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    auskip07, ColoradoTJ and ToyoTaco25 like this.
