Transfer-case and Diff gaskets
Discussion in '2nd Gen. Tacomas (2005-2015)' started by trd_arlen, Jun 11, 2020.
  1. Jun 11, 2020 at 11:00 AM
    trd_arlen
    trd_arlen [OP] Well-Known Member
    2012 tacoma dclb
  2. Jun 11, 2020 at 11:03 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    The silver crush washer goes on the drain plug for rear diff.
    The copper washer goes on drain plug for front diff
    The thicker and flat silver washer goes on t-case drain plug
  3. Jun 11, 2020 at 11:03 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    The bigger silver ones go on the diff.
    trd_arlen[OP] likes this.
  4. Jun 11, 2020 at 11:11 AM
    trd_arlen
    2012 tacoma dclb
    thanks, it actually came with 6 total. so im guessing the fill plug needs one as well?
    BassAckwards likes this.
  5. Jun 11, 2020 at 11:16 AM
    spitdog
    If your doing your rear differential the two of the 3 crush washers on your middle finger go there and torqued to 36 ft lbs.
  6. Jun 11, 2020 at 11:20 AM
    BassAckwards
    Yes, that's correct. Two on the top are for t-case. Copper one and one of the other silvers are for the front diff, then the other two are for the rear diff drain and fill
    trd_arlen[QUOTED][OP] likes this.
  7. Jun 11, 2020 at 11:20 AM
    trd_arlen
    2012 tacoma dclb
    ok thanks, ill also be doing the front diff
  8. Jun 11, 2020 at 11:21 AM
    trd_arlen
    2012 tacoma dclb
  9. Jun 11, 2020 at 11:23 AM
    spitdog
  10. Jun 11, 2020 at 4:37 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    I just use Teflon tape, have for years and don't have any leaks...ever.
