Trailer Plug relocation?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacoma13_NC, Mar 24, 2024.
  1. Mar 24, 2024 at 5:51 AM
    Tacoma13_NC
    Tacoma13_NC [OP] Well-Known Member
    2013 SR5 4x4 DCSB 4.0L (Black) OTT
    Bilstein 6112/5160; JBA HD UCAs; 1.5" 3-Leaf AAL's w/ overload; OME CB drop; RCI aluminum skids w/ catalytic converter shields; Wheeler's U-Bolt flip kit with Superbumps; TRD Pro 4-Runner Wheels; BFG KO2's (265/70/17); Diode Dynamics SS3 Sport (Yellow) fogs; CaliRaised 32" hidden light bar; Morimoto XB LED headlights with upgraded HD harness; Unifilter mod; Rear-View mirror riser bracket; Truxedo Lo Pro tonneau cover; New OEM color-matched grille; Bumpershellz color-matched rear bumper cover; Ultra-Gauge MX 1.4 w/Spiker mount; Baja Designs S2 Sport Ditch Lights with SDHQ brackets; Fog Light Anytime Mod; Overland Tailor Tune (OTT)
    I'm looking for a mounting bracket that rotates the plug 90* underneath the bumper so it's out of the way. I'm not really interested in cutting a hole in the bumper itself to mount next to the license plate. I've seen that these were available several years ago but the makers have stopped producing them from what I can find. Any ideas?
    koditten likes this.
  2. Mar 24, 2024 at 6:26 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I removed one of the license plate lights and mounted the plug in it's spot. You only need one light. The RV type plug receptical fits right in. I also rotated the plug receptical so the spring loaded door hinges down. Makes it much easier to align the plug into the receptacle.
    I do a lot of towing and this was a huge improvement.
    This looks factory to me and you don't need to cut a hole in the bumper.
  3. Mar 24, 2024 at 8:29 AM
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    Tacoma13_NC[OP] likes this.
  4. Mar 25, 2024 at 5:06 AM
    Springsboy
    Springsboy Well-Known Member
    Colorado
    2013 4x4 DCSB SR5
    Full RCI skids RCI bolt on sliders with extra two bolts/side ADS reservoir coil-overs front Bilstein 5100 shocks rear Icon RXT leaf springs, set on option 3 Rear Eaton E-locker, built by ECGS CBI Moab 2.0 classic bumper Diode Dynamics SS3 Pro white fog lights Leer Cap
  5. Mar 25, 2024 at 5:19 AM
    Tacoma13_NC
  6. Mar 25, 2024 at 5:44 AM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    You could unbolt the mount and zip tie it up out of the way. That's what I did with mine......after I broke it the first day of ownership.
    Mine was already tweaked when I got the truck so I got a replacement trailer light harness. It's still in the factory Toyota bag in my garage. Maybe I'll install it one of these days.
  7. Mar 25, 2024 at 12:06 PM
    Bigezee
    Bigezee Well-Known Member
    2013 Toyota Tacoma V6
    do you have pics of this and the bracket you used? thanks
    koditten[QUOTED] likes this.
  8. Mar 25, 2024 at 1:01 PM
    koditten
    Kirk
    Central Michigan
    No bracket is needed. I drilled 4 holes thru the plastic.
  9. Mar 25, 2024 at 3:32 PM
    Bigezee
    That is a thought. I only need the four pin though. Are those Schrader valves next to it. Maybe for air brakes?
  10. Mar 25, 2024 at 3:49 PM
    koditten
    Kirk
    Central Michigan
    Air bags to combat squat when trailering.
  11. Mar 25, 2024 at 3:52 PM
    Bigezee
    ahh. gotcha. didn't think about that. thanks
  12. May 2, 2024 at 1:20 PM
    Laughing Bandit
    Laughing Bandit Member
    2012 Toyota Tacoma 6-spd T|X Pro
    None. Yet.... :-)
    I find myself in the same situation, but I have a cheap Hooke Road rear bumper that is pretty substantial to drill through. I haven't found a good bolt-on option that is still available and might have to DIY it on my '12.
  13. May 2, 2024 at 4:58 PM
    ToyotaMan2015
    ToyotaMan2015 Well-Known Member
    Nathan
    Somerset KY
    2015 Silver Tacoma Limited
    32in Tire
    Tacoma13_NC[OP] and koditten like this.
