Transfer case blown seal...
Discussion in '1st Gen. Tacomas (1995-2004)' started by Archaic2021, Jun 21, 2021.
  1. Jun 21, 2021 at 9:51 AM
    Archaic2021
    Archaic2021 [OP] Well-Known Member
    So how hard is it to change out the Front seal in the t-case.
    Noticed a little bit of a leak and topped off transfer case. Now...it's pouring lol.
    Napa can't get seal until tomorrow.
  2. Jun 21, 2021 at 10:06 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Just what is leaking you mention both the differential and transfer case ??
  3. Jun 21, 2021 at 10:07 AM
    Archaic2021
    Sorry just t case, just replaced the front Differential axle seals last week lol.
  4. Jun 21, 2021 at 10:07 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    FishingInSand likes this.
  5. Jun 21, 2021 at 11:29 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    The Front seal of the Transfer case ?
    Do you mean the one where the output shaft from the transmission goes in?/ This means pulling the transmission and case out
    The one at the front drive shaft? this one is much easier
  6. Jun 21, 2021 at 11:58 AM
    Boone Wesley
    Boone Wesley Well-Known Member
    Boone
    LA 818
    01 4D 4WD Limited
    That seal is not quite the same as the one in tims video, it's actually a lot easier. You can drive the seal through the hole into the case if you're not careful and I put silicone on the shaft splines.
  7. Jun 23, 2021 at 1:05 PM
    Archaic2021
    So its just about the same.
    I'm assuming removed front draft shaft, undo the nut to the flange, pull flange off and bam...theres the seal. Sounds easier than replacing the carrier bearing I just did.
    Is the front t-case nut a 24mm?
  8. Jun 23, 2021 at 1:16 PM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    The nut is the same part number as the rear according to the diagram:
    36104D: 90179-22016
    And because I between meetings, I was able to head out to the garage- 90179-22016 is a 30mm nut.
    Edit: The video posted above also has that nut as a 30mm.
  9. Jun 23, 2021 at 2:43 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    That nut is a stake nut. While I've reused mine, Toyota suggests it is a one-time use part. This is the one for my truck: 90179-22016
    SR-71A likes this.
  10. Jun 23, 2021 at 2:52 PM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    I've always had trouble with reused staked nuts coming loose. I would highly suggest for the $4 bucks that new ones are used. Different case if it's a trail on the road situation, but that doesn't seem to apply here.
  11. Jun 28, 2021 at 10:28 AM
    Archaic2021
    Thank you all for the info, still haven't done the job yet.. I did replace the front struts and was gonna tackle it but I am still trying to find something to use to drive the seal in. Also decided to go ahead and replace the nut.
  12. Jun 28, 2021 at 2:08 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    depending on the exact size of the seal you may find use in a kit like this
    https://www.amazon.com/Orion-Motor-Tech-Universal-Automotive/dp/B08JLDHZHT
    For $25 it has been a very handy though only occasionally used tool
