Trailer running lights...No Work
Discussion in '3rd Gen. Tacomas (2016-2023)' started by timbo3875, Jan 10, 2017.
  1. Jan 10, 2017 at 6:06 PM
    timbo3875
    timbo3875 [OP] Member
    2016 White Tacoma Limited 4x4
    Anyone have issue with trailer lights? Turn signals and brake lights are good. No tail lights. Checking the truck wiring voltage show no voltage between ground terminal and tail light (brown wire) position in the 4-prong flat connector (lights are turned on). Ideas? BTW all lights are good when trailer is connected to other vehicles.
    RGVReefWR5 likes this.
  2. Nov 25, 2018 at 3:19 PM
    captainredman
    captainredman Member
    2016 DBL TRD OFF ROAD
    Did you figure this out? I’m having the same issue. Plugged in a different set of lights and a different trailer, and no go. It’s definitely the truck. 2016 TRD OFF ROAD.
  3. Nov 25, 2018 at 3:25 PM
    lucky13don
    lucky13don Well-Known Member
    Don
    Milton, fl
    R.I.P.04 tacoma prerunner, 04 sequoia 4x4
    Too many to list
    Check the fuses and follow the wires look for breaks or pinches. Check your grounds.
  4. Nov 25, 2018 at 3:27 PM
    Killowatt
    Killowatt Well-Known Member
    Citrus County Florida
    2013 4x4 TRD OFF ROAD
    Most likely a bad ground between trailer and truck. To test, use a length of wire connected to a clean spot on each frame. I still have a length of wire with a clamp on each end, used for U-haul trailers years ago.
  5. Nov 25, 2018 at 3:30 PM
    maxtherat
    maxtherat Well-Known Member
    Inland Northwest
    2001 Dodge Ram 2500, 1993 Jeep Wrangler
    All the usual diesel truck mods- fuel system upgrade, programmer, CAI, intake manifold, 60MM stealth turbo
    Since you’re checking at 4 way flat connector I’m assuming you have a 7 round adapter plugged in? Maybe the newer Tacoma’s come with a factory 4-way along with the 7 round? If you are using an adapter I’d suggest removing it and checking voltage at the pin on the main 7 pin connector. It doesn’t take much for those things to act up and not work correctly. Your tail lights working fine on the truck?
  6. Nov 25, 2018 at 5:57 PM
    FishChief
    FishChief New Member
    2017 Tacoma TRD Off Road
    I had similar symptoms this past summer. Check a fuse in the under hood panel; you’ll find it on the driver’s side. It’s the green 30 amp blade fuse next to the pink square-ish one. The fuse panel lid will have a puller and replacement 30 amp fuse.
    arrakis429, psubrew and lucky13don like this.
  7. Nov 26, 2018 at 9:53 PM
    captainredman
    Thanks guys! I’ll check it out tomorrow and let you know. Sounds like I’ll start with the green 30amp. Then work on checking the grounds.
    1) yes it’s a 7 pin and 4 pin model. My trailer is a 4 pin. I checked the trailer with a 7 pin to 4 pin converter and it’s the same. No running lights from either of the sockets. 2016 model.
    2) @Killowatt , so when I look to check for grounds, I should use a length of wire and connect what to what?
    3) can I just use my multimeter to check the voltage? The running light pin should always be on, and the brakes and flashers only when activated, correct? I assume I just put the hot (red) lead in the pin, and the black will go to ground (frame).
    Thanks again guys. This forum is awesome.
  8. Nov 27, 2018 at 5:24 AM
    Killowatt
    Just find a clean spot on the frame of the trailer and the truck, under a bolt maybe, or use alligator clips to hold in place at each end.
  9. Nov 27, 2018 at 7:37 PM
    captainredman
    It was the green fuse. Thanks guys.
    Irons, auskip07 and Tacoma2020 like this.
  10. Apr 28, 2021 at 3:52 AM
    psubrew
    psubrew Member
    2021 Cement TRD OR
    Dude you just saved me a headache. I love that these threads can help folks out years later. Mine issue was a bad fuse.
    Bastek likes this.
  11. May 22, 2022 at 5:04 PM
    chumhead
    chumhead New Member
    Craig
    2017 Toyota Tacoma Blazing Blue Pearl
    I just built a small harbor freight trailer and while installing and testing the lights after assembling this 1000 PC jigsaw puzzle, realized my running lights didn't work (trailer only).... a quick Google search led me here (as usual, not my first time) and I finally joined just to say "Thank You!" for this thread.... it was a 2 minute fix and it was even the first fuse I checked. Thanks again!
    Irons and TwistedTLM4 like this.
  12. Jun 17, 2022 at 1:49 PM
    Robertmoore0012
    Robertmoore0012 New Member
    Robert
    2018 Tacoma Sport
    Thanks for the info!!
    chumhead likes this.
  13. Aug 5, 2022 at 1:31 PM
    jeffsmitty
    jeffsmitty Active Member
    Jeff
    Northport, Alabama
    TRD Offroad 4x4
    2017 White TRD pro grill
    30 amp mini fuse blown. Next to large 30amp 2017 TRD Offroad 4x4
    AZ Pete likes this.
  14. Jun 30, 2023 at 7:22 PM
    Toymango71
    Toymango71 New Member
    Brian
    2020 SX Tacoma & 2016 TRD off-road
    Thank you. Same thing. Fuse blown. LoL did check here first so yeah I checked ground and for breaks in the wire. Stopped to eat and thought I would double check the forum. Checked the fuse and sure enough bad fuse. Any idea what pops it. Or is everyone just carrying extras? My trailer has no issues with my other rigs so I'm thinking is something else. All the lights are led (utility trailer).
    Thanks again.
    Brian.
  15. Aug 6, 2023 at 7:05 AM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    because there was a problem. that's the entire reason fuses exist.
    i would verify that something isn't wrong on the trailer.
    Chew likes this.
  16. Aug 6, 2023 at 10:05 AM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Correct ….last time I had this issue, the tow ball was badly rusted
  17. Aug 6, 2023 at 10:10 AM
    NorrinRadd
    NorrinRadd Well-Known Member
    WA
    2019 Sport, access cab, MT, Eibach 2.0 stage 2, tow, silver.
    My 2019 uses the 7-connector but the trailer lights only light up when the headlight selector is set to one of the last two notches only, if I leave it on the DRL setting like I usually drive then there is no trailer lights when towing.
  18. Aug 7, 2023 at 3:21 PM
    Killowatt
    You won't have running lights with DRL selected, but you should still have brake lights and turn signals on the trailer.
