Transfer case oil
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TBLTravy, Jan 12, 2024.
  1. Jan 12, 2024 at 3:29 PM
    TBLTravy
    TBLTravy [OP] Well-Known Member
    2019 SR5 4X4 Sement , 2016 DCSB *sold*
    As the title says, one oil I’ve read about is the redline mt-lv as an alternative. Has anyone used it? Plus, if I buy one quart, is the Toyota fluid compatible with the redline / ravenol to where you could top up with the old fluid? Don’t want to buy two quarts if I don’t have to.
    Thanks in advance.
    80sforlife likes this.
  2. Jan 12, 2024 at 3:46 PM
    dentedporsche
    dentedporsche Well-Known Member
    Ron
    Used it in my vehicle plus other redline products for manual trans, differentials, etc. ... all have worked great.
    If your mileage is 30k+, would consider doing a change and will need 1.1 qt or 1 liter.
    02Duck likes this.
  3. Jan 12, 2024 at 3:58 PM
    BillyE
    BillyE Well-Known Member
    I used Redline MTL. It’s all compatible.
  4. Jan 12, 2024 at 4:14 PM
    TruckGuy63
    TruckGuy63 Well-Known Member
    Gilbert
    New York
    2019 Barcelona Red Dbl Cab TRD Offroad
    GL4 spec oil is very important . The brass inside the transfer case can get pitted over time with GL-5 stuff. Now I do see Amsoil severe gear is supposed to be ok in GL4 applications even though it’s GL 5 rated .With all that I went with the Ravenol stuff . Which so far has been totally fine.But it was interesting to see that GL -4 notation on the Amsoil stuff , which makes me think would it actually be ok as a replacement?
    Wero94, TartanEagle and joba27n like this.
  5. Jan 12, 2024 at 4:16 PM
    Bishop84
    Bishop84 Well-Known Member
    It's never happened though and no can prove it.
    Most dealers run GL5 and you wont find any failures of transfer cases except the odd actuator.
    I only push for GL4 on manual gear boxes, but I think the fear of GL5 in a transfer case is unfounded. It's not ideal, but not required.
  6. Jan 12, 2024 at 4:22 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
  7. Jan 12, 2024 at 4:34 PM
    OZ TRD
    OZ TRD Well-Known Member
    Central Coast CA
    6sp Manual TRD PRO - Lunar Rock '21
    Evo A SmartCap, Cali Raised Sliders (0 degree), 2WD low Mod, Puddle Pods, 3 switch overhead panel, 8 slot middle console panel, Custom driver's switch panel, Rek Gens, 265 75 16 Falkens, lil B Bed Stiffeners, All new Speakers, Diff Breather, AC Drain, Many interior bits...
  8. Jan 12, 2024 at 4:37 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    The Redline stuff will be fine, so would Ravenol, so would Toyota….and unless you live in ridiculously cold Canada, 75W-90 GL4 or 5 would be fine as well. I personally have 80W-90 GL4 conventional in mine and it shifts the smoothest it ever has….in Texas. I got a bunch of clunky shifts on the OEM stuff. Not always or even most of the time, but a lot of the time.
  9. Jan 12, 2024 at 5:38 PM
    JWestie
    JWestie Well-Known Member
    2019 Tacoma DCLB-OR Mag gray
    Based on advice of others here, I used it when I changed my TC this summer at ~60K. Used Amsoil Extreme Gear Lube for the differentials. No idea about compatibility though.
  10. Jan 12, 2024 at 5:45 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Yep I use it in my Tacoma and 5th gen 4Runner, after reading about it here: https://www.tacomaworld.com/threads/‘16-newer-transfer-cases.636057/
    The Tacoma transfer case developed a leak at the rear flange seal a year after I changed the oil. No idea if it's related to the Redline oil. Note that seal isn't submerged in oil while the truck is sitting stationary.
  11. Jan 12, 2024 at 5:50 PM
    5Sport
    5Sport Well-Known Member
    All Redline here, in all of my Toyota trucks since a 2009 Gen 2, a Gen 3 Tacoma, Gen 5 4Runner (2) a Highlander. I use the MT-LV in the transfer cases and the 75W-85 in the differentials. No issues and I think they smooth out the transfer case.
  12. Jan 12, 2024 at 6:02 PM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    Wero94 likes this.
  13. Jan 12, 2024 at 6:07 PM
    TBLTravy
    Thanks for the responses. Ordered the redline since it’s available on Amazon and free shipping
  14. Jan 12, 2024 at 8:24 PM
    80sforlife
    80sforlife Well-Known Member
    2017 Toyota Tacoma DC TRDOR 4x4
    Redline is my go to for transfer case and diffs. Been running it for a couple years. Np! Highly recommended.
  15. Jan 12, 2024 at 9:18 PM
    chasecmc
    chasecmc Well-Known Member
    Chase
    2017 DCSB TRD OR
    GFC
    As someone else stated one can of the OEM fluid is enough. That’s the safe and easy choice, the additive package of the ravenol isn’t even close to similar to the Toyota fluid, why risk it for a few bucks is my opinion.
    Speedbird and 22Coma6MT like this.
  16. Jan 12, 2024 at 9:47 PM
    Speedfreak
    Dave
    Canada Eh!
    Manual Mall Crawler
    Do you have a source for this information? I have not found anything in my research to suspect it isn't equivalent.
  17. Jan 12, 2024 at 9:56 PM
    TacoTuesday1
    FL
    I used something from Amsoil under the Transfer Case section
    Probably a normal weight
    https://www.amsoil.com/lookup/auto-...oyota/tacoma/4-0l-6-cyl-engine-code-1gr-fe-z/
    70-75w sounds low.
    AFAIK 75w80, 75w90, 80w90
    are more common specs.
    Higher hot weight is said to offer more protection under hard use. At the cost of some MPG loss. Only thing I’ve done that to is putting BG syn 75w140 in stock rear diff.
    edit: maybe not. It appears certain Toyota tcase oil is labeled as straight 75w
    looks like only 1 amsoil oil is both thinner, falls under tcase compatible, and does not contain LSD additives
  18. Jan 12, 2024 at 10:33 PM
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
    I used redline 75w my first change but due to cost I just used syncromesh the next time. Close to the viscosity of 75w but alot easier to find.
    it's presently -41 here with no wind chill and just for fun after gaining feeling to my hands and I started to move the truck I shifted through the transfer case and everything worked as well as the 75w.
    Gl4 is the better option for the transfer case if you insist on 75w-90 but not compulsory. The syncro in there doesn't have a very hard job to do if you follow the shifting instructions or ideally are coasting in straight line.
    Either way I doubt it'll ever wear out unless you like to play with the 4wd dial around corners, while the traction control light is flashing or you're just plain spinning the tires
  19. Jan 13, 2024 at 12:00 AM
    OZ TRD
    Central Coast CA
    Since we are on the subject - sort of...
    I got this for the Diffs... only after did i notice the note about the limited slip friction modifier...
    Is this ok to use?
    Does anyone have any insight on this?
    TIA
  20. Jan 13, 2024 at 3:21 AM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Put the Ravenol in my transfer case…..plan on a 25k interval
