Trans pump failed?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Brian422, Jun 2, 2023.
  1. Jun 2, 2023 at 7:12 PM
    Brian422
    Brian422 [OP] I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    Trying to diagnose. Pretty sure the trans pump failed without taking it out of the truck. I’m going to have to pull transmission but wondering what y’all think? Going to try tackling this myself.
    https://youtu.be/ddG5cRTWAls
  2. Jun 2, 2023 at 7:14 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Have you checked the fluid? It sounds like it could be sucking air and cavitating.
    10thMTNgrunt likes this.
  3. Jun 2, 2023 at 7:21 PM
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    Lol yea man first thing I did and been replaced. All OEM fluid. Same result
  4. Jun 2, 2023 at 7:24 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Well if the fluid level is good and the filter is installed properly it definitely sounds like an internal problem.
    Does it still drive?
    @gearcruncher your thoughts?
  5. Jun 2, 2023 at 7:27 PM
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    Yea it still drives a cools/ shifts fine. It started after I gone wheeling on a hard trail. Noise did that is. Drove 8 hours home. Trans did get up to 240* and pulled over let cool. Then rest of way home it never got above 175*. So don’t know what to think shifts still like nothing wrong. Haven’t driven truck since I got home Sunday. Changed fluid tonight and nothing changed. I’m almost positive it’s a pump issue.
  6. Jun 2, 2023 at 7:28 PM
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    I tagged him too but he’s been off TE since May 18th looks like
  7. Jun 2, 2023 at 7:50 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I mean it could be an internal bearing too but I'm not a transmission guy so I couldn't tell you what to look for, either way seems like the transmission is gona need to come apart.
    Was there metal in the pan when you changed the fluid?
    Yea he's not as active on here as he used to be but he still usually checks in once a week or so.
  8. Jun 2, 2023 at 8:09 PM
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    No metal
  9. Jun 2, 2023 at 8:11 PM
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    I turned the crank shaft by hand and one side moves east and then comes around to a spot that’s a lot harder to turn. Could be a gear meshing issue but the noise is coming right at the torque converter/bell housing area.
  10. Jun 2, 2023 at 8:32 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I wouldn't think so, it's a gerotor pump.
    As much noise as it's making I would have expected there to be metal in the pan, in the past when I've heard pumps sound like that they wouldn't hardly make enough pressure to make the transmission move and the pan is usually full of metal but I've never dealt with any Toyota transmissions.
  11. Jun 2, 2023 at 9:37 PM
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    Yea it happens all of a sudden too the noise was just there
  12. Jun 2, 2023 at 10:25 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Definitely a strange one, I wish I could be more help but transmissions are not my strong point.
  13. Jun 2, 2023 at 10:33 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    Have you removed the inspection plate to have a look at the torque converter and flex plate? Doubt it will result in anything, but worth a shot.
    Dm93 likes this.
  14. Jun 3, 2023 at 3:51 AM
    1 Limited Toyota
    1 Limited Toyota ISO XRunner body kit complete or pieces
    California
    08 XRunner
    slowly erasing past owner hacks
    All of a sudden? Not always? Hard wheeling?
    Any loose or cracked lines! Pumps cavitation can make noise. Basically water hammerig quickly
  15. Jun 3, 2023 at 6:28 AM
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    No that’s what I was saying, I’m going to have to pull it I just haven’t done it. Hasn’t even been a week since I discovered the problem lol
  16. Jun 3, 2023 at 6:30 AM
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    Yes right after a hard trail wheeling on. Double locked/ inclined lol. Definitely probably did it. But it still shifts and cools? Except for that one instance I mention above.
  17. Jun 3, 2023 at 6:53 AM
    jjsinaz
    jjsinaz Well-Known Member
    Jim
    Sun City West, AZ
    2023 TRD Sport DCLB Ice Cap 4X4
    From what you said, and after hearing the noise, I'd suspect something with the flex plate. Cracked or distorted and rubbing on something in the bell housing. (I used to fix trans for a living)
    Brian422[QUOTED][OP] likes this.
  18. Jun 3, 2023 at 7:04 AM
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    Yea it’s tougher to turn from crankshaft on one side only. Maybe it will be a simple flex plate swap out? Hope that’s the case lol. But it’s definitely coming from that area no question in my mind
  19. Jun 3, 2023 at 7:21 AM
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    Another thing to note is sound increases with throttle in all gear positions
  20. Jun 3, 2023 at 7:23 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Doubt it's the converter, it moves, shifts. Flex plate, either way it has to come out.
