trailer wiring harness on a non towing package truck?
Discussion in 'Towing' started by justin14200, Apr 16, 2010.
  1. Apr 16, 2010 at 6:44 PM
    justin14200
    justin14200 [OP] frequent reader
    justin
    baton rouge
    2010 prerunner sr5 bsp
    stock
    i have a 2010 toyota tacoma prerunner sr5 with the v6. i didnt buy the towing package. does it still have wiring? its too dark for me to go look right now...
  2. Apr 16, 2010 at 6:46 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Nope. You need to get the harness from the dealer.
  3. Apr 16, 2010 at 6:46 PM
    justin14200
    justin
    baton rouge
    stock
    any idea how much they cost? where does it plug in?
  4. Apr 16, 2010 at 6:47 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You can get them for about $80.00. Much better than the aftermarket ones.
  5. Apr 16, 2010 at 6:49 PM
    justin14200
    justin
    baton rouge
    stock
    awesome. thanks
  6. Apr 16, 2010 at 6:54 PM
    dhurley
    dhurley Well-Known Member
    Doug
    Colorado Springs, CO
    04 Double Cab TRD SR5 V6
    TRD, Snugtop Super-Sport, bedliner, receiver hitch, alarm mod, deck plate mod, AFE Pro-Dry S, Saddleman camo seat covers, TW decal, grey wire mod w/switch, DRL, LED cupholder mod, Dynomax Super Turbo, aux back-up lights, Devil Horns by Andres, "blue plug" mod for 2LO, shorty antenna, Pro Comp fog & driving lights, receiver shackle, 15% tint front windows, stainless nerf bars, Ultra Gauge, diff breather mod
    I'd put an aftermarket one on a previous truck, it was plug & play. Very simple.
  7. Apr 17, 2010 at 3:22 AM
    FoxySandChick
    FoxySandChick Well-Known Member
    Kristin
    Henderson, NV
    07 DC 4x4 Base model V6 Impulse Red Pearl
    De-badged, limo tint, black wet okole's, weathertechs, extra d-rings, TSB bilsteins
  8. Apr 22, 2010 at 5:09 AM
    JDCPA
    JDCPA Well-Known Member
    Jim
    SW FL
    09 5 Lug Access Cab SR5
    Curt Hitch and etrailer.com wiring harness.
    Why is that, Chris?
    I've been using an aftermarket harness mounted in the tail lights that works great and is a hundred times easier to install than the oem.
  9. Apr 22, 2010 at 5:33 AM
    911-3.2 Well-Known Member
    CT
    Sold - 2010 Access Cab 4x4 I4 SR5
    Curt Receiver Hitch, Access Literider Tonneau
    If all you are looking for is a 4 pin wiring harness I'd just pick up one of the aforementioned aftermarket kits. I have one from etrailer.com and it was easy to install and works well.
  10. Apr 22, 2010 at 5:48 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The OEM harnes gives a dedicated circut to the trailor. The aftermarket ones dont.
  11. Apr 24, 2010 at 7:50 PM
    Isthatahemi
    Isthatahemi Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
    And people have had issues with the aftermarket ones, if they have a high current draw from many lights or whatever. It's like buying a Toyota, and putting Yugo wiring in it.
  12. Mar 4, 2011 at 4:32 PM
    mattygabe
    mattygabe Well-Known Member
    Western PA
    2011 Access Cab SR5
    Access Limited Soft Rollup Tonneau Cover
    Again, I think this is just an issue of what you're planning on doing. If you have a ton of lights, obviously you're going to want the OEM that has a dedicated circuit. I recently bought an aftermarket Curt harness from eTrailer, and right on the back of the box I think it says it's only rated for one light per each side that's a certain size and pulls a certain voltage, so (without reading or hearing about those problems, mind you) it might just be a case of someone not realizing that they don't have the proper equipment for what they need to do.
  13. Dec 30, 2011 at 11:01 AM
    fixenu
    fixenu Member
    NV
    trd
    I priced a plug here in elko and the dealer wants over $200.00 for harness any ideals were i can fined a better price?
  14. Sep 30, 2014 at 11:48 PM
    NotRed
    NotRed Well-Known Member
    A way around overloading the existing light harness and fuses is to get the aftermarket ones that have a dedicated power connection to the battery. They just take the signal from the existing harness and get the power for the trailer's lights from the battery. A fancy relay if you will.
    Of course that does mean you have to run a wire to a power source but that's not such a big deal.
